HPS short ram intake on the 2.7 taco let me know what you think
Discussion in 'Performance and Tuning' started by 07tacoregcab, Jan 27, 2016.
  1. Jan 27, 2016 at 4:00 PM
    07tacoregcab
    07tacoregcab [OP] Well-Known Member
    2007 Toyota Tacoma regular cab 2.7L 5speed
    2inch front spacer lift in the front 1 inch add-a-leaf in the rear leveling kit
    I wanted to change up the intake so I went with a blue HPS silicone short ram intake. It also has a heat shield but for what i paid I'm happy. Better throttle response too
  2. Jan 27, 2016 at 6:40 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Hot air intake = lost power :(
  3. Jan 28, 2016 at 7:31 AM
    07tacoregcab
    The piping for a cold air intake is not much more tucked towards the ground so it pulls hot air as well. I left the bottom half of the stock air filter on below the cone bc there's a tube that's pulling air from the wheel well
  4. Jan 28, 2016 at 10:20 AM
    WOODEX M.E.
    Corey
    Maine
    Cold air intakes for our truck seal to the hole in the fender well pulling ambient air.
    98% of the air you are drawing in with that setup is all air being heated by the motor. I guarantee you are not getting anything coming from the stock tube.
    Just trying to help.
  5. Jan 29, 2016 at 12:26 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    im not sure about the 4 banger, but a k&n intake on a 2nd gen v6 (shit filter imho) still draws ambient air at the same speed stock does approx 40mph......yet looks like wut u would call a hot air intake
  6. Jan 29, 2016 at 12:30 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    That's why you go with the fully enclosed aFe.
  7. Jan 29, 2016 at 12:31 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    because they all draw the same temp air at 40mph?
  8. Jan 29, 2016 at 12:33 PM
    Nighthawk
    Levi
    Casper Wyoming
    Better filter
    Justus[QUOTED] likes this.
  9. Jan 29, 2016 at 12:34 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    agreed...... but I had to try all of them to test the temps...... that pos got sold asap tho
  10. Jan 29, 2016 at 12:39 PM
    Nighthawk
    Levi
    Casper Wyoming
    Seems like all CAI are pretty useless. Good money making scam though. "Adds 16 HP!!!" should read "makes rumbly noise when you step on it!!"
  11. Jan 29, 2016 at 12:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Turn the piping and take air from the cowl.
  12. Jan 29, 2016 at 3:46 PM
    07tacoregcab
    With my experience with after market air intake is no matter how much you wrap it with "heat resistant wrap" or an In-closed box they all pull hot air. How could a motor not gain any sort of power from any kind of intake its pulling more air in which means more power.. Right?
