If you erase the "Check Engine" light will it come back on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trexTRD, Nov 21, 2014.
  1. Nov 21, 2014 at 1:15 PM
    trexTRD
    trexTRD [OP] Well-Known Member
    California
    Fox All Around, MaxTracs, Black & Red Leather Seats, Straight Pipe, and other crap...
    Yesterday we were doing a "Tune Up" for my truck which consisted of oil change and filter, spark plugs, and engine filter.
    -Plugs are OEM
    -Filter is FRAM Ultra Synthetic (ran it in previous oil changes)
    -Engine Oil: Royal Purple 5w30 (ran it in previous oil changes)
    -"Upgraded" K&N Filter
    Finishes everything up and the "Check Engine" light comes on. We checked everything by "looking" to make sure no hoses or such were disconnected. That didn't turn it off.
    We thought it may have been the "K&N Filter" maybe the engine is not use to how thin it is in comparison to the OEM filter, so we switched it out and in the process we noticed a Spark Plug connector was disconnected, most likely happen when putting the intake back together.
    Although that didn't turn it off either.
    Kinda got us thinking what could be the problem. So we removed each spark plug and made sure they were gaped to "0.44" and put them back on.
    And again that didnt turn it off.
    The engine seems to be running great and no awkward noises. So we used the Ultra Gauge to ignore the "Check Engine" light hoping the light will turn back on if indeed there was a problem "we had read, its suppose to come back on if there is a problem".
    The light has been ignored(turned off) and has not come back on yet. I've driven the truck about 30 miles since this happen and kinda has me thinking now, will the light actually turn back on if it was ignored????
    Thanks ahead of time :)
  2. Nov 21, 2014 at 1:44 PM
    MPLS TACO
    MPLS TACO Well-Known Member
    CHad
    MN
    TRD Sport
    3" Lift with UCA, Grillecraft grille, XD rims w/ 285/70r17 duratracs, leer xq cap,
    Could have been gas cap not tightened enough? Otherwise you are correct if there is a problem the light will come back on. If the light stays off its really hard to say what triggered it. I hope it stays off for ya
  3. Nov 21, 2014 at 1:45 PM
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    I would clear it and see if it comes back. I had an error come up on my Ranger and when I cleared it it never came back :notsure:
  4. Nov 21, 2014 at 1:46 PM
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    Wy didn't you check the code when you cleared it to see why it was throwing it
  5. Nov 21, 2014 at 1:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    AFAIK once the check engine light illuminates, you need to clear it from the OBD port. If it stays off then you're good to go (hopefully), if it comes back on after it's been cleared then the problem persists.
  6. Nov 21, 2014 at 6:53 PM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    If there's an issue, it'll come back on. I had one pop up on a Jetta I had, had it scanned and it was nothing. Cleared and didn't come back.
  7. Nov 21, 2014 at 7:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    If you had a poor connection on one of the plugs, you would definately get a "check engine" light. You reconnected it and cleared the codes. Now the engine is not recording a miss fire on the bad plug wire/cylinder. You are good to go. The light won't come back if nothing is amiss.
    I'm curious how you got the engine ECU to "ignore" the CEL? If you just disconnected the battery for a few minutes, that would work just fine.
    If you are going to continue working on youor own vehicle, a decent, cheap scanner will be a great purchase. I got to warn you, once you start learning how these tools work, you will want to continue to learn more and more about how our truck engines operate. It's kind of an addiction...at least for me it is.
    KO
    Edit:
    I didn't see that you have an Ultra gauge. That is a decent place to start. If you found a bad connection on one the wires, you could have "cleared" the code instead of "ignore". If you run with the UG connected all the time, you want the UG to record the code, ot ignore it.
  8. Nov 21, 2014 at 7:59 PM
    LegitGreenTaco
    LegitGreenTaco Photosynthesis.
    2002 Regular cab base A/C fixed now.
    Westin lights, Westin Light bar holder, New front bumper, Custom floor matts, Steering wheel cover, board in bed to keep groceries from rolling around, new radio, New flat bed cover.
    The gas in the vehicle could be of a low quality I know that has happened to me before.
