Increase lug nut torque for bigger wheels and tires?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austin1346, Sep 19, 2023.
  1. Sep 19, 2023 at 9:04 AM
    austin1346
    austin1346 [OP] Active Member
    1999 Tacoma Reg. Cab Short Bed 2WD 5spd
    Hello, I'm getting new wheels and tires for my 1st gen 5 lug. Looks like stock lug torque is 83ft-lbs. If I'm switching from stock (195/75r14 & 15x6) to 235/75r15 tires and 15x7 wheels, do I need to torque the lug nuts more since the wheel/tire will be heavier, or will that cause damage? I couldn't find anything on google relating unfortunately.
    Thanks!
  2. Sep 19, 2023 at 9:09 AM
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    You don’t want to torque them down more. Those specs are given so that you don’t over tighten and snap lugs off.
    You want to make sure you use the right lug nuts that seat properly on the rim you have.
    A buddy of mine lost his tire and rim, while driving; due to over tightening the lug nuts. It weakened the lugs and they snapped.
  3. Sep 19, 2023 at 9:12 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    The torque value has nothing to do with the size of the wheel/tire. It has to do with the lug studs.
    I run 35s on 17 inch aluminum wheels... still torque to 85 ft lbs. (because I've always torqued to 85 on this truck... because 83 is dumb lol)
  4. Sep 19, 2023 at 9:25 AM
    austin1346
    That's what I was going to guess, just wanted to make sure. Thanks guys.
