In bed pressure washer?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PunisherTaco, Jul 6, 2016.
  1. Jul 6, 2016 at 8:58 AM
    PunisherTaco
    PunisherTaco [OP] Member
    Greg
    Hey all Newer member here sorry if not allowed and delete if need be. I have been searching and have not found what i am looking for. I want to have a portable pressure washer like Karcher K2 with a vacuum pickup tube. I am wondering if the bed power outlet will be enough to power the washer. I want to make a portable system to take with me to the Dirtbike track so I can wash the bikes before coming home. I live in an apartment and do not have a hose to attach to washer. Anyone know or a small setup like this or does anyone HAVE a setup like this? If not I will make one but I am still waiting for my truck to be delivered to the dealer. thanks in advanced.
  2. Jul 6, 2016 at 9:01 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Somebody did this, but I'll be damned if I can find it.
  3. Jul 6, 2016 at 9:02 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Keep in mind OP, the bed power is only 400 watts max, this type of pressure washer is around 1400 watts. You'd be better to go gas.
  4. Jul 6, 2016 at 9:09 AM
    PunisherTaco
    Greg
    Thank you guys for quick response, So id have to find a lower wattage washer or go gas.
  5. Jul 6, 2016 at 9:15 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  6. Jul 6, 2016 at 9:16 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  7. Jul 6, 2016 at 9:16 AM
    127.0.0.1 AKA ::1
    /etc/hosts
  8. Jul 6, 2016 at 9:18 AM
    PunisherTaco
    Greg
    The problem I see with the 12v ones is that its like a garden hose, I dont want to buy one and it not get the job done. The wattage converter might be an option though they just plug in to the outlet or do I need to wire it in?
  9. Jul 6, 2016 at 9:18 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  10. Jul 6, 2016 at 9:19 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    You would need to wire the inverter to a 12 volt source.
  11. Jul 6, 2016 at 9:19 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    dude
    you are not stripping paint, you are blasting mung off a dirt bike. you do not need the monster washers
    I have used 12volts on my MTB when I race, and I have clay mud errywhere...these work fine. use a brush and poke at the really hard bits.
  12. Jul 6, 2016 at 9:22 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    You would have to wire it and probably add a second battery for that high of a inverter wattage. To be safe, at least a 2500 watt inverter, but would be based on the wattage of the unit you want to use.
  13. Jul 6, 2016 at 9:39 AM
    PunisherTaco
    Greg
    Im going to try and borrow a buddies washer and see if it will work. what is the worst that could happen? blow a fuse?
  14. Jul 6, 2016 at 9:42 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep, fuse will blow in a hurry. Don't waste your time.
    PunisherTaco[OP] likes this.
  15. Jul 6, 2016 at 9:45 AM
    PunisherTaco
    Greg
    well crap, guess ill have to go with inverter or 12v... Thanks for the insight guys.
  16. Jul 6, 2016 at 10:12 AM
    koditten
    Kirk
    Central Michigan
    I'm not sure you are getting this.
    The plug in the bed is an inverter. It will put out just enough A/C voltage to run a small TV at best.
    If you get an inverter, you will be plugging it into one of the cigarette plugs. You can look at the writing on the little flap on these plugs. It will tell you the maximum watts the plug will produce. You can't run a pressure washer off these plugs. The wiring is not heavy enough.
    You will need a very large inverter to run a pressure washer and it can not be plugged into the cigarette plugs. It will have to be clamped directly to a battery. An inverter big enough to run an electric pressure washer will be very expensive.
    Your best bet, if you absolutely need serious cleaning power is to get a plastic 55 gallon drum and run water from it to a GAS pressure washer.
  17. Jul 6, 2016 at 10:16 AM
    PunisherTaco
    Greg
    Thank you, I think im going to be going this route but ill have to make a cover for the top so water doesnt splash out while driving
    http://www.northerntool.com/shop/to...2N_dYGxEeHHL39YsnV6jYSkrkZOJs8XSezhoCIDjw_wcB
  18. Jul 6, 2016 at 10:17 AM
    koditten
    Kirk
    Central Michigan
    Now you are talking!
    That should work pretty good for blasting dirty rides.
  19. Jul 6, 2016 at 10:19 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    no one needs a commercial paint stripper concrete cleaning pressure washer
    to get woods mung off a chariot
    -12v DC washers pump hard enough to sting but not break skin
    -gas and 1500 watt pressure washers can destroy your hand
    -hand-pump plant sprayers won't hurt your eyeballs
    IMHO of these three types, the 12v DC is ideal for woods adventures on a dirtbike
    you may just want added tank capacity and a brush. you don't want high pressure
    on a dirtbike anyway lest you wash the grease from the wheel bearings and
    steerer anyhow
  20. Jul 6, 2016 at 10:19 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Hmmm, ya, that might work for you. Good luck OP.
