I have motor oil behind my throttle body...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Canyon Jeff, Mar 6, 2015.
  1. Mar 6, 2015 at 11:57 AM
    Canyon Jeff
    Canyon Jeff [OP] Well-Known Member
    Jeff
    Southeast Utah
    98 Tacoma V6 3.4, TRD 4x4 5-speed 100k miles
    Is this normal? Or bad? my first thought was bad, but I don't know a whole lot about engines, so...
    I removed my throttle body today to clean it and the IAC, and I noticed a little pool of motor oil right behind the throttle body. I stuck a rag deep in there and the rag got a fine coating of fresh motor oil. wtf?
    I have a pic to attach, but I doubt you can tell anything from it. But you can kind of see the golden glow. I took my finger and ran it across the bottom of the opening, and you can kinda see the track of my finger through the oil. It was a very fine coating...
    Anyone know what this means?
    Thanks so much for your advice!
  2. Mar 6, 2015 at 12:35 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    PCV valve stuck open?
  3. Mar 6, 2015 at 12:39 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    Sure it's motor oil and not just oil from a filter (K&N)?
  4. Mar 6, 2015 at 12:44 PM
    MrRiverMan
    WNC
  5. Mar 6, 2015 at 12:58 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    filter is OEM: no oil. i mean, it just feels and smells like motor oil.
  6. Mar 6, 2015 at 12:59 PM
    Canyon Jeff
    Jeff
    Southeast Utah
    so it looks like that post is saying this is normal? i can totally live with that...
  7. Mar 6, 2015 at 1:02 PM
    MrRiverMan
    WNC
    I think it's normal to have oil there. If it seems like a lot, you should check to make sure your PCV valve isn't stuck open. Or just change it anyway - it's a $5 part.
  8. Mar 6, 2015 at 1:11 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    don't try to clean it unless you take the manifold off to do it, otherwise just leave it alone and it wont hurt anything
    for the throttle body cleaning, oil mist gets in it from the pcv valve and its full of black soot from the EGR valve so when these combine it makes a gooey tar like gum in there, mine looked like a stove pipe.
    whatever you do don't hit it with carb cleaner or it definitely melts into tar and it will be a royal PITA to get rid of.
    scrape it all out dry and after you cant clean it anymore, then use a cleaning solution on it. for the EGR passageway a good tip is use a gun cleaning brush for like 45 to run through that tube, just be sure to remove the temp sensor first.
    and get all new gaskets, FYI most times the EGR gaskets (2) need to be ordered and aren't kept in stock
  9. Mar 6, 2015 at 3:10 PM
    smokn
    smokn Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
