How Would You Remove This Oxygen Sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongEnoughCrazy, Jul 29, 2024.
  1. Jul 29, 2024 at 8:40 AM
    LongEnoughCrazy
    LongEnoughCrazy [OP] Active Member
    This corrosion is so severe that I can't even see a nut. How would you attack this?
  2. Jul 29, 2024 at 8:44 AM
    545 Well-Known Member
    2015 Access Cab
    I’d pound a external bolt remover on to the studs and try and remove the stud and nut at the same time
  3. Jul 29, 2024 at 8:49 AM
    Dare Devil Diablo
    Dare Devil Diablo Well-Known Member
    2000 TRD Offroad MT
    Probably want to use a lot of PB Blaster.
    They make sockets for removing rounded bolts.
    You can also try cutting a slot in the bolt with a Dremel and then use an impact screwdriver with a flat bit.
    You could also sawzall the thing under the head of the bolt, slide off the remaining portion and then use some vice grips to work out the remaining screw.
    If you can weld you could tack a nut to the top of the bolt and remove them that way.
  4. Jul 29, 2024 at 9:02 AM
    BroTaco8008
    BroTaco8008 Well-Known Member
    01 TRD sport
    Mine looked the same. I beat on a smaller socket
  5. Jul 29, 2024 at 1:23 PM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
  6. Jul 29, 2024 at 1:36 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    b4 you do anything.....
    i would just make sure that you cant feel an exhaust gas leak here:
    Clucky, Moto521, Pscdouglas and 5 others like this.
  7. Jul 29, 2024 at 1:38 PM
    LongEnoughCrazy
    How do I test this?
  8. Jul 29, 2024 at 1:46 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    It's important to know that the studs are threaded into the bung on the exhaust. They are replaceable if you damage them. That being said- if it were me, I wouldn't think twice about getting in there with a cut off wheel and do some precision cutting on whats left of the bolts, and then just replace the studs.
    CrustyTaco and bkhlrTaco's like this.
  9. Jul 29, 2024 at 1:46 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Start it up. Put your hand down there and feel.
    I'd be surprised if you got that off without snapping a post. Then you just created a bigger problem.
    Like mentioned above...a leaking exhaust could read as a bad O2 sensor.
  10. Jul 29, 2024 at 1:52 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Become friends with someone who has a torch and a welder. Good luck!
    bkhlrTaco's likes this.
  11. Jul 29, 2024 at 2:36 PM
    ControlCar
    Steven
    Sugar Land TX
    what bkhlr says^^^^^
    as long as truck/exhaust not volcano hot can use soapy water in spray bottle too
  12. Jul 29, 2024 at 2:40 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Smoke machine through the tailpipe, would that work to locate any leak?
  13. Jul 29, 2024 at 2:56 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    It would.
    LongEnoughCrazy[OP] likes this.
  14. Jul 29, 2024 at 2:59 PM
    MadNachos
    PB sprays over a day, a map gas torch, and it will come right off. Heat it, let it cool, and do it again if it fights. Worst case Dremel the nuts off and deal with the studs.
  15. Jul 29, 2024 at 3:05 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I second cutting/grinding the nuts off and then using vice grips to remove the studs and replace them. Its gonna be rough/hard/dirty work. PB blaster will absolutely be your friend here.
  16. Jul 29, 2024 at 3:44 PM
    ControlCar
    Steven
    Sugar Land TX
    IF no exhaust leak found
    I would carefully use dremmel and make slot in what is left of those bolts(not dmging stud threads)
    Then use flathead/hammer and split bolt
    This also depends on clearance u have
    if there is exhaust leak on the base of O2 sensor…..
    I would just take to exhaust/muffler shop
    They likely would just section in a pipe along with new O2 bung with studs
    That O2 bung is universal (just like the newer style ones (only a threaded bolt)
    $200 at the most
  17. Jul 29, 2024 at 5:25 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I would probably try using a nut splitter first. There are sets in the $20-30 range on Amazon. If that didn’t work, I’d probably try using a bolt/nut extractor socket. If you can remove the nut without damaging the stud you’ll save yourself some time, but there’s a good chance they’ll come out together.
  18. Jul 29, 2024 at 8:21 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Went through this on both front and back O2 sensors. Use a small file to file down one side of the nut off. Then tear the nut off with needle nose pliers. But your gonna need to replace that section of pipe/muffler soon. Had the same issue and replaced the muffler, O2 sensor and hardware at the same time while it was out.
  19. Jul 30, 2024 at 5:27 AM
    Black97v6MT
    iMA0
    tacoLand USA
    that is a California rig?
  20. Jul 30, 2024 at 5:32 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Mine looked like that. I just heated the nut residue red hot with a hand torch and then unscrewed the nut using channel locks.
