how would u lowwr a 2012 tacoma base model
Discussion in 'Street Trucks' started by sullie62604, Mar 19, 2013.
  1. Mar 19, 2013 at 6:10 AM
    sullie62604
    sullie62604 [OP] Rawdoggin Randoms
    Steven
    Ft Benning, GA
    2012 Tacoma Base Model
    I'm looking for a way to lower the front of my 2012 Tacoma base model
    If u know a cheap way let me know
    Also would x runner front spring fit if so how much of a drop will I get
  2. Mar 19, 2013 at 6:13 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    Cut the springs
    Super cheap
  3. Mar 19, 2013 at 6:15 AM
    Large
    Large Red
    Sorry man I have to ask, why buy the most expensive mid size truck and look for cheap ways to mod it?
  4. Mar 19, 2013 at 6:15 AM
    sullie62604
    Steven
    Ft Benning, GA
    Wouldn't that hurt the ride
    And how much would I cut
  5. Mar 19, 2013 at 6:16 AM
    sullie62604
    Steven
    Ft Benning, GA
    If u don't have anything useful to say please don't post
  6. Mar 19, 2013 at 10:30 AM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    Xrunner coils will work
    You could buy spacer kit for about 1-1.5 inch drop in front and buy 2 inch blocks out back this would be the cheapest
    Or you could purchase xii 1.7 inch drop coil for the front which will stiffin the ride a little more
    More expensive route is djm 3/4 or 3/3 kit
  7. Mar 19, 2013 at 10:32 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    softer spring rate
  8. Mar 20, 2013 at 5:06 PM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    lower the front only? just throw is a xii performance drop coil
  9. Mar 31, 2013 at 12:34 AM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Upgrading gears is a must for those tires
    I have 255/50/19 which is same height you planning to run on stock gears haha I'm stretching them for days when I shift haha would be even worse if u had an automatic
    But I'm downsizing anyways to stock height tires since I'm lowering my truck
  10. Mar 31, 2013 at 5:47 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Well the height im dropping now way my current tires would fit so stock height tires will be needed
    Even if I were lowering it only a little I wouldn't.personally run as big as a tire I have but somewhere in the middle between the stock size and what I have
    I hate the fact of how much wheel gap came on the 2nd gens:p
    There's two solutions:
    1. Small drop tall tires
    2. Slammed till fender meets the tire haha
