Icon Lower Control Arm for 2nd Gens - Design Flaw?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Captain Nemo, Oct 27, 2024.
  1. Oct 27, 2024 at 5:27 PM
    Captain Nemo
    Captain Nemo [OP] Well-Known Member
    20K Under the Los Angeles Sea
    '10 Access Cab TRD Off-Road
    ARB bumper w/ TJM winch, All Pro rear bumper, BudBuilt skid plates, DeMello Hybrid sliders, IPAA spotlights, Icon Stage 2 Suspension Lift Kit, 285/85/16 BF Goodrich AT, FJ TRD Trail rims, Optima dual battery w/ Wrangler solenoid, Wet Okole seat covers, BakFlip CS-F1 tonneau
    I purchased some new LCAs from Icon Vehicle Dynamics along with their billet UCAs and struts. @Icon_Adrian
    Anyone else here running ICON's LCAs on the 2nd gen Tacos? Any thoughts on if this is an installation error or a design flaw?
    The installation instructions from Icon are not very helpful due to lack of sufficient images and details instructions. There's no installation video out there that I know of either.
    Upon installation I noticed that where the bump stop has been welded into the icon LCA is grinding into the back of the trucks wheel mount (sorry if that's not the right term) and the cupped "shoe" on the trucks's LCA bracket is grinding into the Icon LCA where the bump stop is supposed to be.
    Attached are photos of the OEM LCA and where the bump stop is on it, and the ICON LCAs currently installed.
    I've sent a few messages to Icon over the past 2 weeks and still haven't received a reply.
    Icon LCAs (SKU 54300):
    https://www.iconvehicledynamics.com/accessory/25229/icon-accessories-icon-2005-2023-toyota-tacoma-front-lower-control-arm-kit/
    Instructions:
    https://images.iconfigurators.app/pdf/I54300_REVA_3079.pdf
    Kolter45 likes this.
  2. Oct 28, 2024 at 2:01 AM
    Flex-AZ
    Flex-AZ Well-Known Member
    Flagstaff, AZ
    2015 TRD Sport DCLB
    Camburg/Deaver mid travel
    The hemispherical piece on the bottom of the knuckle is the steering stop. When that engages the LCA it can make a terrible squeaking sound. Strangely enough it looks like the striking pad on the LCA that is designed to line up with the steering stop is mounted on the back (rear facing) of the LCA instead of the front.
    Some people remove the steering stops from the knuckle, I think this is somewhat common for long travel setups.
  3. Oct 28, 2024 at 9:55 AM
    TacoTuesday1
    FL
    no response for 2 weeks on $2k control arms
    Guess that crosses those off the list
  4. Oct 28, 2024 at 10:33 AM
    Captain Nemo
    Yes, it's starting to look more and more like a design flaw to me. I'm still on the IFS setup and not comfortable with removing the steering stops...yet. The engineering team at Toyota obviously put more thought into it than the design/fab team at Icon, not to mention the support at Icon has gone AWOL at this point.
  5. Oct 28, 2024 at 10:43 AM
    Sailor_Nick
    Sailor_Nick Well-Known Member
    Nick
    Massachusetts
    2011 Tacoma TRD-OR DCSB 6-speed
    Bilstein 5100's, 32" tires
    The instructions are a bit vague although it does say
    "7. Remove the lower ball joint bracket from the factory ball joint using a ball joint separator and 24mm. Note the orientation of the steering stop to the arm (Front/Back). [FIGURE 5"
    Then in step 8, it shows the steering stop bracket installed in normal orientation.
    OE arms have steering stop pad on front side of arm. Icon arms, the steering stop pad is on the back side. You could try swapping the brackets left/right and see if the stops line up better. I'm pretty sure the only difference in left and right brackets is where the pad is located.
    Also, What is the part in figure 5?
    winkel likes this.
  6. Oct 28, 2024 at 10:50 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Maybe try calling their tech support. @Icon_Adrian might have some input.
    FastEddy59 likes this.
  7. Oct 28, 2024 at 10:57 AM
    Captain Nemo
    I'm not sure it's a good idea to swap the brackets left/right since that completely changes the angle of the LCA, not to mention that it would violate the warranty.
    Besides, look at the image of the truck with the Icon LCAs on their website...it shows it installed with the steering stop pad on the rear side. That's why I'm really trying to figure out if this is a design flaw or an installation error since the instructions leave much to be said for.
