I have an old magnetic oil pan heater - and a skid plate.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by highriserkaiser, Oct 14, 2017.
  1. Oct 14, 2017 at 10:00 AM
    highriserkaiser
    highriserkaiser [OP] Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    2007 TRD. I doubt the thing will radiate enough if I stick it right to the skid plate on harsh nights, which January offers plenty of where I live, but will it?
    I've seen the heater mod with that adhesive pad, but I also got through some harsh winters with an 99 4Runner and no heater at all about 10 years ago.
    What are block heaters running these days, installed?
  2. Oct 14, 2017 at 10:16 AM
    Muddinfun
    Muddinfun Well-Known Member
    I bought mine with a block heater already installed. I've never followed the cord to see where it goes, but from what I've read, on the 4.0, it's just a matter of screwing out a plug and screwing in the block heater.
  3. Oct 14, 2017 at 10:32 AM
    highriserkaiser
    I'm totally open to DIY. Maybe I'll do some internet digging but I have limited tools at the moment. It's not unheard of to see a week not get above 10 degrees F where I am. Has it made a big difference where you are, compared to other vehicles? The cheap little magnet one I had seemed to work really well for my old Impreza.
  4. Oct 14, 2017 at 10:44 AM
    Muddinfun
    I bought my truck last spring, so i've never plugged it in. Where I live, it rarely gets cold enough to need it.
    highriserkaiser[OP] likes this.
  5. Oct 14, 2017 at 8:27 PM
    Climberclimb
    Climberclimb Well-Known Member
    Stacey
    British Columbia
    2020 TRD Sport premium
    Stock!
    My 2015 has a bracket on the engine that blocks putting in a block heater. Looks like an expensive fix to add it. I might try a magnetic one this winter! Cheers
  6. Oct 14, 2017 at 8:33 PM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    I'm not certain on yours, I would suggest looking at the stock option. I installed mine in less than 5 minutes. $140 from dealer and it slid right in a hole on the back of the block. It took longer to run the wire to the grill. Up here we also run pan heaters on our tranny and oil pans. Just small pads that glue onto the pan. Most use the same thing for the battery or use a blanket or trickle charger.
    The stock blocker heater was the easiest part of it all.
  7. Oct 14, 2017 at 8:40 PM
    musher
    2017 Tacoma
    I did some quick checking; per the interweb, yours has the cartridge style too. Back of the block near the brake booster. Looks to run about $70 at some places. Hope that helps.
  8. Oct 14, 2017 at 9:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I don't know about our Tacos but I put a block heater in my old T-100 years ago. You had to drain the coolant, pop out a freeze plug and install the block heater in it's place. It was a pain in the butt but was worth it's weight in gold if you can't park inside. I only plugged it in when it got below 20 F at night but it made a big difference in it's ability to spin over on a cold morning.
  9. Oct 15, 2017 at 8:38 PM
    Climberclimb
    Stacey
    British Columbia
    Stock!
    I agree the stock option would be best, but in the 2015 models there is a bracket that blocks the heater from sliding in. I can see where the stock heater goes, but that bracket!!! Thanks for the replys. I will look again and see if I can make it work. TW rocks!!! Cheers
  10. Oct 15, 2017 at 8:41 PM
    musher
    2017 Tacoma
    The instructions for mine said a bracket was in the way too, but I didn't have an issue. I really spent more time second guessing myself because it was so simple. The dealer wanted a couple hours to install. I did spend more time double checking and running the plug wire than anything else.
    Swing by, we'll check it ;)
  11. Oct 15, 2017 at 8:43 PM
    Climberclimb
    Stacey
    British Columbia
    Stock!
    Haha. I will take another look. Thanks!
  12. Oct 15, 2017 at 9:05 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    i run the slot in stock block heater, wolverine oil pan heater and wolverine battery blanket. Have only turned them on maybe a hand full of times when i was making my way through alaska
  13. Oct 15, 2017 at 9:15 PM
    musher
    2017 Tacoma
    When you coming back? I need a bedslide and bumpers!
  14. Oct 15, 2017 at 10:04 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I guess you can't drop your skid plate and put the heater on the pan and then put the skid plate back on? Skid plate welded on or heater too big?
    The OEM block heater part number used to be 00213-00889. It has either changed or been discontinued in the US.
    It was a simple cartridge style that fit in the specific space in the back of the 4.0 engines, but worked just fine for the area barely north of Anchorage. Really didn't need it, but it did help melt the snow off the hood. It was less than <$50 10 years ago.
  15. Mar 7, 2020 at 12:10 AM
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    Bringing this old thread back to life. I bought my 2009 TRD OR brand new in 2008 and had the dealer put the heater in.
    (RANT ALERT!!: I still have the paperwork for that and they actually charged me a couple hours labor AND coolant! You don't need to drain the coolant because this cartridge simply slides into the hole on the left-rear part of the block that is designed for it!)
    Anyway, I tested the cord that came with it and it isn't registering any resistance so I believe the cord is bad, or maybe both the cord and element. I ordered a new one ( https://www.amazon.com/dp/B004IHLY3I?psc=1&ref=ppx_pop_dt_b_product_details), but even though Amazon and KAT'S state the 11813 part # is correct, it is NOT the correct item after attempting to install it just about an hour ago. That part is for the 3rd Gen's. The difference between the two is that the KAT'S KH11813 is a complete cylinder while the OEM part has a flat edge cut into the length of the cylinder.
    For my 2009 TRD OR 4.0L, made in Canada and bought in UT, the correct part # is: C0140-00889
    Toyota Canada part number: PU140-00902
    Toyota U.S.A. part number: 00113-00213-00902
    (previous part #:00213-00889 or 00213-00885 or 00213-00900)
    So what this boils down to for me, now, is I have to return my Amazon order of the 11813 and then go into town tomorrow to see if Napa carries a replacement for my OEM heater. They DO have the cord, which I may try and see if that lights up my old element plug. We shall see...
