I was quoted $500.00 for spark plug replacement on my 2016 Toyota TRD
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dthieren, Aug 3, 2021.
  1. Aug 3, 2021 at 8:20 AM
    dthieren
    dthieren [OP] New Member
    Denell
    2016 Grey Toyota Tacoma TRD
    Does this seem really high? I was shocked. The serviceman said it's because they are titanium spark plugs which is why it's so expensive. I'm not sure I buy this.
    Thanks for your help!
    Denell
  2. Aug 3, 2021 at 8:21 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yes that's high. And the serviceman is full of shit. As usual.
    shakerhood, jackn7, JustJon and 23 others like this.
  3. Aug 3, 2021 at 8:22 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    Only like $100 if you do it yourself, all you need to know how to do is turn a ratchet.
  4. Aug 3, 2021 at 8:22 AM
    Tacospike
    Two Trucks
    Was that to install as well? or just the parts alone?
    Rockefelluh likes this.
  5. Aug 3, 2021 at 8:22 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    It’s probably labor costs and not the spark plugs. Spark plugs are around $25 and you need 6 if you have the v6.
    MadDaddy and SR-71A like this.
  6. Aug 3, 2021 at 8:22 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    Must be made of actual platinum
  7. Aug 3, 2021 at 8:22 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    They are pricer than copper plugs, plus an hour or so per side. seems right for dealer work.
  8. Aug 3, 2021 at 8:23 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    welcome to the group, that quote does seem high, I would try to get another estimate if possible.
  9. Aug 3, 2021 at 8:26 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. $500 is high but the plugs are rather expensive and it does require a lot more labor to change the plugs than back in the good old days when you just pulled off the wires and changed the plugs.
  10. Aug 3, 2021 at 8:27 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is a step by step spark plug change Thread if you search the 3rd Gen section, little time consuming but not too difficult.
    Mr-Paul, GillyLink, MadDaddy and 5 others like this.
  11. Aug 3, 2021 at 8:28 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Learn to do it yourself and save some money. Then use the money you saved to buy Tacos so you can eat in your Taco.
    jackn7, Baerskin, WoodsGhost and 17 others like this.
  12. Aug 3, 2021 at 8:30 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    khax, MIDTNTACO, hfjeff and 1 other person like this.
  13. Aug 3, 2021 at 8:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hello.
    In the past, folks have been quoted in the mid-$400 range, so with inflation, that seems on target for a dealer quote. But, ridiculously high for the actual job.
    As others have said, it is doable. The left side ones can be done without removing the intake plenum. There is just enough room to work. The left rear one needs about 15in of socket extensions. Forceps really help in removing the coil pack harness.
  14. Aug 3, 2021 at 8:43 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Are you mechanically minded? You can buy iridium plugs at Rock Auto for under $5, or platinum ones for about $2.50. That works out to $25-40 for parts, shipping in. If you are able to do it yourself, I would. There are other things that require more knowledge and specialized tools to do where it makes more sense to go to a dealer.
  15. Aug 3, 2021 at 8:45 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    mileage
    4 0r 6 cylinder
    essentially U r paying full shop rate
  16. Aug 3, 2021 at 8:51 AM
    Kheiron
    Kheiron @Koditten Pirate Radio member #003
    Kevin
    Powell, WY
    2017 OR DCSB QS
    Kenwood d710g, high speed pheasant mod
    tonered likes this.
  17. Aug 3, 2021 at 12:46 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    $13.00 each at the Dealer if you purchase on line. Takes about 1.5 hours to do if you take your time. As noted look for the thread on plug replacement. Need ratchet and extenders (6 and 12), screw driver, torque wrench, anti-seize. Plugs are pre-gapped from dealer. Knockoffs being sold on-line so I'd go the dealer route for parts. Not sure where you are but I'd think anyone on TW that is local to you would lend a hand. I would.
  18. Aug 3, 2021 at 12:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Nonsense.....find another place for service.
    If you have the V-6, it only needs the basic copper plug from Denso. They are <$30 for a set of 6. The inline 4 uses a little more expensive plug. Even so, the set should be <$30. Then roughly 45-60 minutes install time...... Done.
    The service person is taking advantage of your gender.
  19. Aug 3, 2021 at 12:56 PM
    Vegasstunts
    Vegasstunts Well-Known Member
    16 TRD sport
    All of them.
    Whats your location? A member will probably help you out for free as it's a pretty easy job. Around $100 in parts will be all you need
    Mastiffsrule and mquibble like this.
  20. Aug 3, 2021 at 12:57 PM
    ill ay
    ill ay I DO MAN STUFF
    The Valley
    2012 Pre Tacoma & 2017 4x4 SR5 Tacoma
    I doubt its her gender but to prove them wrong, have a male call in and ask for the same service.