    I believe that's the ball joint separator in Figure 5, a tool that's recommended to be used during the installation process.
  8. Oct 28, 2024 at 11:09 AM
    Captain Nemo
    Done that several times. It's just a recording and left a message. I've mentioned @Icon_Adrian in the first post as well.
  9. Oct 28, 2024 at 11:39 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I don’t think even Icon could have fucked up this bad. Not sure why they’ve done it this way, but at first look it seems you’re supposed to swap the brackets that go on the bottom of the knuckle left to right so that they will line up with the stop tabs on the Icon arms.
    Captain Nemo[OP] likes this.
  10. Oct 28, 2024 at 12:44 PM
    Captain Nemo
    Your suggestion to swap the brackets makes the most sense; however, figure 8 in the installation instructions show the brackets in their original position, and there's no mention of swapping the brackets.
    Suggests to me that either the design is wrong or the instructions are wrong.
  11. Oct 28, 2024 at 1:05 PM
    Flex-AZ
    Flagstaff, AZ
    2015 TRD Sport DCLB
    I have Camburg stock length LCAs and they have a horizontal strike pad built in to the arm to contact the steering stops. Here’s a couple pics showing them in action.
  12. Oct 28, 2024 at 1:07 PM
    Captain Nemo
    Now that's how I would expect it to look like.
  13. Oct 28, 2024 at 2:22 PM
    racer1x
    racer1x Well-Known Member
    campbell ca
    05 Taco
    Too many
    The arms are side specific (2) different part numbers, I cannot see icon making that big of an oversight. Are you sure you have the correct arms on the correct sides?
    If those tabs are both pointed toward the rear of the vehicle then I would have to say they are on the wrong sides
    Pickeledpigsfeet likes this.
  14. Oct 28, 2024 at 2:38 PM
    Captain Nemo
    I'm pretty sure they're on the correct side, unless Icon themselves tell me that they're wrong. The images in the truck with them on the Icon product page shows it the same way, and so do the installation instructions. The most plausible theory here is that the brackets are supposed to be reversed; however, that's not in the instructions and figure 8 in the instructions does not show the brackets being reversed.
    In addition the product page mentions "relocated steering stops"...but there's no mention of it in the instructions or the images in the instructions.
    I'm waiting for an official reply from Icon and will keep this thread updated.
  15. Oct 28, 2024 at 3:06 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Maybe you got 2 of the wrong arms. Hopefully Icon responds soon. They aren't known for responding quickly
    My Total Chaos LCAs also have the steering stops, and I didnt need to modify anything, nor does anything rub
  16. Oct 28, 2024 at 9:36 PM
    racer1x
    campbell ca
    05 Taco
    Too many
    The hydraulic bump stops that I got from icon were mis marked left and right, they clearly would not fit on the wrong sides though.
  17. Oct 29, 2024 at 4:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Cut them off the rear and weld them onto the front. At this point that seems the easiest solution.
    Dacapster likes this.
  18. Oct 29, 2024 at 6:30 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    Strange - as shown above, most LCAs have that strike pad in the front to work with the steering stops. It looks like Icon may have had the idea to move that strike pad to the back ... maybe negating the need for the LBJ steering stops - or using both as a limiter but not really accounting for the scratching away you'll continue to get ... and you're seeing both contact? I tried zooming into icon's pics on their site and I'm not 100% certain but it sure looks like they removed their steering stops --- so maybe on their truck it only hits the back strike pad? Strange design and I'm watching to hear Icon's thoughts on the design and recommended next steps.
    FWIW I have the BTF LCAs that push the LBJ forward (great for 35s). I have a similar issue with the stops slowly grinding into the LCA. I could reshape the steering stops or remove them, because it did slightly limit steering, but I just add a layer of grease to the steering stops and put a few good tacks where it's rubbing every summer and it's good. Although in my case I talked to BTF and that portion of the LCA is a solid one piece block versus boxed so it is more of a scratch. Not sure about these?
  19. Oct 29, 2024 at 12:00 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    So I just spoke with my contact over at Icon. They are now aware of this thread and the concerns. They will be chiming in shortly
    winkel, JasonLee, Torspd and 2 others like this.
  20. Oct 29, 2024 at 12:44 PM
    Captain Nemo
    That's great. Thank you for doing that. I'm looking forward to seeing what they have to say.
