I have the dreaded AC light flashing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maachuu, Jun 7, 2018.
  1. Jun 7, 2018 at 6:01 AM
    maachuu
    maachuu [OP] Well-Known Member
    2006 Tacoma SR5 4x4
    I have replaced the relay and didnt not completely fix my problem. Symptoms are : will work and cool at times, if I am on interstate and running same speed ac will cool most of times but if I slow down and in some instances hit a bump, ac will start flashing and stop cooling. Sometimes when I start truck up and get on my way it will work fine and then it will just start flashing. I know according to post that there is one other part the I have to check and maybe replace. Freon is full in compressor, relay not a complete fix, so Im curious as to whether my serpentine belt might be slipping some but its not squealing as I would expect. Could the belt be the problem ? I bought truck used and have no idea when the belt has been replaced or if it has ever. Any thoughts or suggestions greatly appreciated
    Larry
  2. Jun 7, 2018 at 12:33 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  3. Jun 8, 2018 at 5:49 AM
    maachuu
    2006 Tacoma SR5 4x4
