If you don't prime your oil filters..........
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2pei, Feb 19, 2022.
  1. Feb 22, 2022 at 8:29 PM
    #161
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    I doubt Toyota prefills the oil filter when they change my Tacoma's oil. They always send the lot boy out to check the mileage again, that's become a running joke. It's on '04 with 66k miles -- no "1" in front.
    Now on my slant 6 prefilling the oil filter is not an option, it fits on the oil pump can side up. So you pop in a new filter and 5 quarts of oil into the warm engine and bump the key without touching the throttle so it starts up without the choke, idling at about 500 rpm in park. Then you stare at a big red oil pressure light and wait... and wait... you hear the rods start to knock and wait... the rods get pretty loud while you wait... the rods start to quiet down and you wait... then the oil pressure goes out and the engine is quiet. From their I slowly take the rpm up to around 3000 rpm and slowly let it back down to idle. Shut it down, check the filter for leaks and dipstick for level and call it done. It's normal for more than 100k miles. My Dad's old Plymouth with a slant 6 was the same way.
  2. Feb 23, 2022 at 1:45 AM
    #162
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I saw people bypassing the filter cartridge back on the old SBC 283. I don't know if they did it for performance or if they wanted to save the cost of a new filter. :eek:
    Abeyancer likes this.
  3. Feb 23, 2022 at 2:24 PM
    #163
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Performance. Gives you an extra 38hp.
  4. Feb 23, 2022 at 3:12 PM
    #164
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Dont think oil filters make a rats ass difference...
    best thing you can do for your engine ....is change that oil ....alot sooner than what they tell you...
    2K for 4 bangers.....and 3K for v6 ers.......
    Only change filter 4th or 5th change....cause the oil is always new.....
    I've got the routine down to less than 10min.....$10 in valvoline and $2 in a dash of lucas(6oz).......stubby racket is always on standby with a 14mm in it....right next to the two zerex catch pans......
    Only filters I use is K & N racing....and the Napa platinum's......these are built for 'High Bypass'....
  5. Feb 23, 2022 at 6:38 PM
    #165
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    This is why I drill and tap my Toyota YZZ-D1 filter each oil change so I can thread in a Fumoto valve and pre-fill the filter with fresh oil without any mess.
    Kracken65 and Abeyancer like this.
  6. Feb 23, 2022 at 10:35 PM
    #166
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Is this thread on track for record setting thread drift?
    2pei[OP] likes this.
  7. Feb 24, 2022 at 8:25 AM
    #167
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    ^ that's burnt to perfection there. Only needs a dollop of motor oil sauce.
  8. Feb 24, 2022 at 8:12 PM
    #168
    2pei
    2pei [OP] Well-Known Member
    Scott
    Oregon High Desert
    03 Tacoma
    mild lift, suspension & assorted badassery
    2K??? .....that's a little nutty but have fun. I do it every 5-7K, Dino oil and new filter
  9. Feb 24, 2022 at 9:03 PM
    #169
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    7k non-synth is like 15k synthetic... Yikes
  10. Feb 26, 2022 at 6:14 AM
    #170
    2pei
    Scott
    Oregon High Desert
    03 Tacoma
    340,000+ fun & trouble free miles
    Sharpish likes this.
  11. Feb 26, 2022 at 7:48 PM
    #171
    treyus30
    Trey
    Mesa / AJ, AZ
    Obviously due to the oil, nothing else
  12. Feb 26, 2022 at 8:51 PM
    #172
    O'Silver_Taco
    MD
    Yeah oil today is not same as oil from 60, 70 years ago.....
    In the old sae 30 days all the crap in oil would settle out in the pan and leave you with semi-clean oil circulating....
    Problem was everything horizon in the engine would also get this coating,,,,,,slime.....
    So todays detergent oils are suppose to keep all that crap in suspension.....
    do you really want all that crap flowing through you're bearings and passages for 1000's and 1000's of miles.....
    changing oil every 6 or 7K seems ludacris to me....especially when oil in 5qt's is so cheap these days.....
    And synthetic or conventional doesnt matter, problem is not the oil breaking down....its the crap that builds up in it over time......
    The crap comes from blow back and the case vapors reacting with materials at hundreds of degrees.......
    And the higher the mpg of the car, the weaker the rings, the greater the blow back.....especially at age.....
    CS_AR likes this.
  13. Feb 26, 2022 at 9:19 PM
    #173
    2pei
    Scott
    Oregon High Desert
    03 Tacoma
    well, you tel me...... oil is the most important part of engine maintenance. The old-skool 3000 mile oil change was/is a scam to sell more oil changes. 'Synthetic' oil conversions are also a scam
    My 03 Tacoma is original at a happy 340K with everything from the factory 'cept the starter, alternator, water pump and drive shaft & clutch
  14. Feb 26, 2022 at 9:20 PM
    #174
    2pei
    Scott
    Oregon High Desert
    03 Tacoma
    It's happily worked for me for 340,000+ miles. The 3000 mile oil change is a scam
  15. Feb 26, 2022 at 9:31 PM
    #175
    O'Silver_Taco
    MD
    After 3k your oil starts turning into a black syrup.....doesnt even look like oil....
    looks more like an ice cream topping.....
  16. Feb 26, 2022 at 9:34 PM
    #176
    2pei
    Scott
    Oregon High Desert
    03 Tacoma
    ........yea, no. You don't understand how oil works. That's ok
  17. Feb 26, 2022 at 9:36 PM
    #177
    svdude
    svdude Well-Known Member
    jonathan
    nice! I was a gunner/mechanic on the MH’s for about 10 years.
    FWIW: The oil in a piston engine is drawn from the sump, the filter will be filled before the sump even sees a loss of oil volume. Pre-filling the filter is a waste of time. :D
    04Pre_Runner likes this.
  18. Feb 26, 2022 at 9:45 PM
    #178
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Right. Complete marketing tool started by Jiffy Lube back when they started franchising there LOF outlets. Some manufacturers say 5k intervals some say 10k depending on the manufacturer and oil type. Jiffy lube knows there's a million suckers born every minute and built their billion dollar business model on this fact.
    2pei[QUOTED][OP] likes this.
  19. Feb 26, 2022 at 9:49 PM
    #179
    svdude
    jonathan
    Freedom is imaginary.
  20. Feb 26, 2022 at 9:49 PM
    #180
    O'Silver_Taco
    MD
    Yeah the manufacturers on new cars say you dont need a tranny dip stick...
    they say the trans fluid is for life............
    So it takes a $2000 machine to check level.......at a given temp....
