if you cut your exhaust before the muffler will it still pass smog?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoodratstormtroop, May 17, 2012.
  1. May 17, 2012 at 7:20 AM
    hoodratstormtroop
    hoodratstormtroop [OP] Well-Known Member
    santa cruz
    2006 4x4 tacoma TRD debadged
    GPS/dvd player in dash, tires, rims, window tint, tail lights, and sub.
    I wanted 2 cut my exhaust before the muffler so it does it show....will this pass smog? it will still have muffler and cad converter
  2. May 17, 2012 at 7:22 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    If you cut the exhaust before the muffler how is it still going to have one? Are you putting it back on?
  3. May 17, 2012 at 7:52 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Smog isn't the issue. The lack of the muffler being in the system and operating is.
    California Vehicle Code Section 27150, Adequate Muffler Required:
    (a) Every motor vehicle subject to registration shall at all times be equipped with an adequate muffler in constant operation and properly maintained to prevent any excessive or unusual noise, and no muffler or exhaust system shall be equipped with a cutout, bypass, or similar device.
    California Vehicle Code Section 27151, Modification of Exhaust Systems:
    (a) No person shall modify the exhaust system of a motor vehicle in a manner which will amplify or increase the noise emitted by the motor of the vehicle so that the vehicle is not in compliance with the provisions of Section 27150 or exceeds the noise limits established for the type of vehicle... No person shall operate a motor vehicle with an exhaust system so modified.
    EDIT: Based on the other vehicle modifications you show and list, it seems you are a fan of violating all sorts of vehicle code laws, so the above probably won't stop you from doing it even more.
  4. May 17, 2012 at 8:05 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    If you bought your truck then you should know better than that.
    If your parents bought the truck then dont go fucking up their truck.
    you will look back and be glad you didnt do this "mod".
  5. May 17, 2012 at 8:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  6. May 17, 2012 at 9:32 AM
    oldstick
    oldstick Medicare Member
    GA
    Yeah, he would definitely attract a lot of attention (especially the cops) with that mod...:D
    But I assume he meant to change or reroute the tailpipe and muffler??
  7. May 17, 2012 at 10:05 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    OP, after cutting off the muffler, do you intend to weld on a downward-facing nozzle? If not, the hot exhaust gases will be aimed at the frame and floorpan. The exhaust is typically cut aft of the rear axle so it fires downward.
  8. May 17, 2012 at 10:10 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    All your hats have a flat bill don't they?
  9. May 17, 2012 at 10:31 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    meh, I have flat bills and I am in no way a bro .
    But im catching what your throwing ;)
  10. May 17, 2012 at 10:32 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    On newer vehicles they don't even put a probe in the tail pipe. They plug in to your computer. So.......No this will not help.
  11. May 17, 2012 at 10:37 AM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    So you are really wondering if leaving the muffler on the truck but not actually functioning as part of the exhaust system will allow you to pass an emissions test? Just throw the muffler in the bed and let them know you still have it and you should be good.
  12. May 17, 2012 at 10:42 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Op, yes, it will be fine, cut your shit up ASAP! It will sound like a beast, bro!
  13. May 17, 2012 at 11:05 AM
    KenLyns
    Belly of the Beast
    Does the test technician do just an emission test, or does he check other items for compliance (lights working, etc.)?
  14. May 17, 2012 at 11:13 AM
    aznutx
    aznutx Well-Known Member
    DFW Texas
    2011 White TRD
    that OP didnt make any sense, but im guessing he means... to cut it off after the muffler, or before it , if you were looking from the back end. , and if that's the case, i dont see why it wouldnt pass, but you would get some sooty crap after a while underneath ur bed.
  15. May 17, 2012 at 11:15 AM
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Okay, I can see how that might be pieced together. Thus showing why grammar and punctuation are necessary.
  16. May 17, 2012 at 11:50 AM
    Maticuno
    2011 Suburban 2500
    Since this thread is heading south rather quickly, I'll just add this for the OP:
  17. May 17, 2012 at 11:58 AM
    DrewH
    DrewH Well-Known Member
    I assume you mean you want to dump it over the axle after the muffler and yes you can and it shouldn't affect any testing.
  18. May 17, 2012 at 3:45 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Sounds to me like he is referring to the muffler tip. If that's the case, yes, you can cut off as much as you want as long as you don't cut out the actual muffler (OP, crawl under the truck, you'll see it...). I'd recommend cutting it so it turns down away from the cab.
  19. May 18, 2012 at 3:58 AM
    hoodratstormtroop
    santa cruz
    i wanted 2 cut the pipe right before the spare wheel, since i do not want it showing! also, i wanted 2 get a tip facing down so it does not burn a hole threw the spare....
  20. May 18, 2012 at 3:59 AM
    hoodratstormtroop
    santa cruz
    well i would still have the muffler....just cut it before the spare tire.....i just want it 2 be hidden, since its all rusty and looks like shiiiieeeettttt
