I have a broken valve stem (on my tire/wheel)...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaxPower, Sep 25, 2013.
  1. Sep 25, 2013 at 4:30 PM
    MaxPower
    MaxPower [OP] Truck Noob
    Cezar
    Connecticut
    09 DCLB Taco TRD Sport
    in order to fix it, is the TPS that's in that wheel also need to be replaced? i'm hearing yes, maybe and no from different people i've asked.
    if yes, how much am i to expect it to set me back?
    also, and i dunno if this changes anything, i'm looking to get BFG A/T's (265/70/17) on the truck, (a Sport), soonish.
    thanks for reading. sorry for being a dork when it comes to car/truck stuff.
  2. Sep 25, 2013 at 5:02 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    How did you break it?
  3. Sep 25, 2013 at 5:04 PM
    169.254.255.201 Well-Known Member
    Interwebs
    Do you need TPMS?
  4. Sep 25, 2013 at 5:10 PM
    jw1983
    Alberta
    You don't really "need" TMPS. You could just take the other TPMS out and check your own air pressure. Just sayin'. Save the money towards mods.
  5. Sep 25, 2013 at 5:12 PM
    MaxPower
    Cezar
    Connecticut
    TPMS...?
    Friends put on dice cap covers as a gag gift last year, before winter. The inner cap of the dice ripped out when I tried to unscrew it, with pliers, as it was ON there. When I tried to take off just the metal inner part that remained, it broke. Because I am fucking strong.
  6. Sep 25, 2013 at 5:15 PM
    jw1983
    Alberta
    Tire Pressure Monitoring System. You should be able to replace the stem.
    2000 Post TW!!!! I have a lot of time on my hands.
  7. Sep 25, 2013 at 5:21 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    broken TPMS equals light on dash permanently.
    Might take it to a tire shop and see if they can rebuild or fix it for you.
  8. Sep 25, 2013 at 5:26 PM
    jw1983
    Alberta
    He can't just replace the TPMS only?
  9. Sep 25, 2013 at 5:26 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Unfortunately, if you broke the stem, you most likely do need a whole new sensor. Fortunately, they're fairly inexpensive ($40-50) and easy for your truck to "Learn" the new sensor once it's installed.
    They do sell rebuild kits for some sensors, but usually they're just new gaskets and valves, not the actual structural parts.
  10. Sep 25, 2013 at 5:28 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I believe the stem is part of the sensor, only the "nut" and grommet seals are replaceable if I'm not mistaken, known as a TPMS service kit. Which means the fix is a new sensor, or a valve stem if you are willing to disable the system. I would avoid the latter if you really haven't checked your tire pressures since before last winter. The labour to replace the sensor would be very little if you buy new rubber at the same time.
  11. Sep 25, 2013 at 5:29 PM
    jw1983
    Alberta
    When I bought my 13' Access Cab last year, I had asked how much the dealership wanted for TMPS in my winter tires/rims. They wanted $400.00 with install. Yeah! I could deal with out them. Grew up with cars that didn't have any of that stuff.
  12. Sep 25, 2013 at 5:34 PM
    Noelie84
    Noel
    Wales, Maine
    Dorman sells universal replacements for around $30-$40, and you can get a non-dealer factory-style replacement at most of your local parts stores for between $40-$50 per sensor. Usually the "learn" process for the system to pick up the new sensors is pretty straightforward.
  13. Sep 25, 2013 at 5:36 PM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    At the dealership I work at, when people bring us broken sensors (usually from other tire shops), we charge about 100 for the part and one hour of labor (another 100 dollars) to program it to the truck. Not a pretty answer, but that is what you can expect from a dealership.
    OR
    A new rubber valve stem is 25 cents. And I believe that tire light bulb can be removed behind the dash.
  14. Sep 25, 2013 at 5:44 PM
    Noelie84
    Noel
    Wales, Maine
  15. Sep 25, 2013 at 5:59 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    05+ has a button on the dash to relearn the TPMS. Waking the sensor up sometimes takes a special tool. But generally nothin through the obd port.
    Resetting Toyota TPMS is usually painless.
    Depending on the sensor you can replace just the stem. Then no resetting is required of course
  16. Sep 25, 2013 at 6:02 PM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Steel cap corrodes to aluminum valve stems I know from experience also. I broke my front right of like you and had the local tire shop cut the other 3 off without breaking or messing up the threads and tpms
  17. Sep 25, 2013 at 6:06 PM
    Spoonman
    Jamie
    Alberta
    I see that a lot. Always switch to a plastic cap. Those metal ones are trouble.
  18. Sep 25, 2013 at 6:13 PM
    camojared
    Jared
    SE Ohio
    Yep mine were a gift too... Live and learn I guess
  19. Sep 25, 2013 at 7:29 PM
    jw1983
    Alberta
    It's pretty straight forward checking your own air pressure(without TPMS) too.
  20. Sep 25, 2013 at 7:37 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That won't learn a new TPMS transponder serial number. It only resets the trigger pressure.
    To "learn" the new TPMS, it must be input with either Techstream, or the tire shop should have a tool that can communicate (America's tire does).
    OP.. This is very common when metal caps are installed on the Toyota TPMS stems. They "weld" themselves on.
