Idle Air Control (IAC) Valve - Is OEM worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ronnie1, Aug 23, 2023.
  1. Aug 23, 2023 at 12:06 PM
    Ronnie1
    Ronnie1 [OP] New Member
    2001 Tacoma 2.4L Manual
    I'm going to be checking my IAC valve which I suspect needs to be replaced. It seems I can get an OEM part for around $260, which is about double what one of the better parts on Rockauto runs. Anybody have any advice/experience using an aftermarket IAC valve?
  2. Aug 23, 2023 at 12:20 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    It's a roll of the dice. If you replace it with a non OEM part, and it doesn't fix your issue, what are you gonna do?
    Bivouac likes this.
  3. Aug 23, 2023 at 12:58 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I would bite the bullet and just buy one from Mcgeorge.....
    there was a thread here couple years ago where someone took these apart....
    the real oem one had this big ass spring inside it controlling it...
    the knockoff just used a plastic bushing in place of that...thats why so cheap....
    Your Source for Genuine Toyota Online Parts | McGeorge Toyota Parts
  4. Aug 23, 2023 at 1:12 PM
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Turn all accesories off. Start truck cold, after sitting for a few hours, idle should be near 1500-1800 rpm. Should slowly come down to around 1000 rpm. In drive should be about 750. If it does, i.a.c. is working normally. If you clean the throttle plates, it may idle higher then normal till it re-learns its base idle. I like factory parts, but have been bying aftermarket parts for my own car. Customers cars, i push for factory or higher quality parts.
  5. Aug 23, 2023 at 4:02 PM
    Ronnie1
    Thanks for the advice. This makes me feel better about spending an extra $100+ for the OEM part.
