Ignition switch wiring help
Discussion in '1st Gen. Tacomas (1995-2004)' started by thatguy2020, Apr 4, 2021.
  1. Apr 4, 2021 at 10:32 AM
    thatguy2020
    thatguy2020 [OP] Member
    1998 tacoma prerunner 2.7l
    A few months ago my ignition rod that turns the ignition switch broke. since then I've had the ignition switch hanging down and that's how I would start the truck. well last night when I got home and turned it off the switch fell apart and I lost a couple pieces for it and now I cans start the truck. I have a ignition panel I had for another project but I want to use it so I can get rid of the hanging ignition switch. the problem is I need to know what each wire is that goes into the connector for the ignition switch. With the switch broken I cant turn the switch to check voltage or anything to figure out which wire is which. Any help would be greatly appreciated.
  2. Apr 4, 2021 at 10:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Here's the wiring diagram and pinout if that helps.
  3. Apr 4, 2021 at 10:44 AM
    thatguy2020
    It helps a lot thank you. I've looked for diagrams of it but have been having trouble finding one that's accurate.
  4. Apr 4, 2021 at 10:47 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They are from Mitchel and are redrawn so I can't say they 100% are right but they usually are.
  5. Apr 4, 2021 at 10:51 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’m pretty sure you can get a new switch from autozone or so.
    I broke the rod youre talking about a couple years ago and had to have @BartMaster1234 get me the whole key cylinder thing at a pick n pull.
    BartMaster1234 likes this.
  6. Apr 4, 2021 at 5:11 PM
    thatguy2020
    thanks Dm93 the diagrams where 100% accurate and I got everything figured out.
  7. Apr 4, 2021 at 5:17 PM
    thatguy2020
    I was going to get another ignition switch but none of the parts houses where I live have it in stock. I have to have the truck for work in the morning so I was just putting in the ignition panel for a temporary fix. ill get another lock assembly and ignition switch soon.
    JKO1998[QUOTED] likes this.
  8. Apr 4, 2021 at 5:20 PM
    JKO1998
    Utah
    I used a screw driver in the switch for a couple months, if it works it works haha
  9. Apr 4, 2021 at 5:29 PM
    thatguy2020
    That's true. My wife rode with me to the store a while back and she told me it was sketchy starting it with a screw driver. I told her the rod in there made it 21 years and 370,000 miles and I'm surprised its the first one that broke with how small it is.
  10. Apr 4, 2021 at 5:35 PM
    JKO1998
    Utah
    I went and go an alignment when mine was broke, the shop guys thought it was funny.
  11. Jun 21, 2022 at 1:02 PM
    Mr-J5150
    Mr-J5150 New Member
    I tried opening this diagram but it's not working I need tje diagram for the 8 pin ignition harness to repair a stolen recovery.
  12. Jun 21, 2022 at 1:07 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I just tried it and it works for me but here's a screenshot of the pinout.
  13. Jun 21, 2022 at 3:56 PM
    Mr-J5150
    Mr-J5150 New Member
    Thank you so much, I'm trying to instal a easy guard pushbutton start in my truck that was stollen and recovered. The 8pin harness was cut and so it's easy to connect but I'm not getting any reaction from the starter.
  14. Jun 23, 2022 at 4:45 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    They worked fine for me!
    All my online FSM`s died with the computer.
