Ignition - Clutch Relay switch requiring more travel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jere, Oct 14, 2011.
  1. Oct 14, 2011 at 6:27 AM
    Jere
    Jere [OP] Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    I have a 2010 4cyl manual Tacoma with 20,000 miles on it. It seems that I have to mash the clutch into the floor, pushing the back of the pedal well into the carpet to defeat the relay for the ignition. I am convinced it is getting harder and harder to push the clutch pedal in far enough to trip the switch. I've crawled in on the floor with a flashlight, but can't seem to find the switch point to see if I can adjust it. The clutch itself is working fine, no problems with shifting at normal engage depth, it is just the switch that relays to the ignition.
    Anyone have problem with this switch requiring more and more depth? Anyone find an adjustment point. These are the kind of things I hate to take to a dealer.
    Thanks
  2. Oct 14, 2011 at 10:43 AM
    MajKong
    MajKong Well-Known Member
    Johnny
    Reno, NV
    2008 4X4 Access Cab 4cyl
    Seatbelt Buzzer turned off, Bed Mat, Illuminated 4X4 switch, Intermittent Wipers, Fumoto drain valve, LCE header, fog lights
    Move your seat forward!:D
  3. Oct 14, 2011 at 11:09 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I had to do some extensive searching to find this picture. The arrow points to the adjustment nut. Not sure how easy it is to access said adjuster but there is one up there. Just don't overdo it or you will be able to start without the clutch pushed in properly.
  4. Oct 15, 2011 at 3:34 AM
    Jere
    Adjusting the seat doesn't alter how far into the carpet I have to jam the pedal.
    Thanks for the diagram, that gives me a starting point. I'm not worried about a vehicle that can be started with the clutch not pushed in, that would make it like the vehicles I drove a couple million miles in before these safety devices were mandated into vehicles.
  5. Oct 15, 2011 at 3:40 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    That would also dissable your cruise control if overdone.
  6. Oct 15, 2011 at 9:46 AM
    NelsonTacoma
    Tucson, AZ
    Good call. :thumbsup:
  7. Oct 15, 2011 at 9:51 AM
    saugus
    saugus Well-Known Member
    I think that nut is there to hold the switch in place.
  8. Oct 15, 2011 at 9:54 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Do you have all weather mats on the floor? I know mine like to slide forward and its impossible to start my truck when it happens
    potterwatch_1 likes this.
  9. Oct 15, 2011 at 9:59 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    I have the same issue on my 2.7 Prerunner. I have the stock carpeted mats. I will look at mine using the diagram & not go too far adjusting the nut. Thanks for posting the digram
  10. Oct 15, 2011 at 11:35 AM
    NelsonTacoma
    Tucson, AZ
    Always happy to help out.
  11. Oct 15, 2011 at 11:37 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Also, I'd check to see if your tab on the pedal is bending..common problems on 1st Gen Taco's and 2nd Gen 4runners.
  12. Oct 15, 2011 at 9:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have the same issue with my 2009 company truck. It's also a Tacoma. I have looked under the dash and it does not appear that the switch is adjustable. I wrapped the plastic actuator that is part of the clutch pedal with duct tape to try and make it thicker and require less travel to push the switch. It's starting to need more travel again, I think the tape has compressed. It's irritating, and I have had my foot come up just enough to disengage the starter. Sometimes when I push it back down I will grind the starter.
    If you are comfortable defeating that safety switch, it should be easy to do.
  13. Oct 15, 2011 at 10:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe the cruise has a seperate switch that is pressed in with the clutch pedal in the up position. My truck will not start until the clutch is all the way down, but a very light pressure on the clutch will disengage the cruise.
  14. Oct 16, 2011 at 3:03 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    all you do is unplug the switch..lulz or tape the pin in..so contacts always touch.
    4x4 ftw..clutch start cancel ftw.
  15. Nov 7, 2011 at 9:08 AM
    xopher65
    xopher65 Active Member
    Whidbey Island, WA
    2009 2.7l 5-speed 5-lug reg cab 2WD
    I was having trouble with this too. Here's an alternate solution. The Clutch Start Switch energizes the Start Relay in the left engine compartment R/B just aft of the battery which allows +12 VDC to the starter motor. I removed that relay and jumpered pins 3 and 5 with a short wire with spade terminals. See the jumper in the picture. I should have taken a picture before relay removal. Anyway, this relay interlocks (disables) the starter +12 VDC from the ignition switch when the clutch is not fully depressed.
    Also, the ECU will still only get +12 VDC when the clutch is fully depressed with the ignition switch in the start position. I don't know what the ECU does with this signal. My truck starts fine with the clutch pedal up.
    This function is independent of the cruise control clutch switch.
  16. Nov 7, 2011 at 9:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why would you be against taking it to the dealership? You bought a new vehicle with a warranty, let them fix it before rigging it with duct tape. You paid for the warranty, no harm in using it.
  17. Nov 8, 2011 at 5:10 PM
    Jere
    For what it's worth, I found a rubber grommet with the right sized hole in the back side to make a boot for the switch. That extended the switch length by about ¼". Everything is working fine now.
    SAR Taco likes this.
  18. Nov 8, 2011 at 5:13 PM
    NelsonTacoma
    Tucson, AZ
    :thumbsup:
    Glad to hear you got it working.
  19. Nov 8, 2011 at 5:17 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Easy solution to disable, for both Gen 1 and 2 - pull the plug on the switch and short the contacts on the wire. Done.
    I simply took a loose "U" shaped, unused crimp terminal and slid it into the plug. Works perfectly. Now you don't need to press in your clutch to start the truck. I did this the first day I had both trucks.
    Jimmyh likes this.
  20. Nov 8, 2011 at 5:19 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Wonder what tinkering with it may have with getting it into 4 low.
