I need help with lifting my 4th Gen Taco SR(Leaf springs)
Discussion in '4th Gen. Tacomas (2024+)' started by Gr8fulJudah, Nov 24, 2024.
  1. Nov 24, 2024 at 6:44 PM
    Gr8fulJudah
    Gr8fulJudah [OP] Member
    Judah
    2024 Toyota Tacoma SR
    I have a 2024 4th-gen Toyota Tacoma SR with leaf springs, and I was wondering what someone's recommendation is for a small lift with leaf springs and the size of the tires. I am reluctant to put blocks under the leafs. Thanks for your help.IMG_1332 2.jpg
    At The Helm likes this.
  2. Nov 25, 2024 at 4:50 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Maybe there will be some shackles available. The leaf sprung SR might be the worse truck to lift. I have only been interested in the XC, and I wouldn't want to put blocks on one of those trucks either. The way the leafs hang down and so much spring being exposed I don't think it will look good, if it's purely for articulation that's a different story.
  3. Nov 25, 2024 at 5:15 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    buy a different truck.. or just put bigger tires on the truck you have.
  4. Nov 25, 2024 at 6:36 AM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    You're gonna need to add a sarcasm indicator otherwise people are going to think you're stupid.
  5. Nov 25, 2024 at 6:38 AM
    findingthingsout
    midwest
    Are the new leaf set ups Spring Under axle? There should be some options coming out for you. The add a leaf packs could be a decent option, especially since you are starting with a fresh pack.
    R242 likes this.
  6. Nov 25, 2024 at 10:31 AM
    JC 4th Gen
    JC 4th Gen Well-Known Member
    Raleigh, NC
    2024 TRD Sport
    Are you lifting to install larger tires? A cheap way would be to add an RC 1.5" leveling kit (spacers) up front and then add some lift to the back if needed. Lots of ways to lift the leaf springs a bit.
    Your truck already looks a lot more level than mine does with the coils. 285/70's are pretty easy to fit, especially if you lift the front 1.5".
  7. Nov 26, 2024 at 6:18 AM
    yotafiend
    yotafiend Sup Dawg!
    Detroit, MI
    2024 SR5 DCSB 4x4 Underground
    TRD OR Wheels Falken Wildpeak 33s C TRD OR Struts Trailhunter Skid Toyota Mudguards Toyota Integrated Dashcam Toyota Rocker Bars CH Ceramic Paint Coating Costco 91 Octane
    The new leaf springs are under axle, meaning 10x more comfort than previous gen. Also, when a Deaver pack comes out for this truck, it'll be nice.
    Here is what is listed for Tacoma on Deaver's site:
    https://deaverspring.com/product-category/leaf-springs/toyota/
    You should call them and ask if they have a leaf spring for the 24' Taco, maybe it's not showing but could be in production and maybe available. Depending on the weight you plan on carrying, you'll need to know to match the spring load/rate.
    Oldcodger likes this.
  8. Nov 27, 2024 at 11:12 PM
    dalton92
    dalton92 Active Member
    its spring under- so blocks would actually lower it.
    R242 likes this.
  9. Nov 28, 2024 at 12:42 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    I'm in the same boat with the SR, I have an add a leaf ready but not sure if it will add as much lift being under axle. Might be waiting for Deaver's too.
