I need to tow my 4WD tacoma and need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cmccain13, Sep 27, 2020.
  1. Sep 27, 2020 at 6:23 AM
    Cmccain13
    Cmccain13 [OP] New Member
    Cory
    2000 tacoma 4wd
    Ok so I'll be towing the tacoma behind an RV, it's 4WD and I'm thinking that is going to be a problem correct? Can I tow on all 4? A tow Dolly? Or will have to be on a trailer all 4 wheels off the ground?
  2. Sep 27, 2020 at 6:31 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    You can do both, but for a dolly you will have to remove the rear driveshaft, I would also remove the front but if it's not in 4wd it won't be spinning
  3. Sep 27, 2020 at 1:23 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    If you’re doing it frequently or prolonged get a trailer. You can back up a car hauler. Not all campgrounds have pull through sites. Towing it will definitely limit your access.
    ColoradoTJ and LoveableWerewolf like this.
  4. Sep 27, 2020 at 1:24 PM
    LoveableWerewolf
    Nashville
    A car trailer would be a lot easier, and easier to resell if you want. Just drive on and off and tie down.
  5. Sep 27, 2020 at 1:44 PM
    tony2018
    tony2018 Well-Known Member
    I vote trailer as well.
  6. Sep 27, 2020 at 1:48 PM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    LoveableWerewolf likes this.
  7. Sep 27, 2020 at 1:50 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I vote tow dolly, but with the back wheels on the dolly. You can’t tow with the rear wheels down (arguably, unless it’s manual and in neutral)
    Dalandser likes this.
  8. Sep 27, 2020 at 1:51 PM
    LoveableWerewolf
    Nashville
  9. Sep 27, 2020 at 1:52 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Dolly and disconnect the driveshaft
  10. Sep 27, 2020 at 1:58 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    That would suck to crawl under a vehicle to hook up a driveshaft(s) at every destination. If your RV can pull the weight (usually only class A coaches can), a trailer would be the way to go.
    If that doesn't work, Jeep wranglers are dime a dozen.
  11. Sep 27, 2020 at 2:00 PM
    LoveableWerewolf
    Nashville
    Crawling under there on vacation is literally the only reason I vote trailer. But again only if the rv can.
    ColoradoTJ[QUOTED] likes this.
  12. Sep 27, 2020 at 2:11 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It’s only 4 bolts and zip tie or tie the drive shaft to the gas tank crossmember.
  13. Sep 27, 2020 at 2:11 PM
    ColoradoTJ
    Colorado
    I would think it would suck anywhere, but I'm a trailer guy. Flat towing sucks.
  14. Sep 27, 2020 at 2:12 PM
    tony2018
    Uh, it was stated so not sure how someone missed it. But it's the OPs decision, unbolt or get a trailer.
  15. Sep 27, 2020 at 5:02 PM
    aroma
    Snottsdale AZ
    A good point was made about the towing capacity of your rig. That might make your decision for you. My rv will not handle the additional weight of a trailer. Getting a Tacoma set up to flat tow (AUTO) can get expensive. If you have a 5 speed it is much easier. I have been flat towing for about 10 years and made my decision by first renting a tow dolly on a short trip. Never again. There is alot of information on RV forums about this subject. As on this forum there are many opinions and comments from people who have never actually done it.
    nagorb likes this.
  16. Sep 29, 2020 at 1:57 PM
    Boone Wesley
    Boone Wesley Well-Known Member
    Boone
    LA 818
    01 4D 4WD Limited
    I dolly towed my 01 4wd with the transfer case in neutral, trans in park. No big deal. I drove a AAA flatbed for over a decade, I've flat towed just about everything. These guys saying it's easier with a manual, ha.
  17. Sep 30, 2020 at 10:09 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    I dont get it. If the truck can drive the distance on its own I see no reason you need to disconnect the driveshaft just leave it in neutral. If it cant handle being towed on a dolly and the driveshaft spinning then you have bigger problems IMO. The only thing I would say is it will up the mileage on the truck but you can just disconnect the cable/sensor to the speedo on the trans.
  18. Sep 30, 2020 at 10:13 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think the issue was from internet research saying that transmissions could possibly incur overheating / damage from spinning but not having the engine keeping things going fast enough. Having experience with technical issues you may be able to shed light on this issue :)
    Russianman92[QUOTED] likes this.
  19. Sep 30, 2020 at 10:30 AM
    Russianman92
    Dunwoody GA
    Never seen that to be honest. I have heard that with Auto transmissions but not necessarily with manuals. I suppose it is possible as the output shaft does not spin the counter shaft pulling gear oil up when in neutral. Hmm well i stand corrected. Depending on distance disconnecting the driveshaft at the rear axle probably not a bad idea. In any case as someone else mentioned backing the truck up on the dolly and having the front wheels spin would eliminate that problem.
    Dalandser[QUOTED] likes this.
  20. Sep 30, 2020 at 11:10 AM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    minus the part where this is illegal.
