Identifying Different Hoses (and related questions)
Discussion in '1st Gen. Tacomas (1995-2004)' started by dalibran, Dec 20, 2022.
  1. Dec 20, 2022 at 11:43 AM
    dalibran
    dalibran [OP] Member
    1999 Beige Tacoma SR5
    Hi all! I'm restoring a 1999 2.4l Tacoma, and I have some questions related to hoses. I received a p0402 (excessive EGR flow) error, and while I haven't identified the exact cause, I am definitely going to replace all hoses since they are old and cracked. That being said, there are a bunch of hoses that I haven't been able to identify, and I'm not sure if I can replace them using vacuum hose.
    Here is an image of the hood, I've marked the hoses that I need help identifying. I was able to make sense of the vacuum hose diagram on the hood, and I feel good about replacing all of those. Just not sure if I can use the same vacuum hose I ordered on the other ones.
    Some other general questions...
    1. Any tips on the EGR valve excessive flow issue? Watched a bunch of YT vids and have some good areas to investigate, curious if there are any super obvious places I should look.
    2. Any tips on cleaning under the hood? Not sure if spraying the engine components and other stuff with soap and water would be harmful.
    Thanks for the help!
  2. Dec 20, 2022 at 1:23 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    TForan and Andy01DblCabTacoma like this.
  3. Dec 20, 2022 at 2:55 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don’t clean anything in the engine bay unless I have to work on it. And then, I only clean what’s necessary.
    Your truck is 23 years old.
    The seal packs for the electrical connectors are probably aged and aren’t fitting as tight.
    I wouldn’t risk getting any degreasers or cleaners down in the connectors. Some of the cleaners are harsh. You’ll grow green crusties pretty quick if you don’t get it off copper terminals.
    dalibran[OP] likes this.
  4. Dec 20, 2022 at 3:30 PM
    dalibran
    Everything is definitely falling apart, but fortunately I've already completed the higher priority mechanical repairs so the truck runs great. Lots of parts are dirty and the engine leaked a bunch of oil previously which is still on the lower parts of the engine case.
    Focusing on electrical connectors and hoses at the moment, although I will need to dig into the EGR valve a bit more deeply. This guy on YT took off his intake manifold to clean and get at some of the EGR valve parts...tempted to do this myself.
    TnShooter[QUOTED] likes this.
  5. Dec 20, 2022 at 3:44 PM
    dalibran
    This annotated image was extremely helpful, thank you! I will look into getting the crank case breather hose and PCV hose, and I'll use whatever leftover 3mm and 4mm hoses for the other ones you pointed out. Will prob need something bigger than 3 + 4mm for the EVAP emissions vent.
    Based on what you said though, I'm curious if I need a custom hose for part #23826. I replaced everything in the attached diagram with universal hose, and the originals seem to be shaped a certain way which makes me think I might need a custom part.
    I also attached an image of my engine bay that shows the hoses I replaced that I'm not sure if I need something custom. I'm also curious about the hose I outlined in purple, forgot to ask about that one in an earlier pic.
  6. Dec 20, 2022 at 5:29 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    I did my 96 2.7L back in the fall. Sprayed if off at the car wash, used degreaser etc. Have done several older vehicles the same way but all were well warmed up and then driven a few miles back home. Ordered the shop kit from siliconeintakes.com. Most of the sizes worked and I had plenty left over. Regular rubber is fine as long as it seals, in my opinion. Then used Mothers back to black on everything else in there, plastic & rubber. Also check that PCV valve grommet. That was one of the last things I checked and found it wasn't sealing well, could hear it at RPM. Was hard (26 years old) and had to carefully chip/break it out with small needle nose pliers. Most of this info gleaned here from other's posts after some searches. Just put some spiker engineering hood struts on last month. Those are awesome too, just like others here said. Good luck with your truck.
    The hose circled in your pic in purple is the brake booster hose.
    dalibran[OP] and TForan like this.
