Hyper flash turn signals.
Discussion in 'Lighting' started by Tamagotchee, Mar 6, 2021.
  1. Mar 6, 2021 at 4:10 PM
    Tamagotchee
    Tamagotchee [OP] Well-Known Member
    SWVA
    2019 TRD Off Road Tacoma
    LEDs are JDM astar. Resistors are 50w 6 ohm. Links below. I still have the hyper flash issue even with resistors in place. I was able to ohm all connections and they all appear to be connected correctly. I tried eliminating one side and the opposite. Tried this with one bulb at a time on all corners. This happens front or rear, driver or passenger. Any idea to why this would still be happening? Could it be the LED headlights or fog lights? I also removed the mirror turn signals from the equation as well.
    I should probably add that it only does this while the headlights are on. Headlights and fog lights off, the signals work correctly.
    JDM ASTAR Super Bright PX Chips 7440 7441 7443 7444 Red Brake LED Bulb https://www.amazon.com/dp/B06XTDBVWT/ref=cm_sw_r_cp_api_glt_fabc_N18SDXZTD9TV41D47S41?_encoding=UTF8
    LivTee 4Pcs 50W 6ohm Load Resistors - Fix LED Bulb Fast Hyper Flash Turn Signal Blink Error Code https://www.amazon.com/dp/B07RB12HHQ/ref=cm_sw_r_cp_api_glt_fabc_7FHHY5PKR85ER7TXC571?_encoding=UTF8
  2. Mar 6, 2021 at 4:11 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    How come you didn't try some plug and play CANBUS options? Just out of curiosity
  3. Mar 6, 2021 at 4:14 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Poor ground.
    Mmaira2018 likes this.
  4. Mar 6, 2021 at 4:15 PM
    Mmaira2018
    Mmaira2018 Well-Known Member
    +1 for most likely a poor ground wire. Check your connections
  5. Mar 6, 2021 at 4:33 PM
    Tamagotchee
    SWVA
    Mainly because I’ve seen many good things about the astar bulbs.
  6. Mar 6, 2021 at 4:36 PM
    Tamagotchee
    SWVA
    I tested everything to ground and made sure connections were solid while troubleshooting. I should probably add that it only does this while the headlights are on. Headlights and fog lights off, the signals work correctly.
  7. Mar 6, 2021 at 4:37 PM
    RedWings44
    Michigan
    I see. Personally, I just don't like messing with stock wiring if I don't have to. There are a few plug and play options out there if you wanted to try that route. I love the ones I have. But, it looks like a few others have some good suggestions for you! Best of luck, either way!
  8. Mar 6, 2021 at 4:38 PM
    Tamagotchee
    SWVA
    I will look into those. I just typically like tinkering with things haha.
  9. Mar 6, 2021 at 4:40 PM
    RedWings44
    Michigan
    Mine are GTR Lighting Carbide CANBUS 2.0 bulbs. I had hyper flash one time, but I had been sitting on the side of the road for about 20 minutes with my flashers on. After they cooled down they were normal again. Just as a place to start
    I definitely know that feeling about tinkering with things! I'm just not good at wiring or electricity.
    TacomaTakeover2k11 likes this.
  10. Mar 6, 2021 at 5:16 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Not sure about your resistor but many use the resistor case as the ground. You may have to scrape the paint under the resistor.
  11. Mar 7, 2021 at 10:20 PM
    Tamagotchee
    SWVA
    I threaded the resistor case and screwed straight to the bed. Should be a solid ground.
  12. Mar 8, 2021 at 4:29 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    "Should be" It should present about a 50 ohm load between the case and the pig tail too. I mounted mine right to the metal with a screw also one worked the other didn't had to sand a bright spot on the truck metal work.
  13. Mar 8, 2021 at 5:57 AM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    I've got factory LED headlights, and the MESO stage 1 taillights worked for me without resistors. Tried Lasfit and EVO bulbs but had hyperflashing
    With MESO I do have hyperFlash but only when in reverse and turning but I never do that. MESO has plug/play resistors if needed and often sends them for free if you contact him.
