Icon 3 Leaf Add a Leaf leave in Overload spring?
Discussion in 'Suspension' started by Vst, Mar 23, 2021.
  1. Mar 23, 2021 at 12:25 PM
    Vst
    Vst [OP] IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    Alright guys I ordered the Icon 3 Leaf add a leaf and was wondering how many of you guys left the over load spring in? I have a 2018 TRD off road access cab with an ARE topper and a sleeping platform built in the bed. I’m wondering if its a good idea to keep the over load spring in to help with the added weight of the camping gear that i take with me. If anyone has done it how much lift did you get by leaving it in? Or is just the add a leaf enough for the lift and to support the weight? Thanks for any info
  2. Mar 23, 2021 at 12:27 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yes leave it in as it will give you 2 inches of lift and with a little sag you will still be fine.
    Grossomotto and Vst[OP] like this.
  3. Mar 23, 2021 at 5:07 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Yes, with the weight your running you’ll be glad you did.
    But...it’s only a matter of time. You’ll eventually be shopping for a complete pack. Sorry, just the facts.
    PoweredBySoy and Vst[OP] like this.
  4. Mar 23, 2021 at 6:00 PM
    Vst
    Scott
    Kodak, TN
    Yeah i know just trying to keep it budget at moment. I’m going to be running the falcon shocks and they are 1.25” longer in the rear than the stock shocks but i think its better going with an even longer travel rear shock with a new leaf pack.
  5. Mar 24, 2021 at 9:15 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I'm new to trucks. Only had my Tacoma for ~18mon and really only owned sport compacts previously. I installed a 3-leaf AAL yesterday with the overload left in. I did a lot of research and reading beforehand and kept seeing that these AAL's were "designed to be used with the overload left out". I didn't really have any context to that until I did the install. Now, after seeing how all the leafs interact once weighted I understand much better and agree with the quoted statement above.
    I plan to keep mine as-is for now and I don't think I'll have complaints but we'll see after next week's offroading/camping trip. But, I'll also be keeping my eye out for a good deal on a full leaf pack as it's pretty obvious to me now that the performance will be much better.
  6. Mar 24, 2021 at 9:41 AM
    Vst
    Scott
    Kodak, TN
    yes I plan on going full leaf pack in the future also probably the icon rxt pack or deaver just want to get my weight and camping setup dialed in so I know what kind of weight to choose the right pack
    RL33 likes this.
  7. Mar 24, 2021 at 6:55 PM
    RickyG1
    RickyG1 Active Member
    2020 Tacoma pro
    I’m going through same issues on my 2020 pro Tacoma. I have westcott designs from lift and 1.5 icon add a leaf with overload springs removed, my truck has a bit Of a sagged look.
    do you guys know if icon rxt option 1 is ok with stock pro suspension travel?
    thanks
  8. Mar 27, 2021 at 7:03 PM
    CementPro
    CementPro Well-Known Member
    2017 Cement Tacoma TRD Pro
    None.
    Following...
  9. Apr 7, 2021 at 2:20 PM
    Mikro
    Mikro Well-Known Member
    2020 MGM TRD Pro
    What are your measurements from center hub to bottom fender edge?
    I have same setup and in pics it sometimes looks saggy and sometimes not. I figure it’s the angle of the picture b/c I’m within 1/8” variance all around.
    Also I found this, https://youtu.be/IWWpr_tJ4vU
    You can measure that to make sure the collar is properly seated. Mine appears to be.
