Ice cap 2023 the same as super white?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacotrucknuts, Apr 27, 2023.
  1. Apr 27, 2023 at 3:27 PM
    Tacotrucknuts
    Tacotrucknuts [OP] New Member
    Just put in an order for a 2023 sr5 access cab Tacoma. Since, thanks to this super helpful community, I have read about the super white paint having chipping issues.
    My question: is "Ice cap" a separate (new and improved) paint than the old super white, or will I suffer from the same chipping issues? I love the color, but it's not too late to change my order. Should I?
  2. Apr 27, 2023 at 3:29 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    welcome aboard.
    enjoy the truck when it comes in.
    shakerhood likes this.
  3. Apr 27, 2023 at 4:25 PM
    rivets
    rivets Member
    I have an Ice Cap 23OR. It's the same paint code (040). There is no evidence or confirmation by Toyota that they've fixed the paint issue. Only time will tell, unfortunately.
    Stevie17 and Lt. Dangle like this.
  4. Apr 27, 2023 at 4:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome. Your truck your rules.
  5. Apr 27, 2023 at 4:29 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Could be a PR thing.
  6. Apr 27, 2023 at 4:34 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I saw a “white” short box sport recently that definitely wasn’t the super white Toyota color. It was way shinier and looked a bit like “pearl white” colours.
    shakerhood and batacoma like this.
  7. Apr 27, 2023 at 4:36 PM
    batacoma
    batacoma Truck Wars
    Wind Chill Pearl?
    WCP looks good.
  8. Apr 27, 2023 at 4:42 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Oooooooh
    Aaaahhhh
    Stevie17 and batacoma[QUOTED] like this.
  9. Apr 27, 2023 at 6:16 PM
    thman1
    thman1 Well-Known Member
    2023 TRD OR
    Interior LED’s TRD CIA OEM Blackout pkge
    I have a 2023 OR with Ice Cap 040 which is the same code as Super White. Really hoping that Toyota did something to improve it but I remain skeptical. Only time will tell if there is a difference….my build was the Baja plant.
  10. Apr 27, 2023 at 6:17 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you go through the actual thread, I don't think there are any past 2020.
    Tacotrucknuts[OP] likes this.
  11. Apr 27, 2023 at 6:28 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    Name your truck * Storm Trooper*
    Tacotrucknuts[OP] and thman1 like this.
  12. Apr 28, 2023 at 12:40 AM
    BillyE
    BillyE Well-Known Member
    They say it has a clear coat vs single stage super white. I’ve not seen any posts of trucks made past 2019 with the issue. Could be just a time thing though.
  13. Apr 28, 2023 at 6:45 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Go with a different color.
  14. Sep 25, 2023 at 6:12 PM
    Jigstick
    Jigstick Well-Known Member
    2023 TRD OR LB
    My 2023 is Ice Cap 0040. Which is a multi coat application thicker than the old 040. Look at your window sticker. If you see the 0040 code for your paint you should be good to go
  15. Jul 15, 2024 at 9:14 PM
    antofthesky
    antofthesky New Member
    Arizona
    2023 TRD OR DCSB
    Are you sure it's 040? My '23 says 0040 for the paint code. Assuming the extra zero means something as others have said.
  16. Jul 16, 2024 at 5:16 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    For SA my super white was retroactively renamed to Ice Cap in TIS. So that tells me it's the same. It's like what mutual funds do. Rename a bad performer to sweep history under the rug.
    Barsoom likes this.
  17. Jul 16, 2024 at 4:59 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    0040 is 040. They're not different.
    Jeff
