Imminent Crankshaft Position Sensor (CPS) failure in 2016s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oldschoolczar, Jul 21, 2016.
  1. Jul 21, 2016 at 4:24 PM
    oldschoolczar
    oldschoolczar [OP] Well-Known Member
    '16 DCSB TRD OR
    Seems like there have been a lot of premature failures of the CPS on the 2016s. Makes me think that Toyota sourced some cheap-ass China parts for the CPS or something. I wonder if Toyota is aware of this? Would they issue a TSB or recall for this or would they just try to cut costs and hope that many would fail outside of warranty when they'd be off the hook.
    I rely on my truck to get me deep into and out of the backcountry. Would be quite an inconvenience if this happened on an isolated forest service road. Although with the growth in Colorado, it's getting pretty hard to find true isolation.
    Anyone know if Toyota is putting in the same CPS or if they're replacing with a more reliable model? I know warranty wouldn't cover this, but if I see many more of these reports I'd almost consider paying to have the sensor replaced if Toyota has upgraded.
    smitty99 likes this.
  2. Jul 21, 2016 at 4:37 PM
    oldschoolczar
    '16 DCSB TRD OR
    Yeah, I'd hope so. I'd imagine having a mis-timed crankshaft could jack up the engine a bit and maybe cause some significant wear once the sensor goes bad? No idea, as I'm not a mechanic. I could be totally full of shit, but I'd rather not have to get stranded and go through the rigamarole...
    If anyone who has had this issue could chime in that'd be sweet... are they replacing like with like or is there maybe an upgraded sensor? I guess that information may not even be public knowledge at this point.
    Is this something that's pretty easy to do? I replaced the O2 sensor in my POS Nissan Altima, but this seems like a more critical component and I'm minimally mechanically-inclined.
    Rrowdy likes this.
  3. Jul 21, 2016 at 4:39 PM
    oldschoolczar
    '16 DCSB TRD OR
    The hammer likes this.
  4. Jul 21, 2016 at 5:07 PM
    TacoTim16
    TacoTim16 Well-Known Member
    Tim
    Ohio
    2016 SR DCSB 4x4
    How many is "a lot of premature failures"? Seen 2 or 3 posts about it.
    Cavedog, 2016Tacoman, vuTron and 7 others like this.
  5. Jul 21, 2016 at 5:42 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yeah .. those parts in my experience are made in Japan .... unless I see otherwise I'm going with a very integral part of my engine should be a quality part.
    Doesn't make sense to cut corners on a vital engine part to me.. but I'm a common sense sort of guy with some of electrical engineering experience. Bean counters on the other hand ...
    Electrical engineers will build with the BEST parts available. I trust Toyota on that. I've actually banked on that.
    Hobbs and mbarbay like this.
  6. Jul 21, 2016 at 5:45 PM
    oldschoolczar
    '16 DCSB TRD OR
    Yeah, I don't want to get it replaced if it's the same part anyway... I'll probably roll this dice.
    And for the guy who says 2-3, I've seen more like 6-7 over the past few months. It's definitely probably the most common failure I've seen so far...
  7. Jul 21, 2016 at 5:55 PM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    I'll remind you of a quote from a movie which pretty much says it all...
    A new car built by my company leaves somewhere traveling at 60 mph. The rear differential locks up. The car crashes and burns with everyone trapped inside. Now, should we initiate a recall? Take the number of vehicles in the field, A, multiply by the probable rate of failure, B, multiply by the average out-of-court settlement, C. A times B times C equals X. If X is less than the cost of a recall, we don't do one.
  8. Jul 21, 2016 at 5:56 PM
    Bishop84
    Bishop84 Well-Known Member
    There have been other CMP sensor TSB's that require shimming, but most have been the stupid Subaru 2.0 (FRS) D4S engine, I had the same issue with my previous Subaru, They are extremely sensitive to air gap clearances and a minor defect can cause issues.
    I've yet to see a model where replacement of the sensor doesn't correct the issue.
  9. Jul 21, 2016 at 10:38 PM
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    I've thought about carrying one as a spare. I don't know where it's mounted on this truck, but having one in hand could turn a ruined trip into a few hours or inconvenience.
    I haven't found one listed for the 2016, but it looks like typical prices are around $40-$70.
    0210 likes this.
  10. Jul 22, 2016 at 4:09 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    If more than 1 person has an issue on an automotive forum, Its a major issue and there should be a recall immediately.
    SandyTaco4x4, JL911, EB Group and 8 others like this.
  11. Jul 22, 2016 at 6:17 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Does anyone have a picture of what the CSP sensor looks like or where is is mounted on the 2016?
  12. Jul 22, 2016 at 6:19 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Except sites like this tend to draw in people who have issues. It's a lot like going to the doctor and noticing that most of the people in the waiting room are sick. "Must be something going around". But it's a doctor's office and that's where people go for answers to their problems. It's the same around here. "Must be something going on".
    Maybe it is....maybe it isn't. But like any issue...unless there are enough failures to trigger whatever red-flag system Toyota has in place...things like the occasional bad CPS will be replaced on a as-needed basis.
    EB Group, Cazzwell, cctk2 and 6 others like this.
  13. Jul 22, 2016 at 6:27 AM
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    Those of us with the 7.3l Powerstroke did just that....it was a weak link on the motor so I kept one in the glove box. Had to change it once as I recall.
    MannyS likes this.
  14. Jul 22, 2016 at 6:35 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The description in Fight Club was incorrect. Actual "analysis" was done by Ford in regards to the Pinto in a rear collision, where the bolts on the rear axle can pierce the fuel tank. :D Anyway, the way safety reporting and recall decisions are handled by NHTSA have changed significantly since then.
    Bolsillos5624 and TRDinOhio like this.
  15. Jul 22, 2016 at 6:38 AM
    nevadabugle
    Elko, NV
    Wait...you are saying a movie about a ficticious fight club misrepresented a fact like that. Who knew?
    Fortunt1, EB Group, IronPeak and 6 others like this.
  16. Jul 22, 2016 at 6:42 AM
    KenLyns
    Belly of the Beast
    Toyota uses a common CKP sensor across many models. Since the 2016 parts catalog isn't online yet, I can't confirm if 2016 still uses the same part as 2005-2015. There's been some speculation the sensor's proximity to an exhaust pipe in 2016s may be causing the failures. So the solution may not be a redesigned sensor, but better heat shielding.
    nevadabugle likes this.
  17. Jul 22, 2016 at 6:45 AM
    KenLyns
    Belly of the Beast
    Haven't tried soap made from human lipo fat to confirm the other "facts" from the movie either. :laugh:
    nevadabugle[QUOTED] likes this.
  18. Jul 22, 2016 at 6:48 AM
    nevadabugle
    Elko, NV
    "It was beautiful. We were selling rich women their own fat asses back to them." Tyler Durden
  19. Jul 22, 2016 at 7:21 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    That's something else we don't know, was it the CPS that actually failed or the install?
    CPS do fail, but very seldom, I can only think of a few in my life, but from different makers, one Ford, Olds, and one other.
    To get a spare for the wilderness (or a weekend) is not an expensive part to have, based on the scary stat info we have so far, but to do the actual R&R might be a challenge, if we don't know the proper install for this application. I know I don't.
    Perhaps someone with an active TIS account can download the installation instructions for the ’16??
    Cheers!
  20. Jul 22, 2016 at 7:28 AM
    nevadabugle
    Elko, NV
    [QUOTE="The hammer, post: 12870625, member:
    Cheers![/QUOTE]
    Please can someone do this.
