Improving ride comfort
Discussion in 'Suspension' started by RedsWhiteTaco, Mar 11, 2020.
  1. Mar 11, 2020 at 3:59 AM
    RedsWhiteTaco
    RedsWhiteTaco [OP] Well-Known Member
    Portland
    2020 Tacoma Off-Road
    I am sure this has been answered a million times but one more won't hurt.
    I have a 2020 OR DB Cab 5ft. For my driving and off-roading a lift and massive suspension upgrade would be super cool, but unrealistic. This truck is my daily commuter and right now everything is stock. I did some weekend driving around the Oregon coast and for the first time I really noticed the stiff cornering at higher speeds and even slower speeds on sharper corners.
    My question... is there a suspension upgrade or a simple yet quality option to approve cornering for a smoother ride or do I just need to accept the stock suspension as is.
  2. Mar 11, 2020 at 4:13 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Could you describe a little more what the truck is doing while cornering that you dont like?
    I ask because in general, stiffer suspension is what people do to improve handling in corners. Softening it up increases roll. Most aftermarket options will use heavier springs so they will feel a bit stiffer on road, with the benefit being that they are better offroad.
    If youre bottoming out the suspension, thats a different story, and the first thing Id suggest would be a set of Wheelers Superbumps for the front and back. Honestly, of all the things ive done to my suspension, those are probably the biggest comfort increase I noticed.
    AccuTune Offroad likes this.
  3. Mar 11, 2020 at 4:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    You have the most comfy OE suspension already.
    Have you checked tire pressures? Often they are way over inflated at the dealer by the prep folks.
  4. Mar 11, 2020 at 1:28 PM
    RedsWhiteTaco
    Portland
    Well I clearly know nothing because I was under the impression stiffer was not ideal for a daily commuter. It could be my driving but it just felt like I was going to roll even on slower speeds.
  5. Mar 11, 2020 at 1:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    su.b.rat likes this.
  6. Mar 11, 2020 at 1:47 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Is this your first truck?
    QuicksandTaco and BalutTaco like this.
  7. Mar 11, 2020 at 1:47 PM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    So there's pros and cons like with anything. If you want to go hard through corners and not feel that 'I might be about to roll' sensation, you'll need stiffer springs (because they require more force for the suspension to compress). The downside to stiff springs is that you feel bumps more. This is why high performance cars are generally a bit uncomfortable to daily- they have stiff springs so you can haul ass through corners, but road imperfections won't really compress them much.
    personally- I prefer the slightly softer suspension cause I live somewhere with shitty roads, and I'd rather have to go a little slower around corners and not rattle my teeth out of my head.
    But if your biggest complaint is the truck squatting through turns, stiffer springs is the fix for that. Or go slower lol
  8. Mar 11, 2020 at 1:51 PM
    su.b.rat
    su.b.rat broken truck
    everything posted here is good info to consider. honestly, I'm still not clear on what exactly you seek. are you simply looking to control body roll say low to medium speeds? does this sound right?
    if so, i would recommend looking into a rear sway bar to start, given that you already have one up front and it's installed correctly.
    next step after adding a rear bar, would be up upgrade the front one.
    but for this case if I'm understanding correctly, it would likely be easily solved with this on the soft setting:
    https://www.autoaccessoriesgarage.com/Suspension/Hellwig-Anti-Sway-Bar/_Item/_220400327
  9. Mar 11, 2020 at 2:36 PM
    RedsWhiteTaco
    Portland
    yes... is it obvious haha
    tcBob likes this.
  10. Mar 11, 2020 at 2:37 PM
    gotoman1969
    Well then great choice and welcome to tacoville.
    tcBob likes this.
  11. Mar 11, 2020 at 2:52 PM
    RedsWhiteTaco
    Portland
    It’s hard to explain maybe it’s because I am noob. I am starting to think it might just be my driving. When driving to beach there are a lot of curves at 60mph it felt like I needed to slow to 40mph just to make it around. Now granted I come from sedan driving for many years. I wanted to be able to hit the curves and not feel like I am going to roll. Does that make sense? Sorry I am new to this.
  12. Mar 11, 2020 at 2:53 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
  13. Mar 11, 2020 at 2:54 PM
    gotoman1969
    It’s definitely not a sedan. You’ll get used to it.
    QuicksandTaco likes this.
  14. Mar 11, 2020 at 2:58 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I'm so confused about what you want and need.
    You say that you off road, want to improve cornering, and want a smoother ride. You can't do all these things well at the same time.
    And you're right, a stiffer suspension is not idea for a daily commuter. Because if it's just a daily commuter, you're not supposed to care about how well it corners. Better cornering is the whole point of a stiff suspension, you give up comfort in exchange for handling. What you described is not daily commuter stuff.
    Based on everything you've said I think stock suspension is your best option right now.
    BalutTaco likes this.
  15. Mar 11, 2020 at 3:01 PM
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Yea, this is just because of the way the suspension is set up. It's an Off-Road model, So like Jibbs said the shocks are softer so they'll absorb bumps better when driving off road. The other side of this coin is a lot of swaying in corners at speed. (The TRD Sport model is set up the opposite, slightly stiffer shocks, for slightly better on-road handling).
    You can get stiffer shocks so you'll get less sway around corners, but you can't really have both improved cornering and improved off-road bump absorption (at least not without spending a lot of money, which you said you don't want to do).
  16. Mar 11, 2020 at 3:02 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    “Hey guys, first truck and I love it! I love everything about truck. Question. How can truck be more like car? I want it to drive like car. Thanks!”
    DarthPow likes this.
  17. Mar 11, 2020 at 3:02 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, what @gotoman1969 said, you will get used to it. I just took our Corolla to the store last weekend, it was like driving a go kart. They are different beasts with different uses.
  18. Mar 11, 2020 at 3:06 PM
    RedsWhiteTaco
    Portland
    Sorry for the confusion guys. I appreciate the input. Thank you for putting up with me haha
  19. Mar 11, 2020 at 3:14 PM
    RedsWhiteTaco
    Portland
    sorry dude I don’t mean to post a stupid thread. Figured I would ask the people that know what they are doing haha
  20. Mar 11, 2020 at 3:19 PM
    BalutTaco
    Its all practice man. I came from riding small sedans to motorcycle now a midsize truck..... stock taco handles great! skrrrt skrrt
