I did something stupid- Window was down during a storm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jacomus, Apr 29, 2017.
  1. Apr 29, 2017 at 9:31 AM
    jacomus
    jacomus [OP] Member
    I am beating myself today for being an idiot. Last night I left the driver side window down. Powerful storms rolled through and I found the inside of my truck soaked. Nearly all the electronics were covered in water. The seat is soaked of course too.
    I started it up and tested the electronics and so far, everything worked. This is amazing- I didn't expect that.
    I've since moved the truck into my garage and wiped everything down with towels, put a large, basement-style GE dehumidifier (it's the only one I own) in the front and ran the hose out the driver side window. I sealed the rest of that window with towels.
    The hose is unfortunately at an incline so I am not seeing any results but I think the internal bucket is filling up. (It's only been an hour!)
    Anyway, has anyone had this happen and found a water-removal method superior to what I am trying? It's a 2017 TRD OR. I am worried about problems occurring down the road or issues I haven't noticed yet. Thanks
  2. Apr 29, 2017 at 9:43 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Things like this make me glad I have manual locks and windows. Forces me to make sure everything is closed and locked before leaving.
    aeok18109 likes this.
  3. Apr 29, 2017 at 9:48 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I wouldn't have started up the truck and 'tested' out the electronics still wet. Water could short it. Just like if your phone gets wet it's best to let it dry as long you can without turning anything on. Only time will really tell if anything goes wrong. I think you'll be fine though. If all else fails, just play dumb and say you don't know what happened and let the warranty take care of it.
    ExplorHer and Cazzwell like this.
  4. Apr 29, 2017 at 9:49 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Rust in the floor pan under carpet ... i think everyone has done this at least once!
    Good news tho... the rust will likely get covered up with more rust from the under side. By that time you will probably have a new truck!
    One time I had my VW parked under a tree in the spring, all the tree litter fell on the car and the windshield cowl area there's a drain... got clogged and all the water came thru the heater core and into the car next hard rain... had like 4" of water in the car including covering up one of the ECU boxes under the rear seat.
    Dried out fine, didn't even smell... the ECU however was toasted. Car never ran right again after that. Parked it and a few weeks later it got towed in the middle of the night by local street department for no inspection, next day half the tree fell where the car used to be.... I would have gotten replacement value.... just got fucked instead. Got the tree removed by the streets department free tho. Karma..
    tomwil, jacomus[OP] and boynoyce like this.
  5. Apr 29, 2017 at 10:03 AM
    jacomus
    jacomus [OP] Member
    That's a good point about shorting out. I probably should avoid testing them again for a while. I was hoping that just maybe Toyota goes the extra mile for TRD OR trucks and seals the buttons/gauges a bit better than non-OR vehicles. I have no idea, just a theory. Thanks
  6. Apr 29, 2017 at 10:07 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    It'll be fine.
  7. Apr 29, 2017 at 10:16 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    Dry it out good and all will be fine.
    doorsidedown likes this.
  8. Apr 29, 2017 at 10:20 AM
    medic2230
    Murph
    Bama! Roll Tide
    Mine got soaked on the entire floor one time from water running down a CB antenna. I took the entire interior out and dried it.
  9. Apr 29, 2017 at 10:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's doubtful any electronics are actually wet. More sprayed on the surface.
    What you are doing is fine.
    You might want to pull the door sill, lift the carpet, and see about it being wet under there. If it is, you can put a hair dryer, on low, blowing underneath it.
    The good news is you'll likely never do that again. :thumbsup:
  10. Apr 29, 2017 at 10:23 AM
    Taco Caliente
    Taco Caliente WTF?
    San Antonio, TX
    2019 TRD OR DCSB
    This is what I would have done. I would take have taken my leaf blower to the inside of the truck just to blow out any puddles and across the dash area for a good bit. A leaf blower makes a great dryer of things wet! I would then let let it sit for as long a possible, even overnight if I could, BEFORE I even attempted to start it.
  11. Apr 29, 2017 at 10:30 AM
    FHC
    FHC Well-Known Member
    Heat works better than a dehumidifier. Put a small electric heater in the truck and leave the windows down a 1/2 inch.
    ExplorHer likes this.
  12. Apr 29, 2017 at 10:32 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    how so?
  13. Apr 29, 2017 at 10:37 AM
    TOY33
    TOY33 Well-Known Member
    Silver 14 DCSB PreRunner
    Where was this ?
  14. Apr 29, 2017 at 10:38 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Its fine, all you have are cables on the floor and they are shielded. Problems will arise if any of the control boxes got wet, but water would have to be at least a 1~2 foot deep in the floor pan for that to happen. Worry about the carpet / seats and floor pan insulation not the electronics.
    Depending on how far the window was open, maybe look at the door speaker.
    TOY33 likes this.
  15. Apr 29, 2017 at 10:44 AM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Truck left in the bright sunshine with the windows all down is the best --that is for sunny days --when no sun your dehumidifier is a great idea -- just forget the hose and only use the built in tank and check it often
  16. Apr 29, 2017 at 11:18 AM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    Nope, nothing in the interior is since most OR dont leave the pavement regardless of the bedside decal. Doubt anything exterior is sealed more either, most likely it is sealed as well as a 16 year olds jetta...
    Tyler
  17. Apr 29, 2017 at 11:28 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Take a shop vac to the carpets, gets more water out.do the seats too..
    CusterFan and Joe D like this.
  18. Apr 29, 2017 at 11:31 AM
    choupick
    choupick Double Secret Probation
    The south
    2016 DCSB TRD SPORT 4X4 MGM
    Dents in roof from poorly loaded canoe. Broken side mirror from blown transfer truck tire. Scuffed up front bumper from thinking I was still in a corolla. Graham cracker embedded upholstery from a crazy kid.
    The dehumidifier sounds fancy. Last time I did this with my old car I just used a bunch of "DampRid" the next day and it worked fine.
    shakerhood likes this.
  19. Apr 29, 2017 at 11:43 AM
    mrkabc
    mrkabc Mall Crawler with a Locker
    Art
    Corona, CA
    2017 MGM DCSB TRD OR
    Morimoto XB LED Head & Fog Lights, Cali Raised Stealth Light bar, OEM Roof Rack, Homelink Compass Mirror, Power Tailgate Lock, LED bed lights, MESO mirrors, gashole, switch panel & Stage 2 tails, PRO grille. Where's the mall?
    Not true. Dehumidification plus air movement will dry out any interior (homes, car, etc). What the OP is doing is fine as long as the air is being moved within the interior.
    Lt. Dangle likes this.
  20. Apr 29, 2017 at 12:01 PM
    ElCapitan
    ElCapitan Well-Known Member
    Brian
    The High Way Up Far Northeast
    2017 TRD Sport
    I had this happen before I just opened the windows and doors with truck parked in garage and put some fans blowing on it all night. It was warm too because it was summer time and that helped dry it out fast!
