Improve My 2WD Off-Road Build
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrnick7, Aug 7, 2020.
  1. Aug 7, 2020 at 6:18 AM
    andrnick7
    andrnick7 [OP] Member
    I recently bought a 2015 Tacoma 2WD Access Cab.
    I want to do some overlanding in it. In practice that means most of my miles will be on-road miles with moderate off-roading.
    My plan is simple:
    Copy the Prerunner’s proven 2WD off-roading build.
    That means I’m changing my current specs:
    • 15" wheels
    • P215/70SR15.0 BSW AS tires
    To match the Prerunner’s specs:
    • 16" wheels
    • P245/75SR16.0 BSW AT tires
    • Possibly stronger suspension
    Is this the best approach to achieve my goal? Or would you add or remove anything?
    Also, would I need to swap out my suspension?
    Looking forward to your responses :)
  2. Aug 7, 2020 at 7:57 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I dont know that you are going to fit that size of tire on a 5 lug. Also you wont be able to mount a 6 lug wheel on a 5 lug for obvious reasons.
  3. Aug 7, 2020 at 9:07 AM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    You would also need to add a rear locker if you really wanted to copy the TRD OR Prerunner build.
    I have no idea if all of this is possible on a 5lug, others here know more on this topic
  4. Aug 7, 2020 at 9:12 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
  5. Aug 7, 2020 at 9:32 AM
    Dr Amocat
    Dr Amocat Active Member
    Zack
    '13 Base (old Orkin truck) | '18 Black F150 XLT 4x4 STOCK | '88 Red GMC Sierra 1500 (wife's car)
    2" Leveling Kit 235/75/R15 Tires ARE Camper Shell Black Plastidip Badges/Frame
    Check out the 5-lug section! Great info and there are some people doing badass stuff to our little trucks.
    I put on - Cooper DISCOVERER A/T All-Season 235/75R15 105T Tires on my 2013 SC as well as a 2" front spacer leveling kit. I run a camper shell the majority of the time so I will be putting on an aal and bilstein 5100s (or equivalent) in the rear sometime soon! Lots of people on the 5 lug thread have done much bigger tires than me with the BB mod and bigger spacers, etc!
    Das it mang and andrnick7[OP] like this.
  6. Aug 7, 2020 at 11:34 AM
    andrnick7
    That's awesome!
    How much off-roading do you do? This sounds like you're doing what I'd like to do.
  7. Aug 7, 2020 at 11:47 AM
    Dr Amocat
    Zack
    i only did the lift / tires like 2 months ago and am in the middle of a landscaping renovation so all I have gotten to do so far is play in the mud while picking up project trash :/ .
  8. Aug 7, 2020 at 6:48 PM
    Slum Lord
    Slum Lord Well-Known Member
    My vote:
    -stock
    -rear tire chains
    -winch
    Everything else is just BS you most likely won't need.
    EdgemanVA likes this.
  9. Aug 8, 2020 at 5:46 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    But what is needed is good judgement. Pick your trails carefully knowing you have a 2-wheel drive truck.
    Dr Amocat and caffeinated_medic like this.
  10. Aug 8, 2020 at 6:35 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I wheel a lot in 2wd. I wouldn’t go without AT/MT tires, winch (with recovery gear), and sliders. I installed a locker now but I still have to winch, just not as often. You have to approach things differently in 2wd and hit things faster/harder. I’ve completely trashed my side steps lol
    caffeinated_medic likes this.
  11. Aug 8, 2020 at 7:11 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    All things being equal a 4X4 is about $1000-$1500 more than a 4X2. Instead of spending money to modify your 4X2 trade for a 4X4 and leave it stock. You'll come out money ahead in the long run and have a much more capable truck.
    Dr Amocat likes this.
  12. Aug 8, 2020 at 8:28 AM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Another vote for rear locker. I have a rear auto lock and almost never use 4x4
    dirtnsmores likes this.
  13. Aug 8, 2020 at 10:32 AM
    Dr Amocat
    Zack
    I have two other 4x4s and agree that it can be worth it (although I think its more expensive than that) but there is something fun about taking an old fleet vehicle and making it tougher!
  14. Aug 8, 2020 at 10:35 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    U can fit 33s with a 5 lug second gen.
  15. Aug 8, 2020 at 10:36 AM
    Das it mang
    Az
    1996 T100 SR5 MT
  16. Aug 9, 2020 at 12:28 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Its a bigger difference between 5 lugs and any 6 lug.
    As mentioned check out the 5 lug lifting threads on here as the suspension is different from 6 lugs. After lifting 3" in the front and 2" in the back, you can fit 33s or 32s with less rub. The diff is the same as the non elocker 3rd members so any lsd or locker meant for 6 lugs without an elocker will work (ARB). A good set of tires will help alot as well. I like my Goodyear Duratracs as they're not fully mud tires but work really well.
    As for recovery gear maybe a winch or at least a shovel and tow strap will take you a long way. Just start going with your local offroading groups and you will see what you really need.
  17. Aug 9, 2020 at 12:32 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Another vote for some type of rear locker or limited slip. I think a TrueTrac would be a great addition to any 2wd truck.
    Does the 5lug have the same removable carrier as the 6 lugs? If so it's an easy upgrade.
    winkel and 5 Lug Fury like this.
  18. Aug 9, 2020 at 12:43 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Yeah its the same as the all the non trd offroad 2nd gens. I was about drop a lsd in but ended up swapping in a complete elocker axle for cheap lol
  19. Aug 9, 2020 at 12:45 AM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Any big deal to wire in the new locker?
  20. Aug 9, 2020 at 12:48 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Not really took me probably a day. I used a switch from Low Range Offroad and I would suggest adding another switch to make sure you don't accidentally bump it on the highway.
    kodiakisland[QUOTED] likes this.
