Imogene with a trailer?
Discussion in 'Off-Roading & Trails' started by ebarrere, Aug 23, 2020.
  1. Aug 23, 2020 at 8:19 PM
    ebarrere
    ebarrere [OP] Active Member
    2007 Tacoma, TRD off-road
    3” lift, 32s
    Anyone take a trailer over Imogene pass before? I would never attempt this on black bear, but hearing mixed reviews about Imogene..
    We’re in Ouray tonight and want to stay near telluride tomorrow, but have a small (very off-road capable) trailer in tow. I know I can take the highway, but where’s the fun in that??
    2007 DCSB TRD off-road with 33s and a competent (if slightly reckless) driver.
    I’ve seen videos and it doesn’t seem too bad, but am I crazy to consider pulling a trailer over?
  2. Jun 17, 2023 at 12:17 PM
    CHUOX17A
    CHUOX17A Well-Known Member
    Jesus
    Southeastern Ohio
    14 DC TRD OR
    I have waited for an answer on this an nothing. Did you tried with the trailer ? I have a M416 that will like to haul all the way there
  3. Jun 20, 2023 at 12:04 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Call Norwood Ranger District (970) 327-4261 or Ouray Ranger District (970) 240-5300 on this and opening date.
    When open the road is rocky, steep, narrow, muddy, and can have snow/ice when first opened in places and passing can be dangerous and that would be the main issue. Some tight turns on steep grades also.
    Remember uphill has right of way (supposed too but depends) so if you have to backup good luck or in fact even cram those 2 over so others can pass if a group. Often very busy. If heavily loaded braking could be an issue as well as uphill power/traction condition based. They run tours up there using big pickups with seats in the caged bed and they are slow moving and pull over a lot as you can guess.
    RV length restriction set at 300 inches or 25 ft so not sure on truck/trailer if this applies.
    Imogene and Black Bear usually opens by July 4 so see:
    Road Conditions | San Miguel County, CO - Official Website (sanmiguelcountyco.gov)
  4. Jun 20, 2023 at 12:31 PM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I’ve done Imogene a few times now going from telluride to the ourray side the biggest issue is probably oncoming traffic there are some places that are super tight when passing
    As far as turns there was only one left turn going up hill where I kinda puckered as the right side was a cliff and drop off
    when you get down in the ourray side there are some pretty big rocks/boulders that may give you a bit of a hard time but if it’s your first time I would not take the trailer scout it out first also Colorado had a shit ton of snow so call the ranger first. A few weeks ago I wanted to go to Alta lakes near telluride luckily I called ahead even though it said the area was open online, the ranger said it was still 10 feet of snow
