Icon Stage 4 Sweet looks Ehhh performance
Discussion in 'ICON Vehicle Dynamics' started by RDtres, May 24, 2012.
  1. May 24, 2012 at 2:07 PM
    RDtres
    RDtres [OP] Well-Known Member
    Albuquerque
    2012 Tacoma DC LB
    Hey guys, I just installed a stage 4 2.5 lift from Icon on my 2012 Taco DBC LB 4x4, new wheels (TRD's) and new rubber (BFG TKO's). And I'm pleased aesthetically but not nearly as comfy as I had hoped. $4k for suspension lift should feel smooth on the street, certainly NOT rougher than stock. I'm hoping putting some miles on the truck will soften up the springs a lot. It rides stiff, particularly over speed bumps with a hop from the front. Also, when I come to a stop the truck seems to rock back and forth slightly. Any advice or experience out there? Thank you
  2. May 24, 2012 at 2:09 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Have you tried them in the dirt yet? Hate to see you spend $4K of street suspension haha
  3. May 24, 2012 at 2:10 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Most aftermarket suspensions are stiffer than stock... The Icon Stage 4 kit isn't made to run the street, it's made to take hit hits off road which is where it shines over stock. I hate to say it but if you never leave the pavement, you needlessly spend way more than you needed to for a lift...
    Also, what load range are your tires? If they are D or E, that could be part of your problem.
  4. May 24, 2012 at 2:12 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    OP one thing you can do to alleviate it being rough on the street is to get soft springs. I think Icons come with 650lb springs for 2nd Gens, but you can go as low as 500lb springs. Just a thought
  5. May 24, 2012 at 2:15 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Plus it takes them some time to break in. Ive heard that with almost every shock
    Available the first couple days are terrible. Go do some
    Quick runs in the mud and get that suspension working, that's the best thing for them. Dakars and expo leaf packs are noticeably different after a few runs through the dirt.
  6. May 24, 2012 at 2:28 PM
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    Streets are not what lift kits are meant for.
  7. May 24, 2012 at 2:33 PM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    have you checked your tire pressure? if they are over inflated it would feel that way over a speed bump. how far are your icons cranked up?
  8. May 24, 2012 at 2:57 PM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Thank you all for the information. I agree Stage 4 should shine off road (fingers crossed), but heck it should also shine on-road also. Reality is most driving is on pavement, but I went with Icon because they claimed to be the most comfortable daily use lift. If the setup was truley progressive, speedbumps shouldn't feel worse than stock, extra travel should equal extra comfy
    Black Hawk, thx for the info on coil rates. If this doesn't get better I'll def be reaching out to Icon for different rate springs.
    Yes, my tires are BFG TA KO 285/75/16 E rated and running currently at 35psi. This may play a role. I plan to run a chaulk test and find optimal street psi.
    Ben, I agree with you as I'll be heading to the desert this weekend to rub some dirt on the setup and hope it finds a happy place.
    All in all this setup just makes me want a dual rate instead :/ and so far no bueno
  9. May 24, 2012 at 2:59 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    speed bumps make me feel like my truck is falling apart
  10. May 24, 2012 at 3:01 PM
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    lol i love the noises that come with it
  11. May 24, 2012 at 3:04 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Thats a good chunk of change! That sucker better start riding better!
  12. May 24, 2012 at 3:06 PM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Exactly my point FireFighter!
  13. May 24, 2012 at 3:07 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Also, how far down have you cranked those springs?
  14. May 24, 2012 at 3:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    500# springs would give less lift than stock. To get height, you need to increase spring rate, or preload. This equals a more firm ride. Taking out some of the low speed dampening can give a better street ride.
  15. May 24, 2012 at 3:12 PM
    RDtres
    Albuquerque
    2012 Tacoma DC LB
    Rears we're supposed to lift 1.5" and front's were supposed to come 2.0 lift from the factory. After measuring level, I cranked the fronts 10 full turns each. They seam to sit half way on the threads overall. This left me with .5 in higher in the rear to compenste for light loads in the bed or additional passengers.
  16. May 24, 2012 at 3:12 PM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
    sub'd. Just bought icons. Hope I won't be disappointed.
  17. May 24, 2012 at 3:13 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    we're not gonna crank pre-load with the 500lbs, gonna have her ride stink bug; face down - ass up :D
    reduce nitro psi could help a little too
  18. May 24, 2012 at 3:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What are your before lift measurments? Mine came set at 3" lift from the factory. I'd bet you gave them too much preload, which is why the ride is unacceptable.
  19. May 24, 2012 at 3:19 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Crank some presure off the springs, lower the lift and add a 1/2 top plate with longer bolts. Thats what i did and the front is softer then what i had before.
  20. May 24, 2012 at 3:26 PM
    jandrews
    '09 FourDubDee TRD OR
    Icon suspensions are made for medium to high-speed offroad use. If you're driving one around on the street, you just bought the wrong suspension for your job. Do your homework next time.
    A progressively valved system (King, Fox) typically works better on road at low speeds offroad at low speeds in terms of damping. Digressively valved systems like Icon work better offroad at higher speed and on bigger hits (think potholes) on road.
    This.
    10 turns is adding about 2" of lift from whatever they were set at factory, which is usually about 2.5". If you're running 4"+ of front lift on coilovers meant for 3.5 or less, you're gonna have a bad time.
    Would you also like a boat that is excellent in water and on land?
    It's digressive.
