Improve AC Performance for $6
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015WhiteOR, Jul 26, 2019.
  1. Jul 26, 2019 at 7:36 AM
    2015WhiteOR
    2015WhiteOR [OP] Well-Known Member
    Gainesville TX
    I'm sure all of you geniuses are already doing this, but for those who aren't:
    1. Go to Home Depot and pick up a can of this (AC-Safe Air Conditioner Foaming Coil Cleaner)
    2. Next time you're going to wash the truck, first pop open the hood and get this can ready.
    3. Spray down all of the radiator type surfaces behind the grill. The can sprays foam in a thin stream, so you can even shoot through the grill or at angles, and you'll hit the radiator fins.
    4. Make sure you get the transmission cooler as well as towing package cooler and AC condenser surfaces.
    5. Watch as all the highway bugs start flaking and melting off.
    6. Let it soak for 5 minutes
    7. Grab a garden hose and using the hose end only (no sprayer), use the full stream to completely rinse all of this out of the radiators.
    8. Rinse until you no longer see foam/bubbles in the water spilling to the ground
    9. Rinse off the paint/chrome/headlight surfaces that were covered in the foam.
    10. Wash as usual
    11. Re-wax any surfaces that were covered by this foam. It strips wax.
    Even on my relatively clean truck, after doing this, the AC started freezing me at highway speeds. Sadly this won't do much for AC performance when crawling in slow speed traffic, but that's just a design flaw in the Tacoma.
    rjtoc2, xtremewlr, TacoTRD78 and 18 others like this.
  2. Jul 26, 2019 at 8:10 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ya know I was about to hose out my condenser core this weekend. Ill have to grab a can of this.
    Anton338 likes this.
  3. Jul 26, 2019 at 8:20 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Where are the AC coils located? Interested in doing this.
  4. Jul 26, 2019 at 8:24 AM
    nd4spdbh
    SoCal
    Condenser coils are in front of the radiator.
    TacomaMike37[QUOTED] likes this.
  5. Jul 26, 2019 at 8:47 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Yep. Condenser cleaning is likely overlooked by some. I do mine in early spring and very early fall - garden hose. All of my vehicles get this. HVAC at home as well.
    For those who don't know, the condenser is where the heat collected inside the truck is released. If the condenser is dirty, that doesn't happen as well as it should and the refrigerant that now travels to the evaporator is not in quite the same state it was intended to be in.
    In some respects, the condenser does the same thing the radiator does.
    4x4Taco09, goforbroke123 and Skyway like this.
  6. Jul 26, 2019 at 8:50 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I’ll have to try this!
  7. Jul 26, 2019 at 11:03 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    This is the product I wanted to know about for my "Home A/C unit".
    Thank-you.
    It never occurred to me to use it for automotive resource.
    WINNING
  8. Jul 26, 2019 at 11:42 AM
    2015WhiteOR
    Gainesville TX
  9. Jul 26, 2019 at 11:48 AM
    Skyway
    Ande'
    St.Pete
    Thank-ya!
  10. Jul 26, 2019 at 11:49 AM
    TacomaMike37
    13' DCLB MGM
    Nice work man
  11. Jul 26, 2019 at 11:55 AM
    2015WhiteOR
    Gainesville TX
    It may be beneficial to do this process twice, but with a day between each run.
    The first go-round, you're going to be dislodging any dirt on the front of each radiator and then rising it out. If you let the radiator dry completely and then hit it again, the foam can work its way towards the back where it can dissolve more dirt. The goal here is to have the foam touching any cooked-on bugs or road slime, as this emulsifies it and lets the water wash it away.
    If you can also rig up a vinyl tube so that you can push the foam between the AC condenser and the engine radiator, that would also help. Just be careful not to bend any fins.
  12. Jul 26, 2019 at 12:01 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    this ?
    2 clean jobs with it ?
  13. Jul 26, 2019 at 12:02 PM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    definitely a good pro tip. just be careful what you get wet under the hood!
    Skyway likes this.
  14. Jul 26, 2019 at 12:12 PM
    cromag27
    phx-ish
  15. Jul 26, 2019 at 12:13 PM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    May be a dumb question, but does it matter if when you are hosing it all off, if you spray from the outside in or spray it out towards the front of the truck?
  16. Jul 26, 2019 at 12:26 PM
    2015WhiteOR
    Gainesville TX
    If you can maneuver the hose so you spray out towards the front of the truck, more power to you LOL.
    I didn't want to have to disassemble a bunch of the radiator shroud pieces just to get to that.
    Skyway likes this.
  17. Jul 26, 2019 at 12:46 PM
    Jaypown
    Justin
    NE Ohio
    lol Right. I was thinking it was worth a try to see to at least try and spray some out. But thinking about it more with the shroud, it is what it is. I'm used to blowing mud and rocks out of ATV radiators. My truck doesnt (shouldnt) have a layer of mud in there.
  18. Jul 26, 2019 at 12:55 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    cromag27[QUOTED] likes this.
  19. Jul 26, 2019 at 1:05 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I used some Nu-Brite to do just this. I don’t know that I would recommend it as it is very aggressive (it will strip paint if you aren’t careful)
    But it worked great. Here are some pics
    Before:
    During:
    After:
    Bonus pic, from where the cleaner ran down it even cleaned my aluminum skid plate.
  20. Jul 26, 2019 at 7:45 PM
    STAGE 2
    STAGE 2 Well-Known Member
    Awesome! I’ve only got 28k, but definitely gonna do this when I swap out the stock rad for the RJC one.
