Ignition coil browned - sign of a bigger problem?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco2022, Jul 5, 2020.
  1. Jul 5, 2020 at 10:07 AM
    Taco2022
    Taco2022 [OP] Well-Known Member
    2017 TRD Sport DCSB 4x4
    Bilstein 6112, SCS SR8, Grabber ATX 275/70/17
    Replacing the plugs in my '17 Sport - 65K mi. Everything went smoothly, but the center coil on the passenger side is brown/burnt. I see some browning up the ceramic of the plug vs being all white. The other 5 coils were clean and shiny. Is this just a poorly sealed plug, or might this be a sign of a bigger issue? Heading to pick up a replacement coil for peace of mind. Thanks in advance.
  2. Jul 5, 2020 at 10:29 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I have seen this posted recently here 2 other times. The other two had loose plugs. Was that plug tight?
    Junkhead, AmericanDrug and whatstcp like this.
  3. Jul 5, 2020 at 10:35 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Yeah loose plug or leak in valve cover gasket...should test the coil with a multimeter takes 2 seconds and not just replace it as nothing is better than oem.
    MannyS and Taco2022[OP] like this.
  4. Jul 5, 2020 at 10:40 AM
    Taco2022
    Thanks for the response... plug felt as tight as the others. New plugs torqued to 15 lbs so we'll see how things go.
    Junkhead likes this.
  5. Jul 5, 2020 at 11:20 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    From the look of that carbon ring on a couple of threads below the gasket, l would have expected it to be loose.
    trazerr likes this.
  6. Jul 5, 2020 at 11:22 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Maybe the buildup of carbon was what made it fit tight. Does look like it was loose with blowby at some point.
  7. Jul 5, 2020 at 9:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
  8. Sep 20, 2023 at 1:00 AM
    Nikvic
    Nikvic Well-Known Member
    Nikko
    Vancouver, B.C.
    2018 TRD Sport Crew Cab 4x4
    My #3 coil burned out as well. I heard something about the ACIS breaking and getting lodged in the #3 intake, and the shaft falling into the #3 intake/exhaust valve area. Basically transcribed that from a picture I took of the post, i barely know what it means, so take that with a grain of salt. Also read something about an over bored cylinder... i'll try and find a picture to post of that one
  9. Sep 20, 2023 at 1:01 AM
    Nikvic
    Nikko
    Vancouver, B.C.
  10. Dec 1, 2024 at 6:24 PM
    jw_714
    jw_714 New Member
    I experienced the exact same thing today, except it was the middle on both sides for mine. 2017 TRD Offroad 4x4. Anything ever result from your experience?
  11. Dec 1, 2024 at 8:13 PM
    stoney1911
    stoney1911 Professional Idiot
    Phoenix, AZ
    2019 TRD OR DCSB
    Same. I changed mine about a month ago and both my center coils were “browned”. Not as bad as OPs but the discoloration was there. Im in a 2019 TRD off-road 4x4.
