How tough is it to remove the cab?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Strostkovy, Jul 1, 2021.
  1. Jul 1, 2021 at 1:21 PM
    Strostkovy
    Strostkovy [OP] Well-Known Member
    Alex
    White 98 Tacoma
    I'm doing both an engine swap and frame repair. The bed is already gone; how tough is removing the cab? I've never done it nondestructively before.
    It's a 4x4 manual extended cab with the 2.7l.
    Basically, is the time and effort of removing the cab less than the time and effort of swapping the engine and cleaning/painting the frame with the cab in the way?
  2. Jul 1, 2021 at 1:27 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I don't know for sure, but I'd think it is pretty straight forward.
    Break all electrical connections, disconnect the mechanical connections, remove cab mounts. Should lift off. It'll be heavy and extremely awkward.
    Go slow, easy to miss a connection.
  3. Jul 1, 2021 at 1:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Tour991 likes this.
  4. Jul 1, 2021 at 2:08 PM
    Bishop84
    Bishop84 Well-Known Member
    Its not bad dependent on rust.
    The cab mounts can seize and are a real hassle to cut and remove.
    It's just a lot of work and moving it is very difficult.
    Strostkovy[OP] likes this.
  5. Jul 1, 2021 at 2:12 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    It's not that hard once you have the motor out. Break lines, fule lines disconect from the tank, ebrake disconnect at the frame arm, tail light harness disconect drone frame and the steering linkage.
    It's a lot easier then you think. Onec that's all done undo the body bolts and lift.
  6. Jul 1, 2021 at 2:25 PM
    Strostkovy
    Alex
    White 98 Tacoma
    Currently I have the heads off. Do I need to pull more of the motor to get the cab free? I was hoping to plop the cab back down on a mostly complete engine bay
  7. Jul 1, 2021 at 2:26 PM
    Strostkovy
    Alex
    White 98 Tacoma
    Good call, I'll oil up and see if I can get the cab mounts free before disconnecting anything else.
    Tour991 likes this.
  8. Jul 1, 2021 at 4:55 PM
    Tour991
    James
    South Reno/Tahoe
    No you don't but you do have to disconnect the ecu and pull the harness through the fire wall. And a few other lines.
