Hyper Dip…hyper disaster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacomalex1949, Apr 16, 2022.
  1. Apr 16, 2022 at 7:33 AM
    tacomalex1949
    tacomalex1949 [OP] Well-Known Member
    Alex
    2021 Tacoma DCSB
    Well, I let this post sit over night while I relaxed from my frustration.
    TL: DR: Looking for advice on where I messed up with HyperDip.
    I went and Plastidiped my fender flares a few weeks ago. After hesitation and skepticism, I researched and found HyperDip, which seemed to be the best I could get. Or at least it was supposed to work fine!
    I painted the fenders following instructions, 4 light coats and then probably 6 coverage coats. I let them dry/cure for over two weeks before I put them on the truck. I have had great experience with spray paint in the past so I figured I knew what I was doing.
    The “tackiness” was almost non existent so I figured they were pretty good and cured but during the install, I got some dirt on a fender and went to wipe it off with a rag. Even with light pressure the damn thing started peeling! Just to make sure I wasn’t crazy, I grabbed some glass cleaner and a shop rag and lightly tried cleaning another one, and it peeled as well! I mean the entire paint job is as fragile as tissue paper. I am extremely disappointed in this product and likely will rip it all off. And no way in hell do I feel comfortable going through a car wash, despite videos claiming you could.
    But it would be ignorant to just blame it on the product. I can assume I must have done something wrong. Any idea what I could have done wrong? Anybody had similar experiences? Were all the testimonials fake and this is a crap product or did I seriously mess this up in the application.
    At this point I don’t think I’ll ever try to plastidip something ever again. It was a ton of work just to save a bit of cash.
    RhodeIsland4bang likes this.
  2. Apr 16, 2022 at 8:02 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    that sucks, man.
  3. Apr 16, 2022 at 8:04 AM
    Holling
    Holling Well-Known Member
    West Coast
    2021 DC TRD Sport
    What did you do for prep work before applying? It sounds like there was wax or some kind of residue that prevented any adhesion.
    Skydvrr and RhodeIsland4bang like this.
  4. Apr 16, 2022 at 8:10 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    did each coat dry thoroughly before applying the next coat?
  5. Apr 16, 2022 at 8:11 AM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    I got the truck washed, then removed the fenders and thoroughly washed them by hand with dish soap and a sponge to hopefully get off any oils or such. I wash the car regularly but never wax it, so I was hoping that would do the trick!
  6. Apr 16, 2022 at 8:12 AM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    I gave it about 30 minutes between each coat, which YouTube said was more than enough! The paint was dry to the touch each time. I was surprised that the instructions from the company allowed for such quick recoat times, but hey, their product, their instructions! You think that could have messed it up?
  7. Apr 19, 2022 at 3:12 PM
    2wdSR52022
    2wdSR52022 Well-Known Member
    Jc
    Expensive SR5
    That sucks, I was thinking about doing the same to mine...
  8. Apr 19, 2022 at 6:54 PM
    MJTH
    MJTH PretenderLander
    Joe
    Colorado-Westslopebestslope
    19 OR- Land Yacht, w/ fireplace
    The stock fenders have too much of a smooth surface for it to adhere well too. Unless you sand it and give it a rough surface to grab onto, you won't get any good adhesion with paint or plastidip.
    On top of sanding, clean with rubbing alcohol. It won't risk leaving residue that will again, not help with adhesion
  9. Apr 19, 2022 at 7:58 PM
    tacomalex1949
    Alex
    2021 Tacoma DCSB
    Yeah I didn’t want to sand because I wanted the option to remove it if need be…I think I’m surrendering and I’m gonna rip it off. I’ll just pay for new fenders if I really want the black. This will probably be my one and only attempt at plastidip
  10. Apr 19, 2022 at 8:07 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You should look into vynil wrapping them.
