idle speed for 2.7
Discussion in '2nd Gen. Tacomas (2005-2015)' started by allwaysbroken5, Apr 27, 2023.
  1. Apr 27, 2023 at 8:41 AM
    allwaysbroken5
    allwaysbroken5 [OP] Well-Known Member
    jerry
    2010 Tacoma 2.7 manual
    none
    anyone know what the idle speed for the 2.7 is? I can't find it in my haynes book, and does the ECM control that?
  2. Apr 27, 2023 at 9:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Mines about 640-660 with the AC off
    clifpaul likes this.
  3. Apr 27, 2023 at 9:56 AM
    clifpaul
    clifpaul Well-Known Member
    North Texas
    06 access cab 5 lug
    Too many to fit here now!
    Mine idles about the same.
    BassAckwards[QUOTED] likes this.
  4. Apr 27, 2023 at 9:59 AM
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    Same as above. Cold starts around 1400 RPM, drops to 1000 after 30 seconds then settles in at 650.
    SilverBulletII likes this.
  5. Apr 27, 2023 at 11:14 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    600-700 RPM at operating temp in park/neutral, it will be slightly lower in gear and slightly higher with the A/C on.
    PCM controls idle speed based on coolant temp, electrical load, whether or not the A/C is on, and if the transmission is in gear or not.
    Are you having an issue or why do you ask?
    TnShooter likes this.
  6. Apr 27, 2023 at 12:00 PM
    Avotaco
    Avotaco Active Member
    Eric
    Jersey
    94 PU 4x4 4cyl MT reg cab, 06 Taco 4x4 4cyl MT Acc Cab
    ^this
  7. Apr 27, 2023 at 1:25 PM
    allwaysbroken5
    jerry
    none
    thank you all this place is better then any book! :thumbsup:
  8. Apr 27, 2023 at 3:13 PM
    allwaysbroken5
    jerry
    none
    DM93 I was having the oil light come on for a bit, I think the ECM is just relearning things. the RPMS drop down low and it come on. I don't think it's a issue
    also you were right about my oil control valve being stuck, got that p0012 and then I got a p0011 so I taped on it and it came back to life so it was sticking good call
