Ideas on making lumbar support better
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrshaw91450, May 4, 2021.
  1. May 4, 2021 at 11:28 PM
    jrshaw91450
    jrshaw91450 [OP] Well-Known Member
    Maui
    2019 Cement Tacoma TRD OR 4x4
    TRD Cat back & Skid plate
    I have a 2019 and deal with lower back pain. A more exaggerated lumbar support would be grate but curious on any ideas TW may have to make seat a bit more comfortable. I have no complaint about the seats, just would like to customize it to my busted up lower back.
  2. May 4, 2021 at 11:33 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do your seats not have the lumbar knob?
    There's some high quality inflatable lumbar supports that the Auto-X-ers use from the Lotus cars. Dunno the brand but search for those.
  3. May 4, 2021 at 11:56 PM
    Ncska21
    Ncska21 Well-Known Member
    Nils
    New England
    17 Pro
    subbed, laying in bed with lots of back pain
    Aqualoon and Tacoma559 like this.
  4. May 5, 2021 at 6:17 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Not sure what aftermarket options are available as far as seats go. Our seats are kind of small but as a 6'1" driver, I find them ok, even with somewhat of a back issue myself. You can check on lumbar support pillows of various designs,(google) but will need a thin one, as a thicker one may push you too far forward. Some are designed specifically for car seats, but they can be hit or miss.
    When I was in practice, I had patients design their own, via a rolled up towel and duct tape, to place in the lumbar region. (Duct tape to keep the towel rolled up, not secured to the backrest) This way, one can adjust the size of the rolled towel to fit the seat and roll it to the thickness they needed, then place it along the back where needed. Not the prettiest design but effective. My taller patients often would turn their lumbar support pillows upside down to get the support in the right spot. Our seats are concave, so some lumbar supports are too wide to fit properly.
    Not sure if that helps any, but swing by a chiropractors office, or maybe a physical therapy office, as most sell them and probably have them in stock. Maybe try making something for yourself first, to see if it makes sense for you.
  5. May 5, 2021 at 8:17 AM
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    I’ve had 3 back surgeries I did the front seat jackers and I find my seat is much more forgiving on my back now. It puts me in a kind of leaned back position but not uncomfortable. I’m 6ft and I also have a sun roof and my head room is also much better with the front seat jackers.
  6. May 5, 2021 at 8:22 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    I have no input on lumbar additions but I'd recommend you check out the front seat risers if you don't already have them. Getting your legs more underneath you in a typical seated position helps relieve back strain.
    Note: Just to be clear I am not talking about the seat spacers that attach to the REAR supports of the front seat. I'm talking about the front attach point spacers for the front seats.
  7. May 5, 2021 at 9:05 AM
    jrshaw91450
    Maui
    Thanks TW. This is all good stuff. I will try all of it and see what works. I don't have the seat spacers yet so I will look into it along with some rolled towels.
    Gen3TacomaOBX likes this.
  8. May 5, 2021 at 9:11 AM
    Tacoma559
    Tacoma559 Well-Known Member
    2020 Tacoma dcsb 4 cylinder
    6’3 in a 2020 dcsb
    grab an extra shirt or sweater and roll it up and place behind back.
    usually starts to get agitating after 1 hour long drives.
  9. May 5, 2021 at 9:22 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Obusforme. Using it now and for the last 11 years in the truck A51345E0-EFCB-485C-9048-5EF48CBC8CC5.jpg
    kahanabob likes this.
  10. May 5, 2021 at 10:10 AM
    Ncska21
    Nils
    New England
    17 Pro
  11. May 5, 2021 at 10:27 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    there was a thread on pulling a plate out of the seat that is part of the headrest retract system to improve comfort
  12. May 5, 2021 at 10:37 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
  13. May 5, 2021 at 10:48 AM
    Ncska21
    Nils
    New England
    17 Pro
    In that case I'm excited. Never even thought about putting an amp there, sounds like I have myself a new project. Does it work well for integrating with harness or are you doing pretty aftermarket/sub stuff?
  14. May 5, 2021 at 10:50 AM
    MadKatt
  15. May 5, 2021 at 10:56 AM
    B1gDaddyT
    B1gDaddyT Well-Known Member
    2019 Cement Taco TRD OR 4x4 DCSB
    MadKatt[QUOTED] likes this.
  16. May 5, 2021 at 1:26 PM
    Mike402
    Palm Springs, CA
    OP, apologies for this tangent off your thread, but here is what I did:
    First time ever installing car audio equipment, so I wanted a relatively easy plug n play solution, and wanted to keep the 2020 factory head unit and existing speaker wire.
    I went with this adapter (also plugged into the anytime backup camera harness) https://www.amazon.com/dp/B087Z1794K?ref=ppx_pop_mob_b_asin_title
    Went with Kicker front & rears, and subaru tweeter. JL audio stealthbox, all powered by this audiocontrol amp https://www.crutchfield.com/S-6OAUM7ONE4G/p_161LC51300/AudioControl-LC-5-1300.html, mounted to a TT amp rack.
    The nice thing is that amp has accubass, which corrects the factory bass roll off. It sends 500 watts to the JL, and that thing bumps a LOT harder than I was expecting for a single 10.
    I'm thrilled with how it turned out. You will definitely need the spacers to fit the amp underneath the driver's seat.
    I can't say for sure it helps with back support, as I wasn't having issues with the factory setup to begin with.
    jrshaw91450[OP] likes this.
  17. May 5, 2021 at 2:38 PM
    Ncska21
    Nils
    New England
    17 Pro
    Awesome thanks for sharing. Sorry OP I realize this was a tangent. Hopefully a few of us like music and have back problems!
    I have done minimal car audio so this is similar to the route I'd take.
  18. May 5, 2021 at 3:32 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
  19. May 5, 2021 at 5:33 PM
    Unresolved Taco Issues
    Unresolved Taco Issues Well-Known Member
    Jeff
    FINALLY off the island!
    2020 Gray Tacoma Access Cab
    This is what I've been using for many years. Pricey, but sometimes you get lucky if you search thrift stores(they are sometimes a 'free' gift with purchases of their mattresses). I bought mine for $5 at a neighbor's garage sale(still in the unopened box!).
    https://www.tempurpedic.com/other-products/lumbar-support-cushion-travel/
    The travel size fits nicely in the driver's seat and the gel- or whatever it is?- molds to my back. However, be careful if you leave your truck outside in the winter. Mine froze solid and a small piece broke off!
  20. May 5, 2021 at 10:18 PM
    jrshaw91450
    Maui
    No worries. Like to hear all the ideas and tangents keep it fun.
    Ncska21[QUOTED] likes this.
