Icon Bolt On Secondary Shock Hoops and Shocks at Metal Tech 4x4!
Discussion in 'Metaltech 4x4' started by MT4x4, Mar 5, 2013.
  1. Mar 5, 2013 at 11:09 AM
    MT4x4
    MT4x4 [OP] Metal Tech 4x4 Vendor
    Travis "LT"
    Portland, OR
    07 FJ Cruiser
    Sway Away 2.5 coilovers, MT F&R Tube Bumpers, MT Sliders, Marlin Crawler Dual Transfer Cases
    Icon has finally released their new S2 performance secondary shock hoop system! This system is a complete bolt on unit utilizing a lower a arm skid plate and the secondary shock hoop bolts to the frame. There will be 3 different shock options: 2.5" Remote Reservoir, 2.5" Remote Reservoir w/ CDC, and 2.5" Omega Bypass. This kit will work on 07+ FJ Cruiser, 03+ 4Runner and 05+ Tacoma.
    We are currently waiting on our inventory order but if you would like to place your order now we will not bill you until it is ready to be shipped.
  2. Apr 5, 2013 at 5:21 PM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    So I'm guessing its NOT $423.00 for a pair of ICON 2.5 Bypasses? :p
    I'd be all over that if it were for a pair. LOL ​
  3. Apr 8, 2013 at 5:20 PM
    MT4x4
    Travis "LT"
    Portland, OR
    07 FJ Cruiser
    Sorry to say that is the price per shock.
  4. Apr 8, 2013 at 5:24 PM
    jandrews
    '09 FourDubDee TRD OR
    Still don't like that secondary hoop leveraging on the coil bucket, already known to be a weak link. That's the sacrifice for bolt on convenience I guess.
    Edit: And what's the other half of that secondary shock mount on the LCA skid?
  5. Apr 9, 2013 at 11:09 AM
    RAD
    Rad
    LAX & LOGAN
    ^ You can gusset the coil bucket with some TC weld on parts. That would make it real secure.
    I wouldn't trust the bolt on ICON lower skid plate to where it mounts the bypass shock. However they're saying it works and performs.
    I'd mount it on a set of TC or LSK oem Lowers instead. The mount on the Icon skid for the lower is suspect.
  6. Apr 9, 2013 at 2:11 PM
    jandrews
    Yes, of course, but then why not use the TC kit from the beginning?
    The big feature here is that it's a bolt on, reversible package. Frankly, I'm just not sure you can stay bolt on and set a suspension like this up properly. But I'm looking forward to people testing it.
  7. Apr 11, 2013 at 9:40 AM
    MT4x4
    Travis "LT"
    Portland, OR
    07 FJ Cruiser
    The secondary shock hoop bolts to the coil bucket and the frame just like the TC weld on version.
    The lower half there is one formed tab off the skid plate and a second tab that you weld onto your factory lower control arm.
  8. Apr 11, 2013 at 9:48 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
  9. Apr 11, 2013 at 9:58 AM
    JerryTaco
    JerryTaco Well-Known Member
    Cool system, but adding more to an already weak factory LCA kind of scares me a little.. I have plans to do something similar, but with TC LCA's, and TC shock hoop, and ICON shocks...
  10. Apr 12, 2013 at 9:22 AM
    RAD
    Rad
    LAX & LOGAN
    ^Thats a fantastic idea. . . Same as I'd do.
    You can still run everything intended but upgrade the stock LCA.
    However, if you weld a tab to the existing stock lca and use the other side mount of the Icon skid plate. It should handle well as if you would abusing your stock arms in general.
    There are guys who run their Tacos hard as well on stock lowers.
  11. Mar 29, 2015 at 11:21 PM
    trexTRD
    trexTRD Well-Known Member
    California
    Fox All Around, MaxTracs, Black & Red Leather Seats, Straight Pipe, and other crap...
    Anybody done a review on these? Pros and Cons
  12. Apr 19, 2015 at 9:44 AM
    Navar
    Navar Well-Known Member
    Corona CA
    07 Tacoma TRD Sport 4x4
    Washed it, Icon suspension, Icon UCA
    I like the set up and idea, but am concerned with the bolt on application as well as the strength of the system as well as the LCA's.
    Also in the vid those are very mild whoops. Let's see this set up hit the whoops by slasher x at Stodder wells.
    Also the rear end is week on that set up. You can see the rear wanting to bounce up
  13. Mar 10, 2021 at 7:05 PM
    Mickey SGV
    Mickey SGV ThinBlueLine
    Greater Los Angeles area, California
    2015 trd sport 4x4
    mid-travel for now....
    Reviving a dead post.... has anyone else ran this setup. With solid input???
    SoonToBeOn39s likes this.
