illumination wire pioneer avh-p4400bh? Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Aug 16, 2012.
  1. Aug 16, 2012 at 8:04 AM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Do I have to connect the illumination wire from the pioneer avh-p4400bh to factory illumination wire for radio to work properly? I remember reading somewhere about dash light fuse problem but can't find that thread. Thanks for any help
  2. Aug 16, 2012 at 10:55 AM
    blazze2005
    South Jersey
    I emailed Pioneer and this was the response I got from them... Thank you for contacting Pioneer Electronics (USA) Inc. No, the illumination is only use to dim the display when the head lights are on. So I'm just gonna go ahead and not connect the illumination wire for this install
  3. Aug 16, 2012 at 11:03 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I have an AVIC F700BT and my illumination wire is connected. I know mine has 2 modes, headlights on and headlights off. I can set the brightness to whatever I want on either one. Right now, with headlights off, it's set at 10/10 and with headlights on it's at 5/10.
  4. Aug 16, 2012 at 11:33 AM
    blazze2005
    South Jersey
    Ok so when your Avic dims when your headlights are on, is it the screen that dims? Or is it the buttons on bottom of unit? Thanks for any info...
  5. Aug 16, 2012 at 11:35 AM
    The Traveler
    SoCal
    The screen itself dims.
  6. Aug 16, 2012 at 11:38 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    i have an avic u310bt, and only the screen dims
  7. Aug 16, 2012 at 11:56 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    On my AVIC-D3 the screen not only dims but also changes colors to ones that won't blast your night vision. I highly recommend hooking up the dimmer wire.
  8. Aug 16, 2012 at 12:14 PM
    blazze2005
    South Jersey
    Yeah I definitely don't wanna lose the auto dimming feature, I was just afraid to hook up the illumination wire after hearing people blew out their dash lights.
  9. Aug 16, 2012 at 12:31 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    PLEASE use a multi-meter and TEST BEFORE connecting that wire! Then when you think you got it, test again, then a third time just for good measure. Trust me, illumination wires ruin vehicles in seconds!
    For the record, mine is connected, but I am certified in mobile electronics and know 12v like the abc's. If your wire harness has 2 orange wires (one might be orange/white) ONLY CONNECT ONE!! and be sure to test it first. Trust me. Most people just connect orange to orange and get lucky, others aren't so lucky. Bad things happen to nice trucks
  10. Aug 16, 2012 at 1:11 PM
    blazze2005
    South Jersey
    I have a volt meter...how would I go about testing it? Thanks for any help
  11. Aug 16, 2012 at 1:19 PM
    ProForce
    Anthony
    Alaska
    The radio harness only has (1) solid orange wire correct?
    On the wire harness you bought that plugs into OEM side and splices into radio harness, does it have (1) or (2) orange or orange/white wires?
  12. Aug 16, 2012 at 1:25 PM
    The Traveler
    SoCal
    Just curious, how does connecting the wrong wires screw up the entire truck? My harness only had 1 orange wire that was marked "ILL".
  13. Aug 16, 2012 at 1:27 PM
    blazze2005
    South Jersey
    Pro Force I'm gonna check as soon as I get home from work today. I realy appreciate the help you are giving...I'm done at 6:00pm today east coast time
  14. Aug 16, 2012 at 2:22 PM
    blazze2005
    South Jersey
    I was doing some google searches and found this info... An illumination wire simply lets the head unit detect when your headlights are on. When voltage is detected on the wire, the unit will dim the display so that it doesn't hurt your night vision. It is NOT for turning on the radio display lights, and it does NOT allow you to adjust the head unit display using the vehicle dimmer switch. It just dims the display when your lights turn on. The factory radio harness usually contains one or more illumination wires. You can test for it using a multimeter. A true illumination wire will show 12 volts with the parking lights on, and 0 volts with the lights off; it won't vary with the dimmer switch. You may find a "dimmer" wire, which will show voltage with the parking lights on, but the voltage will vary as you adjust the switch.
  15. Aug 16, 2012 at 2:56 PM
    The Traveler
    SoCal
    That's exactly how I thought it worked...which is why I asked my that question in my previous post. :confused:
  16. Aug 16, 2012 at 3:31 PM
    nammer
    Nam
    Bradenton, Florida
    I think some units and/or harnesses have a orange/white striped in addition to the orange they usually label them dimmer or illumination, I think the dimmer could be how factory units adjust with brightness of dash
  17. Aug 16, 2012 at 5:24 PM
    blazze2005
    South Jersey
    ProForce I just looked at the harness...You are correct the pioneer radio harness only has one orange wire/actually it's orange with white stripe,it's a thin wire. In the pioneer owners manual it's listed as Orange/white it says to (connect to lighting terminal) the wire itself is not marked.
    The main metra harness only has one orange wire/it's also Orange/white stripe and it's markes Dimmer on the wire
  18. Aug 16, 2012 at 7:08 PM
    blazze2005
    South Jersey
    I just realized something! The correct definition for illumination is a feature that when you turn on your lights for night driving the stereo dims so your not blinded by the bright radio lights. Well hello mcfly lol...My Tacoma doesn't have that feature at all. The only way I can turn down the brightness of my radio lights would be to manually use the dimmer dial. So doesnt that meen my truck doesn't have an illumination wire in the factory radio wiring??? I meen this is common sense right:confused:
  19. Aug 16, 2012 at 8:39 PM
    BBYE V8
    BBYE V8 Please keep TW beautiful: search & stay on topic
    Brian
    StL, MO
    07 AC 4x4 2.7 5sp SR5
    No...I'm pretty sure there were two wires for illumination going to the factory head unit. One controlled the brightness of the buttons as part of the dash dimmer function, the other turned on the lights for the display when you turned on the headlights. Or was that vice-versa?
  20. Aug 16, 2012 at 8:54 PM
    blazze2005
    South Jersey
    I won't know until I get my volt meter out and test them.
