Iac valve for 4.0 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lita4x4, Mar 11, 2017.
  1. Mar 11, 2017 at 3:52 PM
    Lita4x4
    Lita4x4 [OP] Well-Known Member
    Daniel
    California
    2017 DCLB TRD Sport
    Where is the iac (idle air control) valve located on igrfe 4.0 engine?the engine idle is rough I cleaned the maf sensor so that was not the issue.
  2. Mar 11, 2017 at 11:37 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I'm not sure these trucks have an iac valve. have you cleaned your throtle body and changed plugs
  3. Apr 11, 2017 at 8:13 PM
    Shade5
    Shade5 Member
    Seagull
    2005 Tacoma
    Hello hello! Yup, I have the same issue, same inquiry. Same year, same engine. I cleaned the throttle body, mat sensor, filter, denso plugs. I've been searching forums on cleaning the (IAC-idle control valve) but I'm at a loss with its location. I'm beginning to think the 05's didn't have one. I've done parts searches and it ends at 04'. Were they internal in the throttle body?
  4. Apr 11, 2017 at 8:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    there is no idle air control valve. Reason being is the throttle body is fly by wire with no direct link to the gas pedal. This means the ecu can control the butterfly to control the idle itself rather than having to use a bypass circuit (idle air control valve) to do so.
  5. Apr 11, 2017 at 9:14 PM
    Shade5
    Shade5 Member
    Seagull
    2005 Tacoma
    Thanx for reply. Now I know.
  6. Apr 12, 2017 at 4:46 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    With the age of your vehicle, I say to check your vacuum hoses for cracks. Use some Redline Oil S1 Fuel system cleaner, or VP Racing fuel system cleaner, and or change your fuel filter (fuel pump upgrade from URDUSA.)
  7. Jul 8, 2017 at 10:07 AM
    Sandman24
    Sandman24 New Member
    06 TRD Off Road
    5100's all around, k&n air intake.
    I'm having the same issue with my 06 4.0. Cleaned throttle body, air filter and MAF. I also replaced both my downstream and upstream o2 / AF sensors. Codes I keep getting are P2197- o2 sensor (B2-S1) and P0505- idle air control system. Where do I go from here? Thanks!
  8. Jul 8, 2017 at 5:29 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    P0505:
    P2197:
    I'd check for intake vacuum leaks after the MAF that would affect just bank 2, and also exhaust system leaks before (manifold or gasket) or near (connections/rust/damage to the head pipe) the bank 2 O2 sensor¹.
    ¹ - Exhaust gasses flow in pulses with a higher than ambient pressure head, a near ambient pressure body and a less than ambient pressure (partial vacuum) tail. When the pulse's head passes the leak exhaust gasses are forced out of the system, when the body passes the leak nothing happens. Neither of these affects the content of the exhaust gasses.
    However when the pulse's lower than ambient pressure tail passes the leak outside air is sucked in making the AFR appear lean, making the O2 sensor appear to be "stuck" lean.
  9. Jul 11, 2017 at 8:19 PM
    Sandman24
    06 TRD Off Road
    Thanks for the reply. I've been sick the past few days so I haven't done anything with my truck yet. I'll look into it and post my results.
  10. Jul 15, 2017 at 9:34 PM
    Sandman24
    06 TRD Off Road
    No vacuum leaks just two bad air fuel ratio sensors. Mystery solved.
