Independent rear suspension???
Discussion in 'Suspension' started by devanb3, Oct 1, 2018.
  1. Oct 1, 2018 at 10:25 AM
    devanb3
    devanb3 [OP] Well-Known Member
    devan
    hampstead
    I've seen many people post about a SAS (solid axle suspension) swap, why not an independent rear suspension (IRS) swap? I know many military vehicles like Humvee and some of the older jeeps run an independent rear to give a much higher ground clearance along the center-line of the truck, so why hasn't anyone attempted on the Tacoma? I think their is enough room to do so without losing your bed space. and the amount of welding and work doesn't seem to be much more than that of an SAS. Maybe more expensive?
    What would the pros and cons be of an IRS vs a SAS?
    Has anyone tried to do one and been successful?
    I am thinking about trying to do one within the next 5 years and mainly want opinions and science as to whether it's worth it or not and whether i should or should not attempt.
  2. Oct 1, 2018 at 12:05 PM
    T6A1C9O
    T6A1C9O Well-Known Member
    San Diego, CA
    2017 SW DCSB TRDOR 4x4 w/Tech
    IRS will be more expensive, more complicated, will most likely end up with less payload capacity, tends to be heavier (see what happened to the Mustang), and have less travel than a modified stock configuration.
    On top of that you are introducing more failure points into the driveline.
    What is the use case for the modification? Better ride? Would be cheaper/easier to get a Ridgeline. Offroading? Stick to the solid rear.
  3. Oct 1, 2018 at 12:15 PM
    Muddinfun
    Muddinfun Well-Known Member
    Humvees use portals to gain massive ground clearance. Just a few of the disadvantages not already mentioned. More stuff to break. Needs wheels aligned properly.
    Gunshot-6A likes this.
  4. Oct 1, 2018 at 12:16 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    There was at least one guy on here who did it. I'll try to find the build thread.
  5. Oct 1, 2018 at 1:22 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Before going to a weaker platform just to have more clearance, go find some unimog portal axles and sas your taco using those. Unless you plan or using this for something like baja style racing, then the rear independent might be worth exploring.
  6. Oct 2, 2018 at 11:17 AM
    Icon_Adrian
    Icon_Adrian Well-Known Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    Icon Bypasses & Coilovers Long Travel Front & Rear Supercharged 3.4L
  7. Oct 2, 2018 at 11:24 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    The Ridgeline has IRS :anonymous: :crapstorm:
    But yeah, swapping in an IRS setup would be a pain in the ass. You'd basically have to rip out the front end of a tacoma, and install it in the back. As if our CVs and boots didn't face enough peril already!
  8. Nov 12, 2018 at 12:26 PM
    Barnburner
    Barnburner Well-Known Member
    2015 Tacoma SR
  9. Nov 12, 2018 at 1:39 PM
    T6A1C9O
    San Diego, CA
    I guess the question is what's the application/justification? If it's just to be different that's fine but you're sacrificing some of the reasons to even buy a truck. I'm sure it's possible to stuff it up under the rear but you'd lose travel, payload capacity, room for spare tire, matching gear ratios for 4x4s, lockers for TRD ORs, etc.
  10. Nov 12, 2018 at 6:25 PM
    Johnhn686
    Johnhn686 2018 Tacoma DCLB TRD Off-Road 4x4
    Houston, TX
    Revtek was showing off their 3rd gen IRS conversion at SEMA this year.
