How to wire fog lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kolton76, Jan 1, 2025.
  1. Jan 1, 2025 at 3:24 PM
    Kolton76
    Kolton76 [OP] Well-Known Member
    Kolton
    Michigan
    2008 white Tacoma SR5
    I have a base model regular cab that I wanna wire fog lights into. My only problem is that I would have to run a fuse tap in order to not have any parasitic draw from the battery. And depending on what I wire it to, my fog light button will always be on. I only want it on when my fog lights are on. It always bugs me when my clutch start cancel switch light stays on, and I know the light will bug me when it’s not on. I was curious if this was at all possible. Maybe even wire it to the horn, because the horn won’t always be on if that makes sense. I know most guys just fuse tap it into a headlight or radio fuse. Link is for reference of the harness. I’m also going to use an OEM fog light button, if that at all makes a difference for if the light turns on or not. https://www.amazon.com/dp/B07MML8QCP?starsLeft=1&skipTwisterOG=1