  9. Nov 21, 2014 at 8:02 PM
    koditten
    Kirk
    Central Michigan
    Mostly correct, The truck CEL light will still come on but the UG has been told to ignore the issue. The truck can't tell you what code has been triggered, the UG can tell you the code number and then you can go to the internet and punch in that code number to learn all about what causes it.
  10. Nov 21, 2014 at 8:12 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    if it comes back on, read codes with your OBD reader and look them up or post on the forum, peeps around here have dealt with about every code ever thrown and can help you out real quick :)
  11. Nov 21, 2014 at 8:15 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    you learned any tricks in your exploration of software you can share? on one of my other vehicles i learned all kinds of lil' extra features that could be turned on with a programmer.
  12. Nov 21, 2014 at 8:21 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    was it a PENDING code?
    I know u can turn IGNORE PENDING codes with ultragauge
  13. Nov 21, 2014 at 8:26 PM
    koditten
    Kirk
    Central Michigan
    I'm pretty sure, he didn't note that if he was here asking questions. Thats fine, how are you going to learn without asking questions.
    KO
  14. Nov 21, 2014 at 8:41 PM
    koditten
    Kirk
    Central Michigan
    I don't have a lot of time right now, been awake since 3am, so getting ready to call it a noght.
    One of the best things that I can point a person who has interest is to go to Amazon and buy the TechStream softaware and cable. I think its around 35 buck now. This is the exact software that the dealers use. All I can say is OMG. The info and changes you can make to a Toyota vehicle is is awesome! You won't be able to change any engine parameters, but you will get access to all sorts of options that only the dealers can do. Example, turn the alarm on or off, adjust the key chime, turn off the seatbelt chime, make the windows roll down with the key (limited or up package), compression checks, light checks, gauge checks, fuel gauge calibrations, tranny temps. I'm going by memory here, been a while since I played with mine.
    You will need an old laptop that runs windows XP with a 32 bit OS, but there is a work around that allows you to run the software on a 64 bit operating system.
    I ahve to warn you, it took a while for me to get my TS program to function properly, it was quite clunky, but I attribute that to me not being very computer saavy.
    Later
    KO
  15. Nov 21, 2014 at 8:57 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    Yes, if there is an issue. I did a spark plug change, got a hesitation and bog from engine. Very randomly, I didn’t know what it was. Until 5-7k miles after it started doing more frequently and got very bad. I finally got a Check Engine Light, scanned with hand held scanner, and found a misfire on cylinder 4. Erased it and came back again after driving. I ended up buying a new Coil, still didn’t fix problem. I ended up pulling spark plug and replacing it. Fixed the issue right away. Faulty spark plug was gapped okay, nothing visually bad about it. I only buy Toyota OEM parts from dealer. I do got to say, it took awhile for check engine light to come on initially, even slight hesitation didn’t throw check engine light. It took some consistent misfire, crappy acceleration, it drove me nuts.
    Forgot to mention. I used a friends handheld reader, Actron I believe. I erased after I read it and came back on after driving again with misfire.
  16. Nov 21, 2014 at 9:26 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    What code was present?
  17. Nov 21, 2014 at 10:31 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    thanks bro! i will try to get one! as far as laptop setup, i have a few ready to use that i used on other vehicles and to program eeproms and atmels. gotta always keep a laptop or 2 around with xp and serial ports and even with 98 and serial ports :)
  18. Nov 22, 2014 at 8:44 AM
    Doomsday
    Cypress, TX
    I can't remember, scanner gave code and description.
  19. Nov 22, 2014 at 9:07 AM
    trexTRD
    California
    Thanks all of you for the feedback!
    The light has not come on, I would assume it had to come on already since I put 100 miles on it as of now, I was driving a lot yesterday and no weird noise, no smell, no signs of anything being wrong.
    My only concern was; What if there was actually something wrong and the light just wouldn't come on anymore because it was turned off. That's what has me thinking a bit, another thing is why wouldn't the light turn off by itself if I had fix the problem?
    I didn't drive it with the check engine light on so my other assumption was it was probably going to turn off by itself after I had driven around a couple miles????
  20. Nov 22, 2014 at 10:41 AM
    T4RFTMFW
    Doesn't turn itself off. Has to be reset to turn off once it's come on.
