I know others have done it, But Redline MT-LV 70/75 GL-4 is better!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SRBenjamin, Jun 11, 2021.
  1. Jun 11, 2021 at 7:30 PM
    SRBenjamin
    SRBenjamin [OP] Well-Known Member
    Benny
    Changed out the transfer case oil with RedLine MT-LV oil.
    The 4x4 engagement is much faster now, with less hunting.
  2. Jun 11, 2021 at 7:33 PM
    Dellafor
    Dellafor 2017 Tacoma 4x4 (Big Blue)
    Atlanta
    Suspension:Procomp 4" coilover lift kit w/cv drop & diff drop. Dirt king UCA, Sway bar relocate, urethane bushings and sumo bump stops AAL w/ 1" rear block and shim. Fuel 18 x9" wheels with 275/70/R18 K02s. BAMF CMC (deep). Exterior: High linel bumper gaurd with LED bar and Smitty winch. CNC Blue line Grille. Custom 6" LED over 3rd brake light for trailer/ bed. Any time backup and Front facing camera. Rear hitch guard/step, rear tow hooks (f150). Red tail light overlays and side mirror signal tint and corner marker blackout. Fully debadged and removed decals, tailgated raised letters. Toyota tonneau cover. Nerf 3" side rail sliders. Interior: Meso Dash Blackout kit, w/AC knobs and Start button. Blue floor led lights , Meso lower dash switch panel with HDMI input and usb quick charge. Dash track mount w/ram mounts. Blue vinyl overlays. Kicker tweeters and kicker amp w/ JL w3 8" sub on OEM entunes head unit (anytime gps mod & av input.. Full door, roof and cab dyna mat. Weather floor mats, center console cover, LED int light kit. Full Alpine Dash cam.setup(3). Performance: OV Tune, K&N filter with TRD piping & accelerator. TRD exhaust Tip. Oil catch can and AC drain mod.
    Never heard of this...how long.have u.been driving this way now
  3. Jun 11, 2021 at 7:36 PM
    SRBenjamin
    Benny
    One trip in to the mountains today(about 3 hours).
    Correction, I did a trans fluid change today. The Transfer I did 4 days back.
    So about 2~300 miles since.
  4. Jun 11, 2021 at 7:37 PM
    jbradar
    jbradar Member
    JB
    2020 Super White Tacoma TRD Off Road
    That's interesting!
  5. Jun 11, 2021 at 7:48 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    If you have the trucks driveline lined up, any Tacoma will go back and forth into 4hi, 2WD, and 4lo with ease. The shift into and out of 4WD is mostly due to the luck of the draw with having the splines in the T-Case and the ADD aligned.
    The t-case isn’t really a system that “hunts” for the gear. It’s either aligned, or it’s not.
    No offence, but your video would make more impact if it showed a series of engagements, after driving the truck around, then sitting stationary and hitting the 4WD knob.
    Smacky2020, Lt. Dangle, hiPSI and 4 others like this.
  6. Jun 11, 2021 at 8:07 PM
    SRBenjamin
    Benny
    offence taken. I've driven this truck for 19 months. Engaging 4x4 has always been a pain. I engage the four high while driving and it would take 4~6 seconds.
    After the oil change, it takes 2~3 seconds. A noticeable difference. I won't film a video while driving.
    I've got over 1,000,000 miles with Toyota 4x4's. I know how the system works. Almost every time someone makes a post, in an effort to help others out,
    There's always a MoFu stepping in to tell everyone how smart he is.
  7. Jun 11, 2021 at 8:13 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Could be a she
  8. Jun 11, 2021 at 8:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Which ones?
  9. Jun 11, 2021 at 9:15 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    19,000 miles of ownership; 19,000 total miles as well?
  10. Jun 11, 2021 at 9:38 PM
    Stocklocker
    17TRDORDCSBAT
    I’ve got 7,000,000 miles in Toyota 4x4s and all of that was spent in a zen state. Wasn’t trying to trigger you brother. Just staying facts. Your video shows nothing, but I do appreciate you sharing your findings with all of us here.
    Lt. Dangle and hiPSI like this.
  11. Jun 11, 2021 at 10:48 PM
    SRBenjamin
    Benny
    Lucky boy pass, Nevada.
    eurowner[QUOTED] likes this.
  12. Jun 11, 2021 at 10:55 PM
    SRBenjamin
    Benny
    Video shows the time it takes. others can compare.
    7 million miles? you must be about 175 years old.
    Not triggered, just how I respond to posters that add nothing but useless info.
  13. Jun 12, 2021 at 10:04 AM
    SRBenjamin
    Benny
    Also, I'd like to share a little more info. I was hot to try the Ravenol Gear Oil MTF-3 75W, because it seems to be a favorite in Toyota forums.
    After finding a VOA on the Ravenol Gear Oil, I was sad to see that it's sort of a piss poor oil. It has a very poor additives package.
    This is why I went with RedLine.
    usmc2msu likes this.
  14. Jun 12, 2021 at 11:09 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The point @Stocklocker was trying to make above is you are implying that your lube has to be slicker or thinner or something. It's not. Also, when you start talking additive package analysis, Bobistheoilguy is a much better place to discuss this topic. Very knowledgeable guys over there.
    I know you are posting here because you have a Tacoma but your findings, if true, would impact any box that meshes gears and splines.
    Now you can call me names too lol.
    skiploder, Stocklocker and Lt. Dangle like this.
  15. Jun 12, 2021 at 11:20 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I consider myself an expert too. I will never change the transmission fluid. Transfer case maybe once. Oil every 10k. When she gets to about 150k I'll sell her and grab an electric one.
    hiPSI likes this.
  16. Jun 12, 2021 at 1:55 PM
    splitbolt
    NW Arkansas
    I'm hot to try the Redline...got a link to the MT-LV voa?
  17. Jun 12, 2021 at 2:38 PM
    SRBenjamin
    Benny
    I dont know if there is one.
  18. Jun 12, 2021 at 4:33 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    We had a thread on it awhile ago it conforms to the shell tf0870 blah blah oil that is used by Toyota/bmw/ford/someone else I cannot remember.
    Of course we had people arguing that Redline is lying or mistaken about their fluid being Toyota compatible because this is the Internet and every moron has access to it these days.
  19. Jun 12, 2021 at 4:48 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    I’m getting ready to try the Red Line oil also mainly because I don’t want to purchase the liquid gold. I talked to the parts guy at my local dealer about if he had the product in stock. He responded Yes but it was pricy. A technician happened to overhear our conversation and responded that they mainly use the 70/w90.
  20. Jun 12, 2021 at 5:38 PM
    splitbolt
    NW Arkansas
    To me, all the popular substitutes are some kind of special low-viscosity manual transmission fluid. While they have similar viscosity, they vary in additive package with nothing really coming close to Toyota LF.
    My curiousity is more academic than anything; I'll probably use MT-LV on my next replacement.
