I got a flat tire should I replace all 4 tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sh56, Feb 20, 2024.
  1. Feb 20, 2024 at 5:34 PM
    Sh56
    Sh56 [OP] Well-Known Member
    Shara
    2022 Lunar Rock Tacoma TRD off road
    I got a 4wd tacoma
    I got a flat tire and I have a tire warranty. So the dealer changed the flat tire with brand new tire.
    should I change all four tires because the truck is 4wd?
    i read some articles that it says changing only one tire can cause extra stress on 4wd drivetrain and cause immature wear and tear
  2. Feb 20, 2024 at 5:41 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    How many miles and how much wear are on the 3 originals? Those are the biggest factors.
    Oh and TW will defiantly cause immature wear and tear on your soul :D
  3. Feb 20, 2024 at 5:41 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This is usually an issue on AWD vehicles. (You taco is 4WD)
    How worn are your other tires?
    If the difference is severe, you could consider buying two and keeping them in the rear. How often do you use 4Wd?
  4. Feb 20, 2024 at 5:42 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Yes and go bigger.
  5. Feb 20, 2024 at 5:43 PM
    Sh56
    Shara
    Almost 30k mile on originals mostly highway miles.
    I don’t need the 4wd really I only use it once a week to keep things lubricated drive straight line for couple of miles
  6. Feb 20, 2024 at 5:45 PM
    Bishop84
    Bishop84 Well-Known Member
    I can tell you only the full time models have issues with this, and Toyota doesnt have many true AWD vehicles. IS350 is good example of a car that needs identical diameters.
    Just leave it in the rear, rotate the other 3 and get your moneys worth.
  7. Feb 20, 2024 at 7:23 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    My OEM tires ( Firestones ) lasted 15,000 miles with 3 rotations they were down to 4/32.
    Put a set of Wildpeaks on and glad I did.
    Your new tire is probably better than what's the spare is, so if I were you I'd buy a new set, and use that new one as the new-spare.
    HiBillyMaysHere likes this.
  8. Feb 20, 2024 at 7:36 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    37s. Which requires a lift, a CMC, new UCAs and LCAs. Oooh ... and a snorkel!
  9. Feb 20, 2024 at 8:55 PM
    tacotuesday83
    tacotuesday83 Well-Known Member
    DimSum
    Virginia Beach
    19 Tacoma OR
    this is the way
    Mully[QUOTED] and Shellshock like this.
  10. Feb 20, 2024 at 8:55 PM
    TacoTuesday1
    FL
    What are your tread depths and why wasn’t the tire repaired.
    4x and LSD means similar tread depths kept similar by doing tire rotations.
  11. Feb 20, 2024 at 8:56 PM
    tacotuesday83
    DimSum
    Virginia Beach
    19 Tacoma OR
    why patch it when it’s under warranty and you get can get a new tire for free?
  12. Feb 20, 2024 at 8:56 PM
    TacoTuesday1
    FL
    because a free functional patch doesn’t mess up your diameter matching.
    when people purchase new tires, it is typically all of them.
    if I had even tread and somewhat used tires and got a new one in the right rear it would simply achieve the result of fucking up my mechanical LSD.
  13. Feb 20, 2024 at 8:58 PM
    tacotuesday83
    DimSum
    Virginia Beach
    19 Tacoma OR
    :bananadead:
  14. Feb 20, 2024 at 9:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Serious question.
    I honestly don't know the answer too.
    What do you when the TPMS uses the wheel speed sensor?
    Can you reset the system to recalibrate the new "larger" tire?
    I haven't delt with this type system. But always wondered.
    Stevie17 likes this.
  15. Feb 20, 2024 at 9:39 PM
    RichochetRabbit
    1 tire new, 3 tires 50%-ish gone. Some would get 4 new and sell the other 3 for those who need spares. Not saying that is the ONLY way to handle it, just saying that mixed-age tires can be tricky.
  16. Feb 20, 2024 at 9:58 PM
    Bishop84
    WSS isnt on many trucks that I know of, so we've never had to deal with tire size variances. We just bump it past threshold and reset it.
    I can only think of corolla and matrix that had it here. Canada its not law for TPMS, so 50% of models had it until recently. Still now, the Rav4 does not have it (they are canadian made)
    TnShooter[QUOTED] likes this.
  17. Feb 21, 2024 at 9:36 AM
    Mully
    CA
    The force is strong with this one.
  18. Feb 21, 2024 at 5:17 PM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    I'd just buy 4 new now, your gonna need them soon anyway with 30k.
    Mully likes this.
  19. Feb 21, 2024 at 8:25 PM
    Sh56
    Shara
    This is what I did.
    I put the spare tire in front with the new tire. They both are new tires. And I have two old ones in rear with third old one on spare.
    i won’t be rotating until I get all 4 new tires.
  20. Feb 21, 2024 at 8:29 PM
    OZ TRD
    Central Coast CA
    If you put the new ones in the back, theyll catch up (on wear) with the old ones... at which point you can resume your rotation normally
