If I fill my truck up with non-ethanol fuel..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aficianado, Dec 18, 2019.
  1. Dec 18, 2019 at 6:41 AM
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    What happens?
    better mpg? More pep? Nothing?
    I need to run out some more fuel, but I found a station selling 87 octane non-eth. Curious to try it, since it is not an option back home.
  2. Dec 18, 2019 at 6:44 AM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I ran a tank through our 2014 Highlander while driving cross country a few months ago. Didn't notice any differences at all in power, smoothness or MPG.
    Lester Lugnut likes this.
  3. Dec 18, 2019 at 6:49 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Nothing happens cept it cost more. I’ve tried a couple of tanks noticed no difference.
  4. Dec 18, 2019 at 8:10 AM
    96carboard
    96carboard Well-Known Member
    Technically, ethyl alcohol has about 90% of the energy of octane, so 10% alcohol means that you lose 1% fuel efficiency.
    Fact is that the "other" differences in winter gas will account for a much more significant difference in efficiency.
    If you want to do a test, make sure that you unplug your battery for an hour after your SECOND fill-up, then run about 10 tanks through it for the system to calibrate, then start measuring.
    cruxofthebisquit likes this.
  5. Dec 18, 2019 at 8:19 AM
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    I have a '06 Matrix as my daily driver. When ethanol mix gas came out, my hwy mpg dropped from 34 to 30mpg
    Norton and cruxofthebisquit like this.
  6. Dec 18, 2019 at 8:21 AM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    Gasoline has a higher energy density than ethanol and does not absorb water (can be stored for much longer).
    Norton, bigmw and revtune like this.
  7. Dec 18, 2019 at 11:36 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    The New York Times stated that E10 gasoline actually gives you 2-3 miles per gallon less than pure gasoline (ethanol free).
    In my Tacoma that is exactly what I found on long round trip FL to AK and when in Canada with ethanol free (pure gasoline) my mpg went up 2 mpg so from 20 to 22 or a 10% increase. Isn't it interesting that 10% ethanol decreases your mpg 10%. And yes ethanol does not trap water so is more corrosive. Methanol or what's in dry gas traps or encapsulates the water in gas and then it gets burned in combustion. But as I only use ethanol free in my boat and see the price all the time, the increased cost of it is not cost effective over E10 price wise in vehicles (about $0.60 higher or 25% more here).
    Why then were we forced to use it - look at who profited from the corn planting and rise in prices as corn starch is also in many food products - pure greed and stupidity again hey that's a shocker.
    Norton, bigmw and Too Stroked like this.
  8. Dec 18, 2019 at 11:41 AM
    Nachomama2001
    Nachomama2001 Well-Known Member
    South Carolina
    2013 Tacoma TRD OR prerunner
    Bilstein 6112+5160s Air pump delete-Hewitt Technology Rear view mirror switch Hawk pads G2 BAK flip Roadmaster active suspension Seat lifters HVAC AJT knobs
    Ethanol is a government mandated fart. If it was up to the free market that sheet would be gone.
    Norton, bigmw, TacomaMike37 and 3 others like this.
  9. Dec 18, 2019 at 11:52 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    In my experiences, minor MPG improvements have been observed however not enough gain to offset the 10-15% higher cost at the pump.
  10. Dec 18, 2019 at 12:35 PM
    Nachomama2001
    South Carolina
    It’s more expensive because it’s not subsidized. It’s better for plastics and isn’t hydroscopic.
    I don’t buy corn gas
    Norton and bigmw like this.
  11. Dec 18, 2019 at 1:06 PM
    Jw88
    Jw88 Well-Known Member
    NC
    2014 Black TRDOR DCSB
    Bought it
    I too have increased mileage by using Ethanol free gas, as others have said. But like others have said as well, the cost of it outweigh the benefits, IMO for daily driving anyways.
  12. Dec 18, 2019 at 1:36 PM
    SteveNC
    SteveNC Well-Known Member
    Charlotte, NC
    01 Tacoma 4x4 2.7l
    It might get better MPG, but you will need to calculate your cost per MPG to see if it is worth it. If you don’t drive your truck often using corn free is probably better since it wont attract moisture.
    I had a Ford Ranger 3.0 V6 which would run flex fuel. When running E85 (mostly corn fuel) the exhaust smelled like a dryer vent. It didn’t knock under load (typical for that truck) due to the higher octane but it was gutless. Trying to tow the boat or going up a hill it felt like a four banger. Gas mileage was typically around 14 mpg with corn gas and closer to 19 with cheap real gas. I didn’t do any unplugging of the computer between tanks. However that year I tested several different fuel grades and found that even when E85 was less expensive during Obamas first term, the lower cost per gallon always resulted in a higher cost per mile driven. That Ranger got the best MPG on Super Unleaded but it got the best cost per mile with mid grade gas.
    As far as Ethanol free fuel that is all I ever run in my ’83 RX-7 (Wankel Rotary with 4bbl carb). I also tend to put Ethanol free in my RV when I put it away for the year. The Yoda gets cheap regular gas but once got racing fuel when Charlotte NC ran out of gas after Katrina and my Baja gets super because of the turbo.
    bigmw likes this.
  13. Dec 18, 2019 at 1:40 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It makes a 10% diff. in MPG for me. Not that it's worth the money though because it sure is more than 10% more expensive.
  14. Dec 18, 2019 at 5:03 PM
    Lthompson
    Lthompson Well-Known Member
    ethanal free is all I use in anything I have.
  15. Dec 18, 2019 at 5:29 PM
    brac2015
    brac2015 Well-Known Member
    Dan
    Victoria BC
    Barcelona Red 2015
    grrck likes this.
  16. Dec 18, 2019 at 5:57 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    That was such a fantastic car. Before they got greedy for HP.
  17. Dec 18, 2019 at 6:54 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    At one time I had 3 different rotary engine vehicles. A 1973 RX 3 station wagon, a 1974 RX4 station wagon and a 1977 Rotary Truck.Image19.jpg
    Looking back, wish I had kept them, and had purchased the Cosmo, that I only dreamed of owning
    And yes, you will get better MPG with non-ethanol fuel.
    grrck likes this.
  18. Dec 18, 2019 at 7:00 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I ran ethanol free for years (it’s the only gas available where I lived) and noticed no change when I moved and started using 10% ethanol.
  19. Dec 18, 2019 at 7:34 PM
    brac2015
    Dan
    Victoria BC
    Barcelona Red 2015
    Nice, I've had an r100 , 2- rx2s and a gsl=se... not much ethanol up here.
  20. Dec 19, 2019 at 7:11 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I haven't ran E10 in my tacoma much although I live in Iowa, ethanol heart of the country. I did notice in my 2011 F150 Flexfuel that I lost about 5-6 mpg running E85. The price had to be $.50 or more cheaper than regular for it be worth it, also noticed less power and longer warm up times. I ran probably 8 tanks through it, so it had plenty of time to "learn". I noticed about 1 mpg difference between E10 and Regular though for what thats worth.
    In my Tacoma I haven't noticed a notable difference in MPG between E10 and Regular. I do prefer to run straight gas though as I have seen Ethanol levels vary quite drastically in both E10 and E85. In fact there have been a few highly modified street cars in my area that have blown up because of a "bad" batch of E85. Some have measured as low as E60 when they blew up their engine. They tried to get money out of the gas station but none have won that battle. I have also seen E10 be as high as E30. So for me, I just don't trust the fuel mixologists.
