Immobilizer bypass for remote start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justin144, Oct 7, 2010.
  1. Oct 7, 2010 at 8:17 PM
    justin144
    justin144 [OP] Well-Known Member
    justin
    Las Cruces, New Mexico
    2011 Taco 4X4 Dbl cab Long Bed
    Hi,
    I joined this forum because I need some help with my toyota tacoma that I bought but I haven't had any luck getting help from anybody yet.
    I am in the process of installing a remote start on my 2011 tacoma and I need to purchase an immobilizer bypass. If anyone has had experience with installing these, I would appreciate some input. Currently, I don't know what exactly I need to purchase and need help figuring it out.
    I think this http://www.bulldogsecurity.com/Prod...-module-for-remote-starter-installations.aspx might be what I need, but I'm not sure because it says TRANSPONDER bypass. what does this do? and what's the difference between that and the XK05 bypass? and how easy is it to install these? PLEASE HELP!
  2. Oct 7, 2010 at 9:19 PM
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    Try asking your dealer? I have no idea.
  3. Oct 8, 2010 at 5:43 AM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    Immobilizer and Transponder are the same. The system the Tacoma has is a transponder that recognizes the key being used. Toyota calls it an immobilizer. The bypass system you are referring to uses your spare key, which is put inside the box and mounted usually under the dash. Then the system always thinks that the proper key is being used. The problem with this system is your ignition can now be mechanically defeated and driven away as it defeats the purpose of having this anti theft feature.
  4. Oct 8, 2010 at 9:40 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
  5. Oct 8, 2010 at 2:51 PM
    justin144
    justin
    Thanks guys for the help. I appreciate it. How easy was it to install this bypass?
  6. Oct 8, 2010 at 3:00 PM
    Raylo
    MD, USA
    This bypass itself is pretty easy. It just taps into two wires (scrape a bit of insulation off and solder on) on a small connector near the ignition switch (see my notes). With the older style xk-05 models you had to cut the ECM wires and put it inline. Much more "invasive surgery" than with these "ALL" models. But this is just one small part of the remote starter job. Lots of wires to find and connect.
  7. Oct 8, 2010 at 8:40 PM
    justin144
    justin
    Ok well that sounds like the way to go then. I've already installed the remote start by myself, I just need the bypass. So if its no more difficult to install than the starter, I should be good! :D
    Thanks!
  8. Oct 8, 2010 at 8:45 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    thats one thing that i dont understand why people spend SO much money on remote start.....why?
  9. Oct 8, 2010 at 9:23 PM
    justin144
    justin
    100 bucks is "SO much"..? I got it because it would super nice to be able to get into a nice warm truck this winter when its freezing outside, and also be able to get into a cool one when it's hot.. Definitely worth $100 dollars in my opinion.
  10. Oct 8, 2010 at 9:31 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    what kind of remote start did you get for $100?
  11. Oct 8, 2010 at 9:37 PM
    justin144
    justin
  12. Oct 8, 2010 at 9:37 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    more power to you then man! :laugh: i always thought they were A LOT more.
  13. Oct 8, 2010 at 10:14 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    A buddy of mine has remote start. On those hot days, it's really nice to get into a cold car. And if you have a dog, you could leave the truck running with the A/C on too.
  14. Oct 9, 2010 at 3:51 AM
    Raylo
    MD, USA
    I use it mostly in the winter but I found it helps in the summer, too. Often I'll just hit it as I am walking back to my car in a hot parking lot and having it run for only 30 seconds is enough to clear the a/c vents of that superheated air that builds up while parked. Much more comfortable to drive away with relatively cool air coming out of the vents and it doesn't require that you run the truck for long periods unoccupied.
  15. Aug 18, 2011 at 6:58 PM
    amoomaw
    amoomaw Senior Member
    moomaw
    central illinois
    2011 TRD Sport Black
    pioneer 4300dvd, subwoofer, axxes steering wheel controls, remote start, painted rims, stereo usb/ipod converter, tinted fog and tail lights, low profile window shades, tinted windows, low profile bed top, custom grillcraft grill, blacked out headlights+tint film, night shaded driving lights mounted under hood, night shaded 3rd brakelight, film tinted tail lights, aftermarket pop'n'lock tail gait lock, light switch added for off-road lights, headlight "eyebrows", remote start, hardwired radar detector, seat belt chime disabled, disabled drl, painted interior, custom leather seat covers.
    Do you have to use a bypass to install a remote start? 2011
  16. Aug 18, 2011 at 10:13 PM
    justin144
    justin
    yep
