I want posi traction...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98yotadog, Jan 20, 2009.
  1. Jan 20, 2009 at 1:24 PM
    98yotadog
    98yotadog [OP] Member
    north carolina
    98 tacoma
    k & n filter, aftermarket sound system
    i did the search and haven't found a direct answer for my question. i keep reading on here that the lsd's clunk, rub, etc. in my mustang, the traction loc is factory and does none of this. few of the aftermarket units have these problems either.
    is there no aftermarket or oe unit for my 98 yota that won't give me these problems? it is a 2.4 reg cab 2wheel drive. i'd rather not have an electronic locker. i want something that's there 24/7. thanks for any input.
    by the way, if the yota rear can't work like my 8.8 ford unit, maybe it's time for a little rear end fabricating...like a ford 8.8 in the taco...
    wilcam47 likes this.
  2. Jan 20, 2009 at 3:33 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    I suspect much or all of what you've read about 'clunking' or 'rubbing' has been in relation to lockers and not LSD's.
    I'm not knowledgeable about Mustangs, so I don't know if the traction loc you refer to is a locking or a limited-slip differential.
    If it's a limited-slip differential (LSD) you're after, you want a Detroit TrueTrac for the Tacoma '7.5' rear end.
  3. Jan 20, 2009 at 3:40 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    My truck has never spun only on tire.... it doesn’t matter if its pavement or ice they both spin.... an its a base package???
    Jutty913 likes this.
  4. Jan 22, 2009 at 1:02 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    2015 TRD Sport 4wd
    Icon Coilovers, Magnaflow, K&N Intake
    Just wondering here, but why would you want posi-trac in a 2.4 2wd truck? What do you expect to do with it? Sounds pointless to me unless you've got a big motor in it or turbo/SC etc...
  5. Jan 22, 2009 at 2:11 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    'Posi-Trac' is the GM branded Limited Slip Differential. He wants LSD instead of his open differential. Has nothing to do with motor size.
  6. Jan 22, 2009 at 2:44 AM
    dustinuhls
    Manhattan, KS
    2015 TRD Sport 4wd
    I know that, I'm just wondering why one would want LS on a truck w/ a small motor and 2wd. What performance gains are you really getting from that? I just wanna know why he would spend money on this??
  7. Jan 22, 2009 at 2:52 AM
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    what is all involved in the install of the detroit tru trac lsd on a 2006 tacoma with open diff? just R & R or is there more to it?
  8. Jan 22, 2009 at 4:05 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Why does motor size comply with more traction? Have you ever been stuck?
    cruxofthebisquit likes this.
  9. Jan 22, 2009 at 4:15 AM
    Delmarva
    Tucson, AZ
    x2...
  10. Jan 22, 2009 at 5:30 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I don't know his reasons, but I have had the same thoughts. 2wd 4cyl base model with an open rear end. For me, it's not that I try to go 4 wheeling with it, it's so that if one wheel starts to slip (for whatever reason) the other wheel will still turn. Hopefully, that will keep me from getting stuck in say.....a field that is just wet enough for it to not get good traction...or with slick roads in the winter. The 4cyl may not be a huge powerhouse, but it can spin the tires.
    All in all, I hope that I don't need it. It's more of a safety/security feature that I hope I don't ever need. I've only needed it (or 4wd) once before, but I was able to get unstuck anyways.
  11. Jan 23, 2009 at 11:09 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    SO what is the part number and all the parts needed to make this happed?
    Or do you need to go to a junk yard and find these part and make it work?
    Reason to have it, it is safer.
    If you drive mountain roads you want good traction.
    If you hual gear you want good traction
    If you do anything on a race track you want good traction....
  12. Jan 23, 2009 at 11:28 AM
    98tacoma27
    Ben
    Not Beech Creek
  13. Jan 23, 2009 at 6:03 PM
    98yotadog
    north carolina
    98 tacoma
    i just want to have it if i need it. i hunt in a sandy area, and although it's not a pre or 4wd, it gets the job done. i just want the extra insurance a lsd would give me. we just had about 6 inches of snow here and on my way to get 2 new rear tires, i felt like i was in a drift competition. my f150, which has a traction loc (LSD) never does this.
    my second reason is that my son gets the truck in 2 years. he wants to put a turbo and built motor in it...a built 2.4 at that! then the lsd will really help.
    as for the "small" motor comment, you'd be surprised at what my little yota has been through in it's 200k miles! with enough weight in the bed (as a work truck) to make the leaf springs look like they were upside down, it still kept up with traffic and never complained.
    anyway, i've found the powertrax on ebay for a great price and now i'm waiting on it to arrive. thanks for the input.
    by the way, the part # for the powertrax unit is 1611 for the 7.5 rear.
  14. Jan 23, 2009 at 6:22 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    i must say it is a royal beotch to have 1 wheel off in the mud and one on the pavement..but thats when i put er in 4hi but obviously he cant do that.... 1 wheeler squeelers suck...lol.....
  15. Jan 23, 2009 at 6:30 PM
    98yotadog
    north carolina
    98 tacoma
    lmao....i've never been stuck and i don't have to step up to get in my yota (tacos are either full of meat or pink!)...lol. and, as the wife will tell ya, i've learned to do with 2...well, you get the picture...lol.
  16. Jan 27, 2009 at 7:46 AM
    afd23a
    The Dynamo of Dixie
    Let us know how it goes. The powertrax looks pretty interesting.
  17. Jan 27, 2009 at 7:55 AM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    I thought about a LSD unit, but seeing how taking corners when the road is wet one wheel spins now and I fishtail, I can imagine how bad the rear end would want to 180 if both wheels were spinning.
    Some sort of "switchable" LSD (not switchable locker) would be nice.
  18. Jan 27, 2009 at 8:23 AM
    98yotadog
    north carolina
    98 tacoma
    from what i understand, it installs without removing the ring and pinion...i'll keep you posted
  19. Jan 27, 2009 at 8:24 AM
    98yotadog
    north carolina
    98 tacoma
    if this thing works like the traction-loc in my mustang, that shouldn't be a problem, especially with the auto. the stang is a stick and only spins when i want it to (or more like when the wife wants it to! she rarely lets me drive it...lol)
  20. Jan 27, 2009 at 8:55 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
