I cannot keep mice out of my engine compartment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willtill, Dec 5, 2023.
  1. Dec 5, 2023 at 10:23 AM
    willtill
    willtill [OP] Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I am at wits end. I’ve tried all of the remedies I know to dissuade them. I placed large satchels of moth balls in the compartment, spray Tomcat Rodent repellent constantly on the firewall insulation, and placed sticky glue traps on the air cleaner and air intake expansion chamber to no avail.
    It seems the mice (or mouse) has an affinity for the Tacoma’s firewall insulation and continually mines it, and builds a nest up under the intake. Very hard to get to, and it takes a lot of work with a shop vac and long needle nose pliers to extract the nest each time she does it.
    I am seriously considering just removing all of the firewall insulation from my truck, in order to dissuade the mice (mouse) from finding nesting material. What would be (if any) negative ramifications after I remove the firewall material?
    I park my truck alongside of a fenced off woodline in my backyard on asphalt pavement. I am sure the woodline where they are coming from.
    Any other ideas for mouse repellents? Short of sticking my truck on a lift every night, I have no idea what else to do….
    HondaGM likes this.
  2. Dec 5, 2023 at 10:25 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Get some barn or stray cats
    Kolohe07, auskip07, BillF1564 and 9 others like this.
  3. Dec 5, 2023 at 10:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    An outdoor cat
  4. Dec 5, 2023 at 10:27 AM
    ironhead181
    ironhead181 Well-Known Member
    2021 Tacoma DBL Cab
    none
  5. Dec 5, 2023 at 10:29 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    +3 for an outdoor cat. A cuddly pal to you, but a stone cold killer to rodents.
  6. Dec 5, 2023 at 10:29 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    mix equal parts peanut butter , baking soda ,and sugar ... and put it under the hood
  7. Dec 5, 2023 at 10:33 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Set like 30 mouse traps. Just kill em all!
  8. Dec 5, 2023 at 10:36 AM
    willtill
    Maryland
    So, I assume this becomes fatal to the mice when they ingest it?
    HondaGM[QUOTED] likes this.
  9. Dec 5, 2023 at 10:37 AM
    willtill
    Maryland
    I’m getting to that point.
  10. Dec 5, 2023 at 10:38 AM
    fourfourone
    My friend just went through this, but they kept getting in his garage. It was the only way to stop it. Mass murder lol.
  11. Dec 5, 2023 at 10:39 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    The baking soda creates carbon dioxide gas when it reacts with the stomach acids of the rodent. Rats cannot pass gas, so the carbon dioxide has nowhere to go and eventually leads to ruptures or internal blockages.
  12. Dec 5, 2023 at 10:41 AM
    MGMDesertTaco
    Cats, pellet gun, mouse traps of different kinds. :infantry:
    auskip07 likes this.
  13. Dec 5, 2023 at 10:43 AM
    willtill
    Maryland
    I don’t think I can do an outdoor cat. We live near a very busy street and we also have a 100 percent toothless, indoor cat. They would not cohabitate well together, and I’m not sure how survivable it would be for the outdoor cat.
  14. Dec 5, 2023 at 10:44 AM
    willtill
    Maryland
    Is this the same for mice? You mentioned it affects just rats.
  15. Dec 5, 2023 at 10:46 AM
    kraftorama
    kraftorama Well-Known Member
    Longmont, CO
    2015 Tacoma TRD OR DCSB
    GFC Camper Icon RXT leaf pack 3rd gen suspension 2022 Trail Edition wheels
  16. Dec 5, 2023 at 10:48 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well...google says it want kill mice,my bad...
  17. Dec 5, 2023 at 10:48 AM
    MGMDesertTaco
    outdoor cats going to be more effective than traps and poison. BTW, don't do the poison if you have cats.
    StayinStock and shakerhood like this.
  18. Dec 5, 2023 at 10:49 AM
    willtill
    Maryland
    Ok. Well, the last thing I want to do is attract them with non-poisonous bats.
  19. Dec 5, 2023 at 10:49 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Use Borax instead of baking soda for mice...
  20. Dec 5, 2023 at 11:01 AM
    themumlord
    themumlord New Member
    If you can stand the smell of peppermint under the hood, I've been picking up these from the local walmart:
    https://www.walmart.com/ip/Mainstay...ppermint/1748276848?athbdg=L1200&from=/search
    mixing them with a little water in a small cheap spray bottle and generally spraying the engine bay bout once a month. I try to hit the wire looms and get a good cover to the top of the engine where I've had previous wires chewed and other signs of mice activity. So far it seems to keep them out, and the smell hasn't intruded into the cab at all.
    Might be anecdotal, but I also found those damn squirrels seemed to stay away from the truck when I had a fresh coat of fluid film / surface shield applied to the frame and lower components. Could be the smell of those items might also help to drive the furry pets away. Granted in my case, I failed to reapply the stuff after it got washed away / covered in mud when I went off roading earlier this year because of my laziness.
    willtill[OP] likes this.