  7. Dec 20, 2022 at 6:42 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    You dont need special hoses any except for the pcv vent hose....that one needs to be fuel resistant....
    LuckyFin_007 and dalibran[OP] like this.
  8. Dec 20, 2022 at 7:00 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  9. Dec 20, 2022 at 7:18 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    P0402 instructions attached
    dalibran[OP] and TnShooter like this.
  10. Dec 22, 2022 at 12:59 PM
    dalibran
    Thanks again everyone for your new replies! My knowledge of these different hoses as grown a ton, and I feel much more confident making the necessary moves. Here is an update showing the hoses I've swapped out so far, I've been using 3mm, 4mm, and 8mm hose. Need to buy some more 8mm so I can swap out the EVAP emissions vent hose.
    I'll check out the instructions regarding the p0402 error, but I've also seen some potential sources for the problem being the EGR vacuum modulator and/or the vacuum switch under the intake manifold. Those replacement parts were cheap on Amazon, so I'm going to see if one of those fix the problem. There are a couple of other hoses related to the EGR valve that go behind the intake manifold that I can't reach easily, so I'm assuming that I won't be able to get at those until I take off the intake manifold.
  11. Dec 22, 2022 at 1:04 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    I had a dealer pressure wash my 99 Taco, it screwed up the cruise control and the auto locks. I did not ask them to clean under the hood, they just did it...
  12. Dec 22, 2022 at 1:09 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I clean my engine bay often. I just take care not to aim squarely at wire harness connectors, the fuse block, or the battery. Otherwise, everything gets a rinse and has since the first car wash.
    Before I replaced my valve cover gaskets, I had oil all over the sides of the block, and everything below that. I sprayed some foaming degreaser in these areas and agitated them with a medium size brush getting every surface I could. Rinsed well after that. No issues.
  13. Dec 22, 2022 at 2:13 PM
    O'Silver_Taco
    MD
  14. Dec 22, 2022 at 2:15 PM
    O'Silver_Taco
    MD
    As far as washing engine.....an engine will run just fine dirty.....
    However when you get water into the engine sensor connectors....
    you know the 25yr old ones.....
    nothing good can ever come of that......
  15. Dec 22, 2022 at 2:34 PM
    O'Silver_Taco
    MD
    There's a bunch of vids on tactics to clean engine bays.....
    In keeping mine clean....there is a number of things I've caught.....few natural failures.....
    but mostly things I didnt do right first time....
    caught em before the walk of shame.......
    And if I get caught in the rain......I always make sure to wash under carriage down at work before the weeks out....
    I worked too hard getting all that cleaned and painted......
  16. Dec 22, 2022 at 2:45 PM
    O'Silver_Taco
    MD
    JustADriver likes this.
  17. Dec 29, 2022 at 11:57 AM
    dalibran
    So I've swapped out most of the main ones, but I'm not sure how to proceed with the PCV hose. Toyota doesn't make this OEM hose anymore, and it seems to have 2 different size ports to fit on. The PCV valve looks to be about 8mm and the port connecting to the intake manifold seems to be a couple mm bigger.
    Can anyone provide insight into what size I should get? I saw that some people added a custom hose for this one, so curious if you remember how you did it.
  18. Dec 29, 2022 at 12:06 PM
    O'Silver_Taco
    MD
    I have a 98 and I think I used 5/16 clear blue snowmoble fuel line.....its whatever the largest they sell.....
    .....I think it was like $9 for a ten foot roll......
    It works fine.....the intake nipple is tiny bit larger....
  19. Dec 29, 2022 at 12:15 PM
    O'Silver_Taco
    MD
  20. Dec 29, 2022 at 1:08 PM
    dalibran
    Thanks this was helpful! Was unsure if the 5/16 would be too small for the intake nipple but fortunately it doesn't seem so. Also, I zoomed in on your photo and I don't think I even have a grommet on my PCV value. I have no idea what happened to it but whatever it was probably happened before I became the owner.
