I'm concerned. yellow gunk under oil filler cap...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neverstuck, Jan 5, 2010.
  1. Jan 5, 2010 at 8:46 PM
    neverstuck
    neverstuck [OP] Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    :eek: I changed my oil and under the oil filler cap there was yellow gunk. There was a trai of yellow fluid trailing dorn from the filler cap into the engine. There was a small deposit of yellow gunk up in the top/inside of the filler cap. What is this stuff?
    I've been using synthetic 5w20 for the past few oil changes after buying my 06 trd used. previous owner used conventional.
    I changed my spark plugs approximately 1500 miles back. Other than that I don't know what else to add. :confused:
    I'm concerned that when changing my spark plugs (for the first time) that I frigged something up because my fuel economy has been crap lately too. (might just be because I'm running 265/75/16 studded mudders)
  2. Jan 5, 2010 at 8:47 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Some moisture in the oil.
    wilcam47 and ABNFDC like this.
  3. Jan 5, 2010 at 9:18 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Sounds like blinker fluid residue.
    presta24, Troutman3000 and TacoMan33 like this.
  4. Jan 5, 2010 at 9:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2. Change the oil more frequently.
  5. Jan 5, 2010 at 9:26 PM
    Carone
    Carone Well-Known Member
    NOR CAL
    LOOK HERE!!! 02 TRD xtra cab v6 4x4 white
    Look at my Build
    Like yellow yellow or yellowish? lemonade, or fresh oil
    thick or watery?
  6. Jan 5, 2010 at 9:30 PM
    4low2go
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Sometimes a lot of short trips where the engine oil doesn't get up to full temp will also cause that.
    mabepossibly likes this.
  7. Jan 5, 2010 at 9:31 PM
    dorkman
    dorkman Well-Known Member
    Drive more so the water evaporates, its just condensation in the fill neck. Should be fine.
  8. Jan 5, 2010 at 9:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Yep...nothing to worry about:)
  9. Jan 5, 2010 at 9:46 PM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Its lube from the cap. My truck is only 3 months old and I noticed it the first oil change that I did. It wont hurt anything.
  10. Jan 6, 2010 at 5:47 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    mine does that too.
  11. Jan 6, 2010 at 4:11 PM
    JKD
    JKD Well-Known Member
    I was freaked out the first time I saw what looked like mayonnaise on the oil filler cap and PCV valve on my old car. Short city trips will do that. Go drive a good long highway drive to get the oil up to full operating temp for a while. It will drive the water out of the oil.
  12. Jan 6, 2010 at 4:24 PM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Yep, freaked me out the first time I saw it too. Looks like mud or something.
  13. Jan 6, 2010 at 4:34 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    really bad VD, you should go to the Dr.
    Maticuno, Lifeofbrian and Maggot61 like this.
  14. Jan 6, 2010 at 6:09 PM
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Make sure your not using coolant. My last vehicle had that ( not a toyota ) Turned out to be a cracked head.
    bluezzy likes this.
  15. Jan 6, 2010 at 6:13 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    it's an infection,its called engine pus
    Benzdriver81 and jshsltr like this.
  16. Jan 6, 2010 at 6:22 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I just changed my oil last night and noticed the same thing. It's condensation from heating/cooling cycles. I've never had a vehicle that I've noticed this on before. I do virtually all highway driving, my commute to work is 25 miles each way on freeway, so I know the oil is getting up to temp. I keep a close eye on coolant and have not used any in 15k miles.
    Oh well, I'm sure it's not really a problem.
  17. Mar 16, 2010 at 11:48 AM
    curt05
    curt05 Member
    Curt
    Dallas, TX
    05 4x4 v6
    Hey fellows. I've been a member for a while now but this is my first post. I logged-on this morning to read about this very subject. I have just rolled over 115K on my 05 V6 4x4. I have been the ONLY person that has ever done ANY PM on my truck. At 3K I drianed the factory oil and began using RP 5-30. This truck has only seen RP 5-30. I have always done my oil changes at 7,500-10,000 miles. For those of you that know & use RP products you will understand how I rest assured knowing my truck is well taken care of. This past w/end I changed my oil and it was at 11K cince my last change. Now, this is by far the longest that i have gone on an oil change. When I changed it this time I noticed, for the first time ever, that I had a "yellowish gunk" under my oil cap as well as in the filler tube. I removed the tube, took a sample,washed it as well as the cap and re-installed them. After draining the oil I took my flexable fiberoptic light and looked around inside the timming chain as well as the walls of the case. NOTHING! This was not good enough for me so I then proceeded to get back under the truck and removed the oil pan to inspect. NOTHING! I completed the oil change and documented the issue in my ongoing excell document. I know, I know. I am that guy!
    In my profession I have the luxury of being able to use some of the finest molecular testing available. After returning to work yesterday and examining the sample I can report, w/ 100% certainty this condition was caused by moisture in the oil. The break-down (for you geeks out there) is as follows: 97.3% synthetics, 2.1% H2O, .6% (w-code ,dirrivative of the refining process) or "contaminants.Now as we all know hydrogen can ONLY be introduced to any invironment in two ways. First, it was intrduced on purpose (adding water) and we know that did not take place. Second, atmospheric (the cooling and heating of any liquid).
    Knowing that I have not seen this to date I am in the process of reserching this issue. Taking into consideration that I often go as long as 9K-10K on an oil change (but ONLY when the miles in that time-frame are highway miles) I have never gone as long as I did on this past change, 11K. I have to conclude that in the time/miles from 9K to 11K the H2O content rose. This is the question at hand. I will find out why as I am that guy!
    I'm sorry, did you just want to know the time or did you want to know how to build the watch?
    BTW, this is a great location to find answers to many questions you may have to do with Toyaot Tacomas. Keep it up.
    Curt
    2001 Taco V6 4x4 (272K miles)
    2005 Taco V6 4x4 (116K miles)
    2008 4Runner V6 4x4 (23K miles) wife's
    2010 Land Cruise 4x4 (4K miles) too many extras to mention...
    Adventurous likes this.
  18. Mar 16, 2010 at 11:51 AM
    JKD
    No need. The only reason the mayonnaise-like deposits exist is because of cold-weather condensation inside the cold parts of the engine. The oil fill tube is a big, cool insulator.
    The water is trapped in the mayo and does no damage. When the weather warms up, the water will be driven out and removed via PCV.
  19. Mar 16, 2010 at 11:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sounds like pollen..................
  20. Mar 16, 2010 at 12:26 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    Unless a chunk of it it falls off and blocks an oil galley and burns up something in the engine .
