I DID NOT "fill my gas tank" and 24 hours later the dash says empty.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by eurowner, Jun 30, 2023.
  1. Jun 30, 2023 at 9:00 PM
    eurowner
    eurowner [OP] Duke Sky
    Scoty
    I did not put gas in the tank!
    I filled up yesterday, I have driven about 15 miles since. When I went out this evening the truck said I had 24 miles left and the needle points to almost empty. The only thing I did was install front door Kicker speakers, non-JBL headunit, this afternoon (do it, a big difference that the puny stockers).
    I do not have a locking gas cap. I crawled under the truck to look and feel if there was a hole in the tank and didn't find one. I have not filled it up to find out if there is a leak or an electrical problem. I removed the battery negative for over 15 minutes and nothing changed. I have not looked for any codes, there is no CEL.
    Ideas?
    hotdog41 and Little Lion like this.
  2. Jun 30, 2023 at 9:02 PM
    happyvirus
    happyvirus Well-Known Member
    I guess it’s still Friday.
    wilcam47, HisDad and amyracecar like this.
  3. Jun 30, 2023 at 9:03 PM
    eurowner
    Scoty
    Yep, and I made a proper Friday thread a while back. This isn't one.
    uploadadventure and shakerhood like this.
  4. Jun 30, 2023 at 9:04 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Can you show us where the dash is on your truck?
    eurowner[QUOTED][OP] and RIX TUX like this.
  5. Jun 30, 2023 at 9:05 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Did you go fill up and see if you were in fact empty? If you were empty...you were robbed. If not, sending unit.
    eurowner[OP] and RIX TUX like this.
  6. Jun 30, 2023 at 9:10 PM
    eurowner
    Scoty
    I have not filled up to see what the level is now.
    Edit: My credit card isn't showing a charge at the pump.
    I may have not filled up. :pout::frusty::facepalm:
  7. Jun 30, 2023 at 9:11 PM
    eurowner
    Scoty
    IMG_20230630_220644085.jpg IMG_20230630_220655849.jpg IMG_20230630_220723049.jpg IMG_20230630_220815635.jpg
  8. Jun 30, 2023 at 9:15 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
  9. Jun 30, 2023 at 9:16 PM
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    Just go pump and see if any gas will enter. If its full then maybe some level sensor went bad.
  10. Jun 30, 2023 at 9:21 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    get on the side of the bed and push back and forth so the struck rocks and shakes to see if it pops the sensor back
    eurowner[OP] likes this.
  11. Jun 30, 2023 at 9:21 PM
    eurowner
    Scoty
    That did cross my mind. This is the second gasoline fckup in my life this year.
    Stocklocker[QUOTED] likes this.
  12. Jun 30, 2023 at 9:22 PM
    RIX TUX
    first was ?
  13. Jun 30, 2023 at 9:23 PM
    eurowner
    Scoty
    I drove it 5 miles out, partially on a dirt road, and back since the light went on.
  14. Jun 30, 2023 at 9:24 PM
    eurowner
    Scoty
    Got a tank of bad gas in the wife's '00 TJ Wrangler in the winter.
  15. Jun 30, 2023 at 9:33 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I called the cops once because I thought someone shot towards my truck and put a hole in the gas tank. Later on I saw the holes they also drilled in my locking gas cap. Looks like they tried that and then went for the gas tank. … well it looked like a bullet hole to me!
  16. Jun 30, 2023 at 9:52 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    and just so you know.....
    you can go around 30 miles PAST zero because Toyota thinks we can't be trusted and has almost 2 gal left usable in the tank at empty...
    (They say its a safety factor)
  17. Jun 30, 2023 at 10:17 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've seen false readings after parking, or even driving on steep inclines. All of the gas goes to either the front or rear of the tank depending on which end is downward. The sensors think the tank is empty. I've had it happen to me twice in another vehicle. Both times I had to drive about 30 minutes after getting back on fairly level ground before the fuel gauge and DTE readout were accurate.
    Granted that wasn't with a full tank. Both times I had roughly 1/2 tank of fuel when I got false readings. It happened the 1st time after driving up Pikes Peak in CO, and more recently after driving up Mt. Washington in NH.
    FWIW, its almost impossible to siphon fuel out of the tank from the filler on newer vehicles. That's why people are now drilling holes in the tank.
  18. Jul 1, 2023 at 3:13 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Just by chance you set the handle to fill it up automatically and it clicked,stopped and never pumped gas.You think it was on full and infact you didn't get any gas as this may be why your card was never charged. I bet you are still on empty.
    Irons, eurowner[OP] and turbosnail like this.
  19. Jul 1, 2023 at 4:01 AM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    So I’m guessing while you were out running your errands , you possibly stopped at the dispensary before the fuel stop ? It happens …
  20. Jul 1, 2023 at 4:08 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Old age is a unforgiving bxxch isn't she?
