Igniter circuit issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pierce2006V64x4, Feb 3, 2024.
  1. Feb 3, 2024 at 12:49 AM
    Pierce2006V64x4
    Pierce2006V64x4 [OP] Member
    Pierce
    1996 Tacoma 3rz Regular Cab
    12 inch Subwoofer Aftermarket radio
    I have code p1300 which is reading igniter circuit error, I was wondering if anyone has a wiring diagram for that or the whole entire truck because i think the igniter is shorting out or its broken. its a 1996 2.7L 4x4, its causing my engine to lose all electricity while driving, i already replaced ignition coils, spark plugs, distributor cab and rotor, as well as new alternator, battery, battery terminals, fuses, clutch safety sensor, and cleaned battery/engine ground. Im wondering if that is all that it could be or if its fuel pump as well because it would make sense. also having trouble putting new fuel filter in.
  2. Feb 3, 2024 at 5:01 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Remember that is the complete circuit not just the igniter !!
    It might be as simple as a corroded connection or broken wires.
  3. Feb 3, 2024 at 7:13 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The P1300 sets when the PCM does not receive an Ignition Confirmation (IGF) Signal from the Igniter for 4 consecutive firing (IGT) events.
    It will go into limp mode/disable fuel injectors when this code is active.
    Bivouac likes this.
  4. Feb 3, 2024 at 7:39 AM
    Bivouac
    Thank you sir for the diagrams.
  5. Feb 3, 2024 at 8:58 AM
    Pierce2006V64x4
    Pierce
    thank you so much for the diagram i couldnt find them for the life of me
  6. Feb 7, 2024 at 6:35 PM
    Pierce2006V64x4
    Pierce
    welp couldn't find short and put new ignitor in but still cuts out, no check engine light, still so confused
