I want to tap into the power to the rearview mirror anyone done this?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, May 10, 2024.
  1. May 10, 2024 at 4:39 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I want to tap into the power plug on the back of the rear view mirror to power my dash cam and radar detector. Anyone done this? Advice on which adapters are best?
    Pics of any cool installs?
    Thanks
  2. May 10, 2024 at 4:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I don't know if there is an adapter. But I can tell you that there are 2 fuse that go to it.
    A 7.5A and a 10A. I'd see what the Cam and Detector pull, then go from there.
    PM inbound.
  3. May 10, 2024 at 4:52 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Jesse H, TacoTrigger16 and TnShooter like this.
  4. May 10, 2024 at 4:55 PM
    TnShooter
    Deogee
    STOCK
    Nice. That should make life easier.
    Just need to be sure both don't draw more power than the fuse.
    hyrule_trd[QUOTED] likes this.
  5. May 10, 2024 at 5:02 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    I did a combo of tapping into the mirror connector using a pin-connector harness and then ran a USB power source converter that I spliced (t-soldered) to the mirror wire under the overhead cluster. So, I have my radar detector and dash camp getting power at the top with no wires hanging down. One thing to note, there is a constant power wire and a switched power wire. I went from switched to constant for my dash cam after a break-in. Some USB converters will automatically switch-off once it detects low-voltage.
    Check out this thread: https://www.tacomaworld.com/threads/overhead-cluster-12v-ignition-switched-power-pin-outs.512640/
  6. May 10, 2024 at 5:19 PM
    eurowner
    eurowner Duke Sky
    Scoty
  7. May 11, 2024 at 7:17 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Both the camera and radar detector are 12v
  8. May 11, 2024 at 7:25 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Hell - I've got a dongar tap sitting around here. I used it for a bit and then went a different direction. DM an address and I'll see what it costs to ship. All yours. Just Zelle me the shipping when you get it.
    AZ Pete, EMR, eurowner and 2 others like this.
  9. May 11, 2024 at 8:40 AM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Very kind of you, Greg! Take a bow! :burnrubber:
  10. May 12, 2024 at 11:31 AM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Awesome thanks man!
  11. May 12, 2024 at 11:38 AM
    desmojames
    desmojames Member
    James
    Squamish
    22 TRD Sport with modifications
    Wheels and tires, suspension, bumpers, racks, tonneau cover, CAI, exhaust
    I also used the Dongar adapter for my dash cam. It does not provide constant power. It works perfectly when the truck is on, but when you park and leave the truck, you are relying on the dash cam internal power for parking recording. Maybe others have different experiences? Mine is an N300
    STEELeR43 likes this.
  12. May 20, 2024 at 10:41 PM
    Taco.Tuesday
    Taco.Tuesday Well-Known Member
    New Mexico
    '21 TRD Sport 4x4 DCLB
  13. May 21, 2024 at 6:33 AM
    black3rdgen
    black3rdgen Well-Known Member
    STL
    3G on 35s, 5.29s
    YW E30 tune, 5.29s, equal length dual exhaust, 2000w audio system
    I did it with my Uniden R3 and an Amazon mount. Ill post some pics when im home, its a super clean setup.
  14. May 21, 2024 at 6:48 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    You only get so much power from that adapter/power source. I got a new dash cam to try out and it wasn't working from that adapter, had to use the 12v plug it came with to keep it powered on.
    So, I stuck with my old small dashcam that works from that power source. Something to keep in mind..
  15. May 21, 2024 at 7:32 AM
    TheRogueBroJames
    TheRogueBroJames Member
    2019 Black Tacoma TRD
  16. May 21, 2024 at 7:37 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    Just bought one and will be installing it and my new camera later this morning.
  17. May 21, 2024 at 2:57 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    If you get a chance to take a pic I'd like to check out how you did radar detector. I'm using the Radenso Pro M and still waiting on the Theia. The peaceful silence of the Radenso is worth the cost. I was die hard Escort for decades, even had a LIVE subscription and the jammers, but not even their top of the line units now have filters as good as Radenso to block out all of the false alerts from collision avoidance systems, etc. Man all the false alerts from the R3 would drive me crazy, lol! One thing I am a little worried about is mounting it too close to the top and to the mirror that could block some of the signal.
  18. May 21, 2024 at 4:59 PM
    NC Gazzer
    Durham, NC
    Installed easily and works fine; however it provides power only when the truck is running (or in "ON" mode). No power when in "ACC" mode. Because it takes a bit of time to transfer video to my phone I can't see sitting there with lights, fan, etc draining my battery, or worse sitting there idling until the transfer is done. In hindsight, I should have run wires to the fuse box. May end up doing this anyway.
  19. May 21, 2024 at 5:22 PM
    black3rdgen
    STL
    3G on 35s, 5.29s
    Sorry forgot about this , just sent the truck in to the shop today to get some work done, so I’ll get some pics when it’s back. The R3 isn’t bad around where I live because literally not a single cop shoots K or X band so I can just turn them off. KA band NEVER has false alerts for me so I don’t see the need to spend more than $300. Might have to get the new R9 with jammers for my S7 tho
  20. May 21, 2024 at 5:28 PM
    mikesixtysix
    mikesixtysix Well-Known Member
    North Jersey
    2018 TRD Pro
